Help /Code Stucks in loop
hello folks, i'm working on an accademic project with my custom Board based on the ATMEGA328p
16Mhz.
Some times my code stucks in the methods of ActionMethods.ino.
exactely in this loop
 do
      if(digitalRead(capTiroir1) && typeCaisse)break;// typeCaisse =0 then if(digitalRead(capTiroir1) && typeCaisse) will be always 0 so break will not be called
    } while ((millis() - timestart) < 300) ; //we will be testing on the time out
i think the problem might be caused by millis overflow.
thankyou for your help.
My code:
main.ino
#define DEBUG // comment to desactivate debug
#define DEBLOCKING // comment to deactivate the deblocking functionality
//#define BLOCKING // comment to deactivate the blocking functionality
//#define configWithPot // comment to deactivate config temporisation with potentiometer
#define SonorisationTiroirOuvert // comment to deactivate the sonorisation when the drawer stays open for a time
#ifdef DEBUG
#include <ArduinoJson.h> // version 6.18.4
long lastSendTime;
#define sendDelay 1300
#endif
#include <EEPROM.h>
#define EI_ARDUINO_INTERRUPTED_PIN
#include <EnableInterrupt.h> // version 1.1.0
#include <SchedTask.h>       // version 1.1.2
#define ConfigPin 6 // pin pour activé la configuration
#define timeOut 150 // timeout for ejection
#define indexT1EEprom 1
#define indexT2EEprom 3
#define indexT3EEprom 5
#define indexBlockCaisse 7         //indicate if blocked or not
#define indexBlockDelay 8          // the blocking delay
#define indexTypeCaisse 10         // the index of Type of the caisse in the eeprom
#define indexPasswordValidity 11   // indicats if the password is used or not
#define indexDeblockingPassword 12 // indicates the index of the first byte of the password
#define indexSonorisationTiroirOuvert 20// index to store the delay before checking if the drawer is opened is closed or not make a signale
unsigned long timestart;
//###################### Pins du clavier ####################
#define clavier1 7
#define clavier2 8
#define clavier3 9
#define potTempo A0 // pin pour le potentiomètre
#define LedR 12 // pin pour la LED Rouge
#define LedV 11 // pin pour la LED Verte
#define capTiroir1 A2 // capteur de fermeture pour le premier tiroir
#define capTiroir2 A3 // capteur de fermeture pour le deuxiéme tiroir
#define capTiroir3 A4 // capteur de fermeture pour le troisième  tiroir
#define Tiroir1 A5 // pin d'activation moteur tiroir 1
#define Tiroir2 2  // pin d'activation moteur tiroir 2
#define Tiroir3 3  // pin d'activation moteur tiroir 3 //
#ifdef BLOCKING
#define pinBlock A1 // pin pour bloqué la caisse
#endif
#define buzzerPin 5 // pin pour buzzuer de
#define serrureSwitch 10 // switch présence clé
#define pinRelay 4
#ifdef DEBUG
StaticJsonDocument<128> doc;
#endif
uint8_t bippingCount = 0; //value to indicate if the bipping in case of abscence of key and one of the drawers at least is already open
#define bippingTimes 50   // value of the bipping times
static unsigned long last_interrupt_time;
volatile byte lastPressedClavier = 0;                                                 //varible pour stocké la valeur du denier boutton présser
volatile bool config = false;                                                         // true mode config ,False mode noramle
unsigned long TempTiroir1, TempTiroir2, TempTiroir3;                                  // variables des valeurs de temporisation pour chaque tiroir
volatile bool Tiroir1Trigred = false, Tiroir2Trigred = false, Tiroir3Trigred = false; // flags pour les etats des tiroir
