help convert String to unsigned char
I'm becoming crazy
I'm reading from an SD card a config file and than apply it.
this is the problem:
unsigned char G_addr[10][8]; //qui memorizzo fino a 10 indirizzi da 8 bytes (64bit)
 void applySetting(String settingName, String settingValue ) {
 if(settingName == "number_of_key") {
 number_of_key=settingValue.toInt();
 if(settingName == "key1") {
 G_addr [1] = settingValue;      <--------- THIS IS THE PROBLEM
I've try to use the following codes
 strcpy((char*)settingValue.c_str(), G_addr[1]);
 strncpy (settingValue.c_str (), G_addr[1]);
the code to fill G_addr use the following code
    byte address[8]; // questo array conterrà l'indirizzo locale delle chiavi
    for(int aa=0;aa<8;aa++) G_addr[G_Devices][aa]=address[aa]; // copy address
please help me !
Thanks a lot
Daniele
What are you actually trying to do? You're passing in a String named settingValue and then doing a weird assignment:
What is the index of [1] supposed to do, and why are you directly assigning a String into a single element of an unsigned char array?
thank you for your answer.
I've got G_addr ( it is unsigned char ) ( see attached file )
unsigned char G_addr[10][8]; //to store 10 address 8 bytes
now I'm reading from SD card a config file saved inside ( file is config.cfg )
the structure of this file is
number_of_key=3
key1=1234567890
key2=2345678901
key3=3456789012
now reading from this file I cant load in memory the G_addr value stored in SD card
ibutton_v3.ino (10.9 KB)
This will not work. G_addr[1] is a memory adress that the compiler knows about - the adress of that second element of your array. It''s ot a thing you can change.
What you probably want to so is to change the memory at that location.
Another issue is that I don't know if the strings in that array are nul-terminated. I'm guessing they aren't - you have to rely on knowing the size.
  memcpy(&G_addr[1], settingValue, sizeof(G_addr[1]));
Of course, &G_addr[1] is the same as G_addr+1, but perhaps more explicit.
The simplest solution is to quit using String anywhere in your code. There is NOTHING that the String class can do that can not be done with string functions applied to NULL terminated arrays of chars.
I've try to change G_Addr from unsigned char to String but there were new problem
look this
String G_addr[10][8]; //store 10 index da 8 bytes (64bit)
byte G_Devices; // number of key in the bus
OneWire ow(1); // inizializza il bus onewire sulla porta n°8 (se avete collegato i sensori su un'altro pin dovete modificare qui)
but this is the problem
   for (int i=0;i<G_Devices;i++) if(CheckAddress(G_addr[i],address)) {old=true;break;} // se trovo l'indirizzo imposto old a true ed esco dal for
this is the error
ibutton_v3.ino: In function 'void lookUpKeys()':
ibutton_v3:140: error: cannot convert 'String*' to 'unsigned char*' for argument '1' to 'bool CheckAddress(unsigned char*, unsigned char*)'
ibutton_v3:148: error: invalid conversion from 'byte' to 'const char*'
ibutton_v3:148: error: initializing argument 1 of 'String& String::operator=(const char*)'
ibutton_v3.ino: In function 'void applySetting(String, String, char)':
ibutton_v3:473: error: incompatible types in assignment of 'char' to 'String [8]'
ibutton_v3:476: error: incompatible types in assignment of 'String' to 'String [8]'
ibutton_v3:477: error: 'exBoolean' was not declared in this scope
ibutton_v3:480: error: incompatible types in assignment of 'String' to 'String [8]'
ibutton_v3:481: error: 'exLong' was not declared in this scope
tryng this
 void applySetting(String settingName, String settingValue , char addr) {
   memcpy(&G_addr[1], settingValue, sizeof(8));
// G_addr [1] = addr;
this is the error
ibutton_v3:473: error: cannot convert 'String' to 'const void*' for argument '2' to 'void* memcpy(void*, const void*, size_t)'
ibutton_v3:474: error: incompatible types in assignment of 'char' to 'unsigned char [8]'
ibutton_v3:477: error: incompatible types in assignment of 'String' to 'unsigned char [8]'
ibutton_v3:478: error: 'exBoolean' was not declared in this scope
ibutton_v3:481: error: incompatible types in assignment of 'String' to 'unsigned char [8]'
ibutton_v3:482: error: 'exLong' was not declared in this scope
That is NOT going in the right direction. Banish the stupid String class from your memory. Forget that it exists for the sole purpose of wasting memory.
Learn to use strings.
