Help change interupt pins in code to work with mega
Hello, I'm not very familiar with how interrupt pins work on either the Uno or Mega but I have code that works on an Uno but doesn't work using the same pins on a Mega. I'll attach the code here so you can take a look for yourself. It's not my code, just something I found online and am trying to modify. The issue specifically is with reading data on pins D2 & D3. Everything works fine on uno but it seems like the interrupt pins used to read the data aren't working on a Mega. Can I just use the same code but attach the data0 and data1 wires to different pins on the board? If so, what pins? or could I use the same pins but change the code a little so it works? If so, then what do I need to change?
/* HID ProxPoint Skimmer
*  Brad Antoniewicz
* This is a prototype for a skimmer that sits between a
* HID ProxPoint reader and a VertX Controller
* It will take data recieved from the Reader, print it
* and send it to the controller
* It will also take data recieved from the Serial interface
* on the Arduino (in Binary) and send it to the controller
* Arduino Pinouts:
*        2 - ProxPoint Green (DATA 0)
*        3 - ProxPoint White (DATA 1)
*        8 - Output to VertX Data 0 (Green)
*        9 - Output to VertX Data 1 (White)
*        11 - VertX Strike Relay NO 1
*        12 - VertX Strike Relay NO 2
*        13 - LED
*        5V - To ProxPoint Red
*        GND - To ProxPoint Black
*        GND - To VertX Ground (Black)
*  All of the Remaining ProxPoint wires can be plugged into the VertX
*  or left out.
* 26-Bit Wiegant Format:
* Bit 1 = Even Parity over Bits 2 - 13
* Bits 2 - 9 = Facility Code (0 to 255) Bit 2 is MSB
* Bits 10 - 25 = ID Number (0 to 65,535) Bit 10 is MSB
* Bits 26 Odd parity over bits 14 to 25
* Disclaimer - I know this code is REALLY sloppy and inefficient
*          Please don't judge me :)
#define CARD_LEN 26
#define LED 13   // output LED
#define VX_D0 8  // output DATA0 (Green) to Controller
#define VX_D1 9  // output DATA1 (White) to Controller
#define VX_NO1 11 // input VertX Strike Relay NO 1
#define VX_NO2 12 // input VertX Strike Relay NO 2
unsigned long cardValue = 0;
int incomingByte = 0;
int sInputCount = 0;
/* This code is for processing data from the reader - Thanks Mike Cook!
volatile unsigned long reader1 = 0;
volatile int reader1Count = 0;
void reader1One(void) {
   reader1Count++;
   reader1 = reader1 << 1;
   reader1 |= 1;
void reader1Zero(void) {
   reader1Count++;
void isr(int action) {
   if ( action == 1 ) { // Start
/* Crazy People Timing and ISR -- Thanks Mike Cook! */
       attachInterrupt(0, reader1Zero, FALLING);//DATA0 to pin 2
       attachInterrupt(1, reader1One, FALLING); //DATA1 to pin 3
       delay(10);
   } else { // Stop
       detachInterrupt(0);
       detachInterrupt(1);
// END Reader In
void resetState() {
   Serial.println("[+] Reseting State...");
   delay(10);
   Serial.flush();
   sInputCount=0;
   reader1 = 0;
   reader1Count=0;
void writeCard(volatile unsigned long sendValue) {
     Serial.println("[-] Sending Data:");
     Serial.print("\t");
     for (short x=CARD_LEN; x>=0; x--) {
       if ( bitRead(sendValue,x) == 1 ) {
         Serial.print("1");
         digitalWrite(VX_D1, LOW);
         delayMicroseconds(34);
         digitalWrite(VX_D1, HIGH);
       } else if ( bitRead(sendValue,x) == 0 ) {
         Serial.print("0");
         digitalWrite(VX_D0, LOW);
         digitalWrite(VX_D0, HIGH);
       delay(2);
void processInput(int byte) {
    if (byte == 49) { // DECIMAL 1
      sInputCount++;
      bitSet(cardValue, CARD_LEN - sInputCount);
   } else if (byte == 48) { // DECIMAL 0
      sInputCount++;
