Hello, I have 2-Two separate codes and I am having difficulty combining them. Maybe someone could pinpoit me into a right direction. General idea is to control 4-Nema 17 Stepper Motors and 1-Servo using Arduino Uno+CNC Shield, etc. Both arduino codes and processing codes work individually. Already tested. Hardware is no issue either.
1st Arduino Code (4 Steppers):
#include <AccelStepper.h>
#include <Servo.h>
#include <math.h>
// Define the stepper motors and the pins the will use
AccelStepper stepper1(1, 2, 5); // (Type:driver, STEP, DIR)
AccelStepper stepper2(1, 3, 6);
AccelStepper stepper3(1, 4, 7);
AccelStepper stepper4(1, 12, 13);
double x = 10.0;
double y = 10.0;
double L1 = 228; // L1 = 228mm
double L2 = 136.5; // L2 = 136.5mm
double theta1, theta2, phi, z;
int stepper1Position, stepper2Position, stepper3Position, stepper4Position;
const float theta1AngleToSteps = 44.444444;
const float theta2AngleToSteps = 35.555555;
const float phiAngleToSteps = 10;
const float zDistanceToSteps = 100;
byte inputValue[5];
int k = 0;
String content = "";
int data[10];
int theta1Array[100];
int theta2Array[100];
int phiArray[100];
int zArray[100];
int positionsCounter = 0;
// Stepper motors max speed
stepper1.setMaxSpeed(4000);
stepper1.setAcceleration(2000);
stepper2.setMaxSpeed(4000);
stepper2.setAcceleration(2000);
stepper3.setMaxSpeed(4000);
stepper3.setAcceleration(2000);
stepper4.setMaxSpeed(4000);
stepper4.setAcceleration(2000);
data[5] = 0;
static int v = 0;
if (Serial.available()) {
content = Serial.readString(); // Read the incomding data from Processing
// Extract the data from the string and put into separate integer variables (data[] array)
for (int i = 0; i < 10; i++) {
int index = content.indexOf(","); // locate the first ","
data[i] = atol(content.substring(0, index).c_str()); //Extract the number from start to the ","
content = content.substring(index + 1); //Remove the number from the string
stepper1Position = data[2] * theta1AngleToSteps;
stepper2Position = data[3] * theta2AngleToSteps;
stepper3Position = data[4] * phiAngleToSteps;
stepper4Position = data[5] * zDistanceToSteps;
stepper1.setSpeed(data[7]);
stepper2.setSpeed(data[7]);
stepper3.setSpeed(data[7]);
stepper4.setSpeed(data[7]);
stepper1.setAcceleration(data[8]);
stepper2.setAcceleration(data[8]);
stepper3.setAcceleration(data[8]);
stepper4.setAcceleration(data[8]);
stepper1.moveTo(stepper1Position);
stepper2.moveTo(stepper2Position);
stepper3.moveTo(stepper3Position);
stepper4.moveTo(stepper4Position);
while (stepper1.currentPosition() != stepper1Position || stepper2.currentPosition() != stepper2Position || stepper3.currentPosition() != stepper3Position || stepper4.currentPosition() != stepper4Position)
stepper1.run();
stepper2.run();
stepper3.run();
stepper4.run();
void serialFlush() {
while (Serial.available() > 0) { //while there are characters in the serial buffer, because Serial.available is >0
Serial.read(); // get one character
data[2] - Joint 1 angle
data[3] - Joint 2 angle
data[4] - Joint 3 angle
data[5] - Z position
data[7] - Speed value
data[8] - Acceleration value
1st Processing Code (4 Steppers):
//Processing Code:
import processing.serial.*;
import controlP5.*;
import static processing.core.PApplet.*;
Serial myPort;
ControlP5 cp5; // controlP5 object
int j1Slider = 0;
int j2Slider = 0;
int j3Slider = 0;
int zSlider = 0;
int j1JogValue = 0;
int j2JogValue = 0;
int j3JogValue = 0;
int zJogValue = 0;
int speedSlider = 500;
int accelerationSlider = 500;
int saveStatus = 0;
int runStatus = 0;
int slider1Previous = 0;
int slider2Previous = 0;
int slider3Previous = 0;
int sliderzPrevious = 100;
int speedSliderPrevious = 500;