volatile bool typeCaisse;                                                             // this value will indicate the type of the caise if 0 without drawer sensor if 1 with drawer sensor
//##################### signature des fonctions#######################
void initPins();
void UpdateTempValue(uint16_t potValue, byte addr);
uint16_t readValue(byte addr);
void clavierPress();
void activationTiroir1();
void activationTiroir2();
void activationTiroir3();
void serrureTogle();
void activateDrawerDeblockage();
void T1CheckCallback();
void T2CheckCallback();
void T3CheckCallback();
#ifdef BLOCKING
void blockCaisse();
void endBlockCaisse();
#endif
#ifdef DEBLOCKING
   #define MAX_PASSWORD_LENGTH 6                                              // the max of the password
  String PasswordEntred = "";                                                // the string to handle the entred password
  SchedTask ejectTiroirDeblockage(NEVER, ONESHOT, activateDrawerDeblockage); // the task responsible for ejecting the drawers when the password matches
#endif
#ifdef  SonorisationTiroirOuvert
bool T1SonorisationIndicator= false;
bool T2SonorisationIndicator= false;
bool T3SonorisationIndicator= false;
#endif
//############# fin signature des Fonctions #################
//############# difinition des taches planifier #######################
  SchedTask T1TempCheck(NEVER, ONESHOT, T1CheckCallback); // (NEXT,PERIODE,FUNCTION)
  SchedTask T2TempCheck(NEVER, ONESHOT, T2CheckCallback);
  SchedTask T3TempCheck(NEVER, ONESHOT, T3CheckCallback);
#endif
SchedTask ejectTiroir1Task(NEVER, ONESHOT, activationTiroir1); // (NEXT,PERIODE,FUNCTION)
SchedTask ejectTiroir2Task(NEVER, ONESHOT, activationTiroir2);
SchedTask ejectTiroir3Task(NEVER, ONESHOT, activationTiroir3);
//################### fin déclaration des taches planifier #######################
#ifdef DEBUG
  Serial.begin(250000);
  lastSendTime = millis();
#endif
  typeCaisse = readValue(indexTypeCaisse); // read the type of the caisse
  initPins();
  enableInterrupt(serrureSwitch, serrureTogle, FALLING);
  enableInterrupt(clavier1, clavierPress, FALLING);
  enableInterrupt(clavier2, clavierPress, FALLING);
  enableInterrupt(clavier3, clavierPress, FALLING);
#ifdef BLOCKING
  enableInterrupt(pinBlock, blockCaisse, FALLING); // interuption pour bloqué la caisse
#endif
  last_interrupt_time = millis();
  //#################### partie de configuration ############################
#ifdef configWithPot
  while (!digitalRead(ConfigPin) & digitalRead(serrureSwitch))
#ifdef BLOCKING
    EEPROM.put(indexBlockCaisse, false); // pour desactiver le déblockage
#endif
    uint16_t potValue;
    config = true;
    switch (lastPressedClavier)
    case 1:
      do
        potValue = analogRead(potTempo);
      } while (lastPressedClavier != 1);
      UpdateTempValue(potValue, indexT1EEprom);
    case 2:
      do
      } while (lastPressedClavier != 2);
      UpdateTempValue(potValue, indexT2EEprom);
    case 3:
      do
      } while (lastPressedClavier != 3);
      UpdateTempValue(potValue, indexT3EEprom);
#endif
#ifdef BLOCKING
  if (readValue(indexBlockCaisse))
    blockCaisse(); //pour détecter si la caisse a été bloqué
#endif
  //####################### récupération des valeurs de temprisation ############
  TempTiroir1 = EEPROMReadInt(indexT1EEprom);
  TempTiroir2 = EEPROMReadInt(indexT2EEprom);
  TempTiroir3 = EEPROMReadInt(indexT3EEprom);
  SchedBase::dispatcher();
#ifdef DEBUG
