I'm very new to arduino, and I would like a little help with coding techniques:
I'm trying to build a conceptual circuit that will light an LED when a piezo speaker reads a certain amount of noise. How would I set up the variables, like the pins that the LED and speaker are hooked up to? Could someone please write a piece of code that would accomplish this? I'd love some help understanding the way arduino works better. Thanks!
Is there anything useful over at the Playground_
#define piezoPin A5 // select the input pin -- analog 5
int ledPin = 13; // select the pin for the speaker
int val = 0; //store value from piezo
pinMode(ledPin, OUTPUT); // declare the ledPin as an OUTPUT
val = analogRead(piezoPin); //read value from piezo
if (val > 500) //you need to find the value for this
digitalWrite(ledPin, HIGH);
delay(100); //about how long the LED will stay on.
digitalWrite(ledPin, LOW); //turn off if value isn't high enough
Serial.println(val); //debug
how to wire the piezo to the arduino
basic, but should work
i know what you mean by example. needed the same thing when i was more of a newb.
sirbow2:
How do you ensure that the piezo output voltage never exceeds 5V?
the megaohm resistor...
Holy crap, Thanks so much!!