int accelerationSliderPrevious = 500;
boolean activeIK = false;
int xP=0;
int yP=0;
int zP=0;
float L1 = 228; // L1 = 228mm
float L2 = 136.5; // L2 = 136.5mm
float theta1, theta2, phi, z;
String[] positions = new String[100];
String data;
size(900, 900);
myPort = new Serial(this, "COM6", 115200);
cp5 = new ControlP5(this);
PFont pfont = createFont("Arial", 25, true); // use true/false for smooth/no-smooth
ControlFont font = new ControlFont(pfont, 22);
ControlFont font2 = new ControlFont(pfont, 25);
//J1 controls
cp5.addSlider("j1Slider")
.setPosition(80, 222)
.setSize(270, 30)
.setRange(-90, 266) // Slider range, corresponds to Joint 1 or theta1 angle that the robot can move to
.setColorLabel(#3269c2)
.setFont(font)
.setCaptionLabel("")
cp5.addButton("j1JogMinus")
.setPosition(80, 275)
.setSize(90, 40)
.setFont(font)
.setCaptionLabel("JOG-")
cp5.addButton("j1JogPlus")
.setPosition(260, 275)
.setSize(90, 40)
.setFont(font)
.setCaptionLabel("JOG+")
cp5.addNumberbox("j1JogValue")
.setPosition(190, 275)
.setSize(50, 30)
.setRange(0, 20)
.setFont(font)
.setMultiplier(0.1)
.setValue(1)
.setDirection(Controller.HORIZONTAL) // change the control direction to left/right
//J2 controls
cp5.addSlider("j2Slider")
.setPosition(80, 400)
.setSize(270, 30)
.setRange(-150, 150)
.setFont(font)
cp5.addButton("j2JogMinus")
.setPosition(80, 450)
.setSize(90, 40)
.setFont(font)
cp5.addButton("j2JogPlus")
.setPosition(260, 450)
.setSize(90, 40)
.setFont(font)
cp5.addNumberbox("j2JogValue")
.setPosition(190, 450)
.setSize(50, 30)
.setRange(0, 20)
.setFont(font)
.setMultiplier(0.1)
.setValue(1)
//J3 controls
cp5.addSlider("j3Slider")
.setPosition(80, 575)
.setSize(270, 30)
.setRange(-162, 162)
.setFont(font)
cp5.addButton("j3JogMinus")
.setPosition(80, 625)
.setSize(90, 40)
.setFont(font)
cp5.addButton("j3JogPlus")
.setPosition(260, 625)
.setSize(90, 40)
.setFont(font)
cp5.addNumberbox("j3JogValue")
.setPosition(190, 625)
.setSize(50, 30)
.setRange(0, 20)
.setFont(font)
.setMultiplier(0.1)
.setValue(1)
//Z controls
cp5.addSlider("zSlider")
.setPosition(80, 750)
.setSize(270, 30)
.setFont(font)
cp5.addButton("zJogMinus")
.setPosition(80, 800)
.setSize(90, 40)
.setFont(font)
cp5.addButton("zJogPlus")
.setPosition(260, 800)
.setSize(90, 40)
.setFont(font)
cp5.addNumberbox("zJogValue")
.setPosition(190, 800)
.setSize(50, 30)
.setRange(0, 20)
.setFont(font)
.setMultiplier(0.1)
.setValue(1)
cp5.addTextfield("xTextfield")
.setPosition(460, 340)
.setSize(70, 40)
.setFont(font)
.setColor(255)
cp5.addTextfield("yTextfield")
.setPosition(610, 340)
.setSize(70, 40)
.setFont(font)
.setColor(255)
cp5.addTextfield("zTextfield")
.setPosition(760, 340)
.setSize(70, 40)
.setFont(font)
.setColor(255)
//Z controls
cp5.addSlider("speedSlider")
.setPosition(450, 550)
.setSize(180, 30)
.setRange(500, 4000)
.setFont(font)
cp5.addSlider("accelerationSlider")
.setPosition(675, 550)
.setSize(180, 30)
.setFont(font)
//Servo Slider
cp5.addSlider("Tilt")
.setPosition(500,200)
.setSize(300,30)
.setRange(-180,180)
.setValue(0)
void draw() {
background(#F2F2F2); // background black
textSize(35);
fill(33);
text("Stepper Control", 85, 150);
text("Servo Control", 550, 150);
text("Location", 580, 320);
text("Speed Control", 540, 490);
textSize(40);
text("USER INTERFACE", 330, 60);
textSize(22);
text("Stepper #1 (Base-Axis)", 60, 210);
text("Stepper #2 (Arm-Axis)", 60, 385);
text("Stepper #3 (Gripper Axis)", 60, 560);
text("Stepper #4 (Z-Axis)", 60, 735);
textSize(22);
text("Velocity", 500, 535);
text("Acceleration", 700, 535);
//println("PREV: "+accelerationSlider);
fill(speedSlider);
fill(accelerationSlider);
fill(j1Slider);
fill(j2Slider);
fill(j3Slider);