  if (Serial.available() > 0)
    DeserializationError error = deserializeJson(doc, Serial);
    if (!error)
      handleRecievedData();
  if (millis() - lastSendTime > sendDelay)
    sendConfigData();
    Serial.println("");
#endif
  if (((digitalRead(capTiroir1) || digitalRead(capTiroir2) || digitalRead(capTiroir3)) && !digitalRead(serrureSwitch)) && typeCaisse)
    if (bippingCount < bippingTimes) //if the bipping didn't depassed the 255 bipping
      Buzzer(100, 1);
      bippingCount++;
ActionFunctions.ino this tab conatins the methods to activate motors
void activationTiroir1() // this method activate the first motor
  if (Tiroir1Trigred && digitalRead(serrureSwitch))
    timestart = millis();
    digitalWrite(Tiroir1, 0);
    digitalWrite(buzzerPin, 1);
     do
    } while ((millis() - timestart) < 300) ; //testing on the time out
    digitalWrite(Tiroir1, 1);
    digitalWrite(buzzerPin, 0);
    Tiroir1Trigred = false;
    delay(300);//wait before Testing
    if (!digitalRead(capTiroir1) && typeCaisse) Buzzer(50, 10);
void activationTiroir2() // this method activate the second motor
  if (Tiroir2Trigred && digitalRead(serrureSwitch))
    digitalWrite(Tiroir2, 0);   //activation verin
    digitalWrite(buzzerPin, 1); // activation buzzer
    do
      if(digitalRead(capTiroir2) && typeCaisse)break;
    } while ((millis() - timestart) < 400) ; // tantque le capteur n'est pas ouver et le time out n'est pas ateint
    digitalWrite(Tiroir2, 1);                                                               // désactivation verin
    digitalWrite(buzzerPin, 0);                                                             //désactivation BUZZER
    Tiroir2Trigred = false;
    if (!digitalRead(capTiroir2) && typeCaisse)  Buzzer(50, 10); // if the drawer is not activated make some sound
void activationTiroir3() // this method activate the third motor
  if (Tiroir3Trigred && digitalRead(serrureSwitch))
    digitalWrite(Tiroir3, 0);
    do
      if(digitalRead(capTiroir3) && typeCaisse)break;
    } while ((millis() - timestart) < 500) ;
    digitalWrite(Tiroir3, 1);
    delay(300);//wait before testing
    if (!digitalRead(capTiroir3) && typeCaisse) Buzzer(50, 10);
void Buzzer(int periode, int times) // activation du buzzer avec une faréquance
  for (int i = 0; i < times; i++)
    delay(periode);
    delay(periode);
#ifdef DEBLOCKING
void activateDrawerDeblockage()// this method will be called by ejectTiroirDeblockage task to eject the drawer
      do
      } while ((!digitalRead(capTiroir1) && typeCaisse) || (millis() - timestart) <= timeOut); //if typeCaisse=0 (!digitalRead(capTiroir1)&typeCaisse)will always 0 so we will be testing only on timeout
    do
    } while ((!digitalRead(capTiroir2) && typeCaisse) || (millis() - timestart) <= timeOut); //if typeCaisse=0 (!digitalRead(capTiroir1)&typeCaisse)will always 0 so we will be testing only on timeout
    do
    } while ((!digitalRead(capTiroir3) && typeCaisse) || (millis() - timestart) <= timeOut); //if typeCaisse=0 (!digitalRead(capTiroir1)&typeCaisse)will always 0 so we will be testing only on timeout
#endif
// this method is called by the Tiroir1TemporisationCheck task to check if the drawer is stil opened to start the buzzer
     if(digitalRead(capTiroir1))
        T1SonorisationIndicator=true;
        T1TempCheck.setNext(50);
        if(!(T2SonorisationIndicator&T3SonorisationIndicator))
          digitalWrite(buzzerPin, !digitalRead(buzzerPin));
      else {
        T1TempCheck.setNext(NEVER);