      bitClear(cardValue, CARD_LEN - sInputCount);
   } else if (byte == 98 || byte == 66) { // b or B
       Serial.println("[-] Entering Brute Force Mode, provide starting value:");
  //    doDecBrute();
     Serial.print("[!] Recieved invalid Value:");
       Serial.println(byte);
       resetState();
void printCardData(unsigned long data) {
     int serialNumber = (data >> 1) & 0x3fff;
     int siteCode = (data >> 17) & 0x3ff;
     Serial.print("\tH: ");
     Serial.print(data,HEX);
     Serial.print(" SC: ");
     Serial.print(siteCode);
     Serial.print(" C: ");
     Serial.println(serialNumber);
     Serial.print("\tB: ");
     Serial.println(data, BIN);
/* This stuff is for the Door Sensor LED */
   pinMode(LED, OUTPUT);
   digitalWrite(LED, LOW);
   digitalWrite(LED, HIGH);
   pinMode(VX_NO1, INPUT); // Reader 1
   pinMode(VX_NO2, INPUT); // Reader 2
// End Door Sensor Stuff
/* Reader In - */
   isr(0);
   isr(1);
   for(int i = 2; i<4; i++){
     pinMode(i, OUTPUT);
     digitalWrite(i, HIGH); // enable internal pull up causing a one
     digitalWrite(i, LOW); // disable internal pull up causing zero and thus an interrupt
     pinMode(i, INPUT);
   delay(10);
   reader1 = 0;
   reader1Count = 0;
//End Reader In
   pinMode(VX_D0,OUTPUT);
   pinMode(VX_D1,OUTPUT);
  sInputCount = 0;
   Serial.begin(38400);
   Serial.println("Please provide a tag value");
   Serial.println("For Binary input, it must be 26 bits long");
   Serial.println("No parity needs, just add two 0's to the beginning");
   Serial.println("e.g. 00001001100011111110010101");
  int reader1Status = digitalRead(VX_NO1);
  int reader2Status = digitalRead(VX_NO2);
  if ( reader1Status == HIGH || reader2Status == HIGH ) {
     Serial.println("---  D o o r  U n l o c k e d ---");
     delay(4000);
/* Start Serial In
    All this stuff does is accept input via the serial interface
  if (Serial.available() > 0 ) {
     incomingByte = Serial.read();
     Serial.print(".");
     delay(10);
     processInput(incomingByte);
     if ( ( sInputCount > 0 ) && ( sInputCount != CARD_LEN ) && ( Serial.peek() == -1 ) ) {
           Serial.println("\n[!] Invalid Input Length!");
           resetState();
   if (sInputCount == CARD_LEN) {
       Serial.println("");
           Serial.println("[-] Sending current Serial Buffer");
           writeCard(cardValue);
           resetState();
      } else if (sInputCount > CARD_LEN) {
           Serial.println("[!] Sorry, looks like your input was too long.. ");
           resetState();
// End Serial In
/* Start Reader IN
     All this stuff does is take data in from the reader
     then send it to the controller
 if(reader1Count >= 26){
     Serial.println("");
     Serial.println("[+] Recieved input from Reader:");
     Serial.println("-------------------------------");
     printCardData(reader1);
     Serial.println("[+] Sending input to Controller:");
     writeCard(reader1);
     resetState();
    // END Reader IN
If only there was a reference page for this sort of thing
Interrupts on pins D2 & D3 on Mega has numbers 4 & 5 rather than 0 & 1 on Uno.
To avoid such problems do not use interrupt numbers directly:
use digitalPinToInterrupt() function and pin number instead:
attachInterrupt(digitalPinToInterrupt(2), reader1Zero, FALLING);//DATA0 to pin 2
attachInterrupt(digitalPinToInterrupt(3), reader1One, FALLING); //DATA1 to pin 3
Yes, as long as the pins are external interrupt pins.
Calling variables the same name as datatypes is confusing
if (byte == '1')
Is so much easier to read, don't you think?
This was the answer; Solved my problem. Thank you so much!
Like I said, not my code. However, I will take your advice when modifying it for my own code. Thanks!
