Gonna cut straight to the cheese, im trying to use Serial Port to send commands to my servo, i have it all worked out, but i have to type numbers in.
int IT1 = 120;
Essentially thats what i have, but i have to type in the 120, is there a way to make it so i have to type in “IT1” into the serial port to execute the same command?
You dont have to read the code unless you want to…
#include<Servo.h>
Servo servo1;
const int IT1 = 120;
const int IT2 = 45;
const int IT3 = 0;
int Order = 15;
// Example 4 - Receive a number as text and convert it to an int
const byte numChars = 32;
char receivedChars[numChars]; // an array to store the received data
boolean newData = false;
int dataNumber = 1; // new for this version
Serial.println("<Arduino is ready>");
servo1.attach(4);
recvWithEndMarker();
showNewNumber();
if (dataNumber == IT1){
servo1.write(IT1);
servo1.write(180);
servo1.write(90);
dataNumber++;
if (dataNumber == IT2){
servo1.write(IT2);
servo1.write(180);
servo1.write(90);
dataNumber++;
if (dataNumber == IT3){
servo1.write(IT3);
servo1.write(180);
servo1.write(90);
dataNumber++;
if (dataNumber ==Order){
servo1.write(IT1);
servo1.write(180);
servo1.write(90);
servo1.write(IT2);
servo1.write(180);
servo1.write(90);
servo1.write(IT3);
servo1.write(180);
servo1.write(90);
dataNumber++;
void recvWithEndMarker() {
static byte ndx = 0;
char endMarker = '\n';
char rc;
if (Serial.available() > 0) {
rc = Serial.read();
if (rc != endMarker) {
receivedChars[ndx] = rc;
ndx++;
if (ndx >= numChars) {
ndx = numChars - 1;
else {
receivedChars[ndx] = '\0'; // terminate the string
ndx = 0;
newData = true;
void showNewNumber() {
if (newData == true) {
dataNumber = 0; // new for this version
dataNumber = atoi(receivedChars); // new for this version
Serial.print("This just in ... ");
Serial.println(receivedChars);
Serial.print("Data as Number ... "); // new for this version
Serial.println(dataNumber); // new for this version
newData = false;