        T1SonorisationIndicator=false;
   if(digitalRead(capTiroir2))
        T2SonorisationIndicator=true;
        T2TempCheck.setNext(50);
        if(!(T1SonorisationIndicator&T3SonorisationIndicator))
      else {
        T2TempCheck.setNext(NEVER);
        T2SonorisationIndicator=false;
   if(digitalRead(capTiroir3))
        T3SonorisationIndicator=false;
        T3TempCheck.setNext(50);
        if(!(T1SonorisationIndicator&T2SonorisationIndicator))
      else {
        T3TempCheck.setNext(NEVER);
 #endif
DEBUG.ino
#ifdef DEBUG
void handleRecievedData() {
  if (doc.containsKey("GC")) sendConfigData();
  else if (doc.containsKey("SB")) setBlockTime();
  else if (doc.containsKey("SDT"))  setDrawerteporisation();
  else if (doc.containsKey("AD"))  ActivateDrawer();
  else if (doc.containsKey("SCT")) SetCaisseType();
  #ifdef DEBLOCKING
  else if (doc.containsKey("SETPSWD")) changePassword();
  else if (doc.containsKey("GETPSWD")) GetPassword();
  #endif
      else if (doc.containsKey("SST")) setSenorisationTime();// set sonorisation time
  #endif
void sendConfigData()// this method sen the config data to the board
  doc.clear();
  JsonArray DS = doc.createNestedArray("DS"); //drawerSensors
  DS.add(digitalRead(capTiroir1));
  DS.add(digitalRead(capTiroir2));
  DS.add(digitalRead(capTiroir3));
  JsonArray DT = doc.createNestedArray("DT");
  DT.add(TempTiroir1);
  DT.add(TempTiroir2);
  DT.add(TempTiroir3);
  doc["SS"] = digitalRead(serrureSwitch);
  doc["BT"] =  EEPROMReadInt(indexBlockDelay);
  doc["SCT"] = typeCaisse;
void setBlockTime()// this function write the blocking time
  EEPROMWriteInt(indexBlockDelay, doc["SB"].as<int>());
  Buzzer(500, 1);
  return;
void setDrawerteporisation()//write drawers temp values
  JsonObject SDT = doc["SDT"];
  if (SDT.containsKey("1")) {
    EEPROMWriteInt(indexT1EEprom, SDT["1"].as<int>());
    doc.clear();
    doc["SDT"] = 1;
    Buzzer(500, 1);
    return;
  if (SDT.containsKey("2"))
    EEPROMWriteInt(indexT2EEprom, SDT["2"].as<int>());
    doc.clear();
    doc["SDT"] = 2;
    Buzzer(500, 1);
    return;
  if (SDT.containsKey("3")) {
    EEPROMWriteInt(indexT3EEprom, SDT["3"].as<int>());
    doc.clear();
    doc["SDT"] = 3;
    Buzzer(500, 1);
    return;
void ActivateDrawer() {
  int index = doc["AD"].as<int>();
  switch (index) {
    case 1 :
      do
    case 2:
    do
    case 3:
    do
  return;
void SetCaisseType()// this function write the type of the caisse 0 without sensor, 1 with sensors
  EEPROM.update(indexTypeCaisse, doc["SCT"].as<bool>());
  Buzzer(500, 1);
  return;
#ifdef DEBLOCKING
void changePassword()
  char* password = doc["SETPSWD"];
  writePassword(password);
  EEPROM.update(indexPasswordValidity, true);// set the password validity indicator to true
void GetPassword(){
  doc.clear();
  JsonObject GETPSWD = doc.createNestedObject("GETPSWD");
  GETPSWD["PSWD"] = readPassword();
  GETPSWD["valid"] = readValue(indexPasswordValidity);
#endif
#endif
    void setSenorisationTime()// set sonorisation time
  #endif
EEPROM.ino// this tab for writing/reading values in the EEprom
void UpdateTempValue(uint16_t potValue, byte addr)// écrire la valeur de temp
  if(potValue<256)EEPROMWriteInt(addr, indexT1EEprom);
  else if (potValue<512) EEPROMWriteInt(addr, indexT2EEprom);
  else if(potValue<768)EEPROMWriteInt(addr, indexT3EEprom);
  else EEPROMWriteInt(addr, 180);
uint16_t readValue(byte addr)// read a simple value
   return EEPROM.read(addr);
void EEPROMWriteInt(int address, int value)// write long Value