fill(zSlider);
fill(j1JogValue);
fill(j2JogValue);
fill(j3JogValue);
fill(zJogValue);
updateData();
saveStatus=0; // keep savePosition variable 0 or false. See, when button SAVE pressed it makes the value 1, which indicates to store the value in the arduino code
// If slider moved, calculate new position of X,Y and Z with forward kinematics
if (slider1Previous != j1Slider) {
if (activeIK == false) { // Check whether the inverseKinematics mode is active, Executre Forward kinematics only if inverseKinematics mode is off or false
theta1 = round(cp5.getController("j1Slider").getValue()); // get the value from the slider1
theta2 = round(cp5.getController("j2Slider").getValue());
forwardKinematics();
myPort.write(data);
slider1Previous = j1Slider;
if (slider2Previous != j2Slider) {
myPort.write(data);
slider2Previous = j2Slider;
if (slider3Previous != j3Slider) {
myPort.write(data);
slider3Previous = j3Slider;
if (sliderzPrevious != zSlider) {
zP = round(cp5.getController("zSlider").getValue());
updateData();
println(data);
myPort.write(data);
sliderzPrevious = zSlider;
activeIK = false; // deactivate inverseKinematics so the above if statements can be executed the next interation
fill(33);
textSize(32);
text("X: ", 460, 420);
text(xP, 513, 420);
text("Y: ", 610, 420);
text(yP, 665, 420);
text("Z: ", 760, 420);
text(zP, 815, 420);
textSize(26);
textSize(18);
} //END VOID DRAW
// FORWARD KINEMATICS
void forwardKinematics() {
float theta1F = theta1 * PI / 180; // degrees to radians
float theta2F = theta2 * PI / 180;
xP = round(L1 * cos(theta1F) + L2 * cos(theta1F + theta2F));
yP = round(L1 * sin(theta1F) + L2 * sin(theta1F + theta2F));
void controlEvent(ControlEvent theEvent) {
if (theEvent.isController()) {
println(theEvent.getController().getName());
public void j1JogMinus() {
int a = round(cp5.getController("j1Slider").getValue());
a=a-j1JogValue;
cp5.getController("j1Slider").setValue(a);
//J1 control
public void j1JogPlus() {
a=a+j1JogValue;
//J2 control
public void j2JogMinus() {
int a = round(cp5.getController("j2Slider").getValue());
a=a-j2JogValue;
cp5.getController("j2Slider").setValue(a);
public void j2JogPlus() {
a=a+j2JogValue;
//J3 control
public void j3JogMinus() {
int a = round(cp5.getController("j3Slider").getValue());
a=a-j3JogValue;
cp5.getController("j3Slider").setValue(a);
public void j3JogPlus() {
a=a+j3JogValue;
//J3 control
public void zJogMinus() {
int a = round(cp5.getController("zSlider").getValue());
a=a-zJogValue;
cp5.getController("zSlider").setValue(a);
public void zJogPlus() {
a=a+zJogValue;
public void updateData() {
data = str(saveStatus)
+","+str(runStatus)
+","+str(round(cp5.getController("j1Slider").getValue()))
+","+str(round(cp5.getController("j2Slider").getValue()))
+","+str(round(cp5.getController("j3Slider").getValue()))
+","+str(round(cp5.getController("zSlider").getValue()))
+","+str(speedSlider)
+","+str(accelerationSlider);
2nd Arduino Code (Servo):
#include <Servo.h>
Servo servo1;
servo1.attach(A0); //The Tilt servo is attached to pin 9.
Serial.begin(115200); //Set up a serial connection for 57600 bps.
Serial.println("Ready");
static int v = 0;
if (Serial.available()){
char ch = Serial.read();
switch (ch) {
case '0'...'9':
v = v * 10 + ch - '0';
case 'a':
servo1.write(v);
Serial.println(v);
v = 0;
break; }
2nd Processing Code (Servo):
//Processing code:
import controlP5.*;
ControlP5 cp5;
int tilt = 1;
Serial myPort;
size(500, 250);
cp5.addSlider("pan")
.setPosition(50,70)
.setSize(300,30)
.setRange(0,180)
.setValue(158)
cp5.addSlider("tilt")
.setPosition(50,130)
.setSize(300,30)
.setRange(0,180)
.setValue(158)
void draw() {
myPort.write("a"+tilt);
