Help by which code i choose for rtc module
hello ! guys Can you help me by providing code for ds3231 current date,time and wether. since i am tried but giving wrong date and time to i2c lcd module
Try the following sketch which shows output on Serial Monitor. You can add codes to show output on LCD.
#include "RTClib.h" //for DS3231 RTC contains Wire.h
#include<Wire.h>
byte prSec = 0;
RTC_DS3231 rtc; //user data type RTC_DS3231    variable rtc or object
DateTime nowDT;
char daysOfTheWeek[7][12] = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
void setup ()
  Wire.begin();
  rtc.begin();
  rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));//takes time of the day from PC
  //rtc.adjust(DateTime(2021, 12, 31, 01, 59, 57));//set date-time manualy:yr,mo,dy,hr,mn,sec
void loop ()
  showTime();
  waitOneSec();//1-sec interval of time display; it comes from DS3231 itself
void showTime()
  nowDT = rtc.now();  //nowDT hold Date and Time
  byte myHour = nowDT.hour();   //myHour holds Hour of time of daya
  if (myHour < 10)
    Serial.print('0');
  Serial.print(myHour); Serial.print(':'); //12:58:57     12:4:56
  byte myMin = nowDT.minute(); //to show leading zero of minute
  if (myMin < 10)
    Serial.print('0');
  Serial.print(nowDT.minute()); Serial.print(':');
  byte mySec = nowDT.second();
  if (mySec < 10)
    Serial.print('0');
  Serial.print(mySec);//(nowDT.second(), DEC);
  Serial.print("  ");
  Serial.print(daysOfTheWeek[nowDT.dayOfTheWeek()]); Serial.print(' ');
  byte myDay = nowDT.day();
  if (myDay < 10)
    Serial.print('0');
  Serial.print(myDay); Serial.print(':');
  byte myMonth = nowDT.month();
  if (myMonth < 10)
    Serial.print('0');
  Serial.print(nowDT. month()); Serial.print(':');
  Serial.println(nowDT.year());
void waitOneSec()
  prSec = bcdSecond();   //current second of RTC
  while (bcdSecond() == prSec)
byte bcdSecond()
  nowDT = rtc.now();
  return nowDT.second();
Output:
22:57:58  Wednesday 15:06:2022
22:57:59  Wednesday 15:06:2022
22:58:00  Wednesday 15:06:2022
22:58:01  Wednesday 15:06:2022
yeah it is correct .but i want to show current dete and time with that . can you help with these
along with weather in i2c lcd module. i can do this earlier.but problem with current data and time set
THIS IS MY CODE & I WANT TO TAKE DATE AND TIME FROM PC
#include <Wire.h>
#include "ds3231.h" // needs config.h, ds3231.cpp
#define BUFF_MAX 128
// remove this block of commented lines - refers to non-I2C LCD
//---(Following are the PCF8574 pin assignments to LCD connections )----
// This are different than earlier/different I2C LCD displays
// #define Rs_pin 0
// #define Rw_pin 1
// #define En_pin 2
// #define BACKLIGHT_PIN 3
// #define D4_pin 4
// #define D5_pin 5
// #define D6_pin 6
// #define D7_pin 7
// #define LED_OFF 0
// #define LED_ON 1
// ---- -( Declare objects )---- - /
// this says I2C, but is using both I2C and ?other? pin protocol
// LiquidCrystal_I2C lcd(I2C_ADDR, En_pin, Rw_pin, Rs_pin, D4_pin, D5_pin, D6_pin, D7_pin);
//****Define I2C LCD Display *********************************
#define I2C_ADDR 0x27 // Define I2C Address for the PCF8574T
LiquidCrystal_I2C lcd(0x27, 16, 2); // USE THIS FOR I2C LCD
END LCD DISPLAY *******************************************
uint8_t time[8]; // (1) redeclaration of "time" (2) never used
char recv[BUFF_MAX];
unsigned int recv_size = 0;
unsigned long prev, interval = 1000;
Wire.begin();
rtc.begin();
rtc.adjust(DateTime(F(DATE), F(TIME)));//takes time of the day from PC
// DS3231_init(DS3231_INTCN); // archaic
DS3231_init(DS3231_CONTROL_INTCN);
memset(recv, 0, BUFF_MAX); // WHY?
Serial.println("GET time");
//LCD Setup******
lcd.begin (16, 2);
// initialize the lcd
lcd.backlight(); // this is the correct function call
// Switch on the backlight
// lcd.setBacklightPin(BACKLIGHT_PIN, POSITIVE); // not I2C LCD
// lcd.setBacklight(LED_ON); // not I2C LCD
//END LCD Setup*****
Serial.println("Setting time");
setTheTime("304022113122023"); // ssmmhhWDDMMYYYY set time once in the given format
char tempF[6];
float temperature;
char buff[BUFF_MAX];
unsigned long now = millis();
struct ts t;
// show time once in a while
if (now - prev > interval) {
DS3231_get(&t); //Get time
temperature = DS3231_get_treg(); //Get temperature
dtostrf(temperature, 5, 1, tempF);
lcd.clear();
lcd.setCursor(0, 0);
lcd.print(t.mday);
printMonth(t.mon);
lcd.print(t.year);
lcd.setCursor(0, 1); //Go to second line of the LCD Screen
lcd.print(t.hour);
lcd.print(":");
if (t.min < 10)
lcd.print("0");
lcd.print(t.min);
lcd.print(":");
if (t.sec < 10)
lcd.print("0");
lcd.print(t.sec);
lcd.print(' ');
lcd.print(tempF);
lcd.print((char)223);
lcd.print("C ");
prev = now;
void setTheTime(char *cmd)
struct ts t;
t.sec = inp2toi(cmd, 0);
t.min = inp2toi(cmd, 2);
t.hour = inp2toi(cmd, 4);
t.wday = inp2toi(cmd, 6);
t.mday = inp2toi(cmd, 7);
t.mon = inp2toi(cmd, 9);
t.year = inp2toi(cmd, 11) * 100 + inp2toi(cmd, 13);
DS3231_set(t);
Serial.println("OK");
void printMonth(int month)
switch (month)
case 1: lcd.print(" January "); break;
case 2: lcd.print(" February "); break;
case 3: lcd.print(" March "); break;
case 4: lcd.print(" April "); break;
case 5: lcd.print(" May "); break;
case 6: lcd.print(" June "); break;
case 7: lcd.print(" July "); break;
case 8: lcd.print(" August "); break;
case 9: lcd.print(" September "); break;
case 10: lcd.print(" October "); break;
case 11: lcd.print(" November "); break;
case 12: lcd.print(" December "); break;
default: lcd.print(" Error "); break;
You didn't like the help to the same question here?
Why not ask ChatGPT, like the responses you provided here?