  byte two = (value & 0xFF);
  byte one = ((value >> 8) & 0xFF);
  EEPROM.update(address, two);
  EEPROM.update(address + 1, one);
unsigned long EEPROMReadInt(int address)// read long value
  long two = EEPROM.read(address);
  long one = EEPROM.read(address + 1);
  return ((two << 0) & 0xFFFFFF) + ((one << 8) & 0xFFFFFFFF);
#ifdef DEBLOCKING
String readPassword(){// this method read each bute of the password and make the string password and return it
  char data[MAX_PASSWORD_LENGTH + 1];
  for (int i = 0; i < MAX_PASSWORD_LENGTH; i++)
    data[i] = EEPROM.read(indexDeblockingPassword + i);
  data[MAX_PASSWORD_LENGTH] = '\0';
  return String(data);
void writePassword(char* password)// this method split the password and save aeach character(byte) individually
    EEPROM.write(indexDeblockingPassword + i, password[i]);
#endif
INIT.ino// tab for initialising pins and timer
void initPins()
  pinMode(Tiroir1,INPUT_PULLUP);
  pinMode(Tiroir2,INPUT_PULLUP);
  pinMode(Tiroir3,INPUT_PULLUP);
  pinMode(Tiroir1,OUTPUT);
  pinMode(Tiroir2,OUTPUT);
  pinMode(Tiroir3,OUTPUT);
  digitalWrite(Tiroir1,1);
  pinMode(ConfigPin, INPUT_PULLUP);
  pinMode(clavier1,INPUT_PULLUP);
  pinMode(clavier2, INPUT_PULLUP);
  pinMode(clavier3,INPUT_PULLUP);
  pinMode(potTempo,INPUT);
  pinMode(LedR, OUTPUT);
  pinMode(LedV,OUTPUT);
  pinMode(capTiroir1, INPUT_PULLUP);
  pinMode(capTiroir2, INPUT_PULLUP);
  pinMode(capTiroir3, INPUT_PULLUP);
  pinMode(buzzerPin, OUTPUT);
  pinMode(serrureSwitch,INPUT_PULLUP);
  pinMode(pinRelay,OUTPUT);
  setupTimer();
  #ifdef BLOCKNG
    pinMode(pinBlock, INPUT_PULLUP);
  #endif
void setupTimer()
  cli();
  TCCR1A = 0;// set entire TCCR1A register to 0
  TCCR1B = 0;// same for TCCR1B
  TCNT1  = 0;//initialize counter value to 0
  // set compare match register for 1hz increments
  OCR1A = 15624;// = (16*10^6) / (1*1024) - 1 (must be <65536)
  // turn on CTC mode
  TCCR1B |= (1 << WGM12);
  // Set CS12 and CS10 bits for 1024 prescaler
  TCCR1B |= (1 << CS12) | (1 << CS10);
  // enable timer compare interrupt
  TIMSK1 |= (1 << OCIE1A);
  sei();
Interruption.ino// tabs for methods that hundeling interruptions
void clavierPress() {
  if ((millis() - last_interrupt_time) > 400) {
    if (digitalRead(serrureSwitch)) {// the key is present
      if (config) {
        switch (arduinoInterruptedPin) {
          case clavier1:
            lastPressedClavier = 1;
          case clavier2:
            lastPressedClavier = 2;
          case clavier3:
            lastPressedClavier = 3;
        digitalWrite(LedV, 0);
          case clavier1:
            if ((!Tiroir1Trigred && !digitalRead(capTiroir1)&& typeCaisse)||(!Tiroir1Trigred && !typeCaisse))
              ejectTiroir1Task.setNext(TempTiroir1*1000);
              Tiroir1Trigred = true;
                T1TempCheck.setNext(5000);
              #endif
          case clavier2:
            if ((!Tiroir2Trigred && !digitalRead(capTiroir2)&& typeCaisse)||(!Tiroir2Trigred && !typeCaisse)) {
              ejectTiroir2Task.setNext(1000 * TempTiroir2);
              Tiroir2Trigred = true;
                T2TempCheck.setNext(5000);
              #endif
          case clavier3:
            if ((!Tiroir3Trigred && !digitalRead(capTiroir3)&& typeCaisse)||(!Tiroir3Trigred && !typeCaisse)) {
              ejectTiroir3Task.setNext(1000*TempTiroir3);
              Tiroir3Trigred = true;
                T3TempCheck.setNext(5000);
              #endif
  #ifdef DEBUG
        doc.clear();
          case clavier1:
            doc["keypad"] = 1;
          case clavier2:
            doc["keypad"] = 2;
          case clavier3:
            doc["keypad"] = 3;
  #endif
  #ifdef DEBLOCKING
  // if the case key is not present we will handle the password
  else if (readValue(indexPasswordValidity))// testing if the password is used or not
    switch (arduinoInterruptedPin) {// append the pressed key to the password String
          case clavier1:
            PasswordEntred+='1';
          case clavier2:
            PasswordEntred+='2';
          case clavier3:
            PasswordEntred+='3';
        // make al little bip for better user experience
        delay(250);
        if(PasswordEntred.length()==6)
          if(PasswordEntred==readPassword()){// the password matches
            ejectTiroirDeblockage.setNext(1000);//we schedule the drawers to be ejected after 1 second
            EEPROM.update(indexPasswordValidity, false); // set the password indicator to false
            PasswordEntred="";
              PasswordEntred="";
  #endif
  return;
void serrureTogle() // fonction pour changer l'état si la clé est insérée ou retirée
  if ((millis() - last_interrupt_time) > 200) {
      bippingCount = 0;// reset the bipping counts
return;
ISR(TIMER1_COMPA_vect) {
  if (!(Tiroir1Trigred || Tiroir2Trigred || Tiroir3Trigred)) {
      digitalWrite(LedV, !digitalRead(LedV));
      digitalWrite(LedR, 1);
      digitalWrite(LedR, !digitalRead(LedR));
      digitalWrite(LedV, 1);
#ifdef BLOCKING
  void blockCaisse()// method for blocking time
  blockCaisseTask.setNext(EEPROMReadInt(indexBlockDelay) * 1000);
  digitalWrite(pinRelay,HIGH);
  EEPROM.put(indexBlockCaisse, true);
  disableInterrupt(clavier1);
  disableInterrupt(clavier2);
  disableInterrupt(clavier3);
  disableInterrupt(serrureSwitch);
  return;
  digitalWrite(pinRelay,LOW);
  enableInterrupt(serrureSwitch, serrureTogle, CHANGE);
  Buzzer(50, 5);
  return;
#endif
Why not print out the value of millis() and/or of millis()- timestart in that do..while to see what millis() is doing?
Side note: I'm confused by the switch..case on lastPressedClavier in setup(). You just initialised lastPressedClavier to 0, and as far as I can see it doesn't change before the switch..case so it can never match the cases of 1, 2 or 3. And it's just as well, since if it did ever go into the switch..case as 1, 2 or 3 it will never get out of the do..while. You would be setting lastPressedClavier back to 0, which is always != 1, 2 or 3 so those whiles will always be true. (I think... that code made my eyes hurt :wink: )
Which would happen a bit more then 1 time in 30 days.
Why not print out the values of the math to see what is actually happening and use some serial.prints to see where the thing is getting stuck.
Millis rollover takes a little over 49 days to occur, so I seriously doubt that is the source of the problem. I would even doubt the actual do..while pointed out by the OP is where the problem occurs. It would be good to know how the OP has determined that the problem lies with that bit of code.
Goes with my suggestion that the OP can use a few prints statements in his code as proofs of issue.
In reference to that, make sure to put Serial.flush() after every output to serial, otherwise you will never see what is left in the serial buffer if something like a processor reset occurs.
Do not have time to read over the code carefully, but it does appear there is a delay() in the clavierPress ISR - that will cause big problems.