PaulS thank you for your answer
so I'm looking to cicling store in temp [1] unsigned char the character reader
 void readSDSettings(){
 char character;
 String settingName;
 String settingValue;
 unsigned char temp [1][8];
 myFile = SD.open("settings.txt");
 if (myFile) {
 while (myFile.available()) {
 character = myFile.read();
 while((myFile.available()) && (character != '[')){
 while((myFile.available()) && (character != '=')){
 settingName = settingName + character;
 while((myFile.available()) && (character != ']')){
       for(int aa=0;aa<8;aa++) temp[1][aa]=character[aa]; // copia l'indirizzo
//   settingValue = settingValue + character;
so if I wanto so store inside temp the character i should cicle the reading
but this is the error
please help me before I become crazy
ibutton_v3.ino: In function 'void readSDSettings()':
ibutton_v3:434: error: invalid types 'char[int]' for array subscript
ibutton_v3.ino: In function 'void applySetting(String, String)':
ibutton_v3:480: error: incompatible types in assignment of 'String' to 'unsigned char [8]'
ibutton_v3:481: error: 'exBoolean' was not declared in this scope
ibutton_v3:484: error: incompatible types in assignment of 'String' to 'unsigned char [8]'
ibutton_v3:485: error: 'exLong' was not declared in this scope
This unsigned char temp [1][8];
worries me
Explain please.
in declaration of variable I've got a unsigned char called temp [numbero of this variable ] [lenght of this variable]
I want to read from line 1 of the sd card config file the value and copy it inside the first[1] temp variable
thank you for your help
But why have a 1 x 8 array?
What is wrong with a simple 8 element vector?
I don't understand your reasoning.
I've thinked the config file in this way
number_of key=10
key1=1234567890
key2=2345678890
ecc
ecc
ecc
so if you see my sketch you can see that the first function was reading the key if never readed)
void lookUpKeys()
while (ow.search(address)) // loop finchè trova nuovi dispositivi
 if (address[0] == 0x01) // identificata chiave 1-wire
  if(CheckSensor(address)==1) //se il crc ok la lettura è corretta
   bool old=false;
   if(!old) // se la chiave non è ancora stata usata....
    for(int aa=0;aa<8;aa++) G_addr[G_Devices][aa]=address[aa]; // copia l'indirizzo
    G_Devices++; // incrementa il numero di devices memorizzati
    lcd.setCursor(0, 0);
    PrintAddress(address); // stampo l'indirizzo della chiave
  digitalWrite(17, HIGH);   // accende il led sulla porta 13
  delay(500);               // aspetta un po'...
  digitalWrite(17, LOW);    //..e spegne di nuovo il led sulla porta 13
        relayState = !relayState;
        digitalWrite(9, relayState);
        system = relayState;
so now I want to configure the kay by sd card so I think:
this was the way that the original code use to store G-addr
I think so
read the value from SD card and copy inside G_addr
so G_addr is lenght 8
and max 10 G_addr
so I think that if I want to copy key1 inside the first G_addr I shoud use
G_addr[1] = key1 ( from sd card file )
ibutton.ino (8.66 KB)
I simple would like to load the ten key from SD config file stored in sd card
to do this I must read the number of the kay ( why use 10 kay if I want only 4 kays ? )
and than the address of key
    fname.toCharArray(temp,8); // Convert the string to a character array
    //G_addr[1][8] = temp;
    for(int aa=0;aa<8;aa++) G_addr[G_Devices][aa]=temp[aa]; // copia l'indirizzo
now compile withour error but I don't know if this could works
So, you need an array that is 10 by 8, not 1 by 8.
The snippet does NOT compile without error for me.
Ok so I need an array 10 by 8
Better if G_addr[number_of_key][8]
So in this case I can use less than 10 kay if I want
But now I've a problem
Reading each line when I found the carriege return I must write the new key in G_addr[number_of_key+1] right ?
I can think this but I can't do in C code. I think it's stupid but I can't. Please help me more.
Thank you
PaulS please correct me I rewrite the function. I think now I'm nearest than before but you help me more !
 void read_file_contents(String fname)
    // This function opens the config.dat file on the SD card, reads the contents of the file and displays
    // the contents on the serial terminal.
    // Declare variables
    lcd.clear();
    char temp[100]; // Since the SD functions expect a character array and not a string we have to temporarily store the string in a character array.
    fname.toCharArray(temp,100); // Convert the string to a character array
    lcd.println("Reading config File");
    delay (1200);
    config_file = SD.open(temp); // Open the configuration file
    if (config_file)
      lcd.println("Reading command file");
      while (config_file.available()) // While the file is available read the contents
        number_of_key = config_file.readStringUntil('\n'); // Read the first line where stored number of key ( so the number of cycle for)
        G_Devices = number_of_key;
        for ( int cycle = 0; cycle<number_of_key ; cycle++)
            address = config_file.readStringUntil('\n'); // Read the passphrase
            G_addr[G_Devices][aa]=address[aa]; // store the reading inside G_addr
    // Display the information that we read from the file
  //  Serial.print("SSID = ");
  //  Serial.println(ssid);
  //  Serial.print("Passphrase = ");
  //  Serial.println(passphrase);
    config_file.close();  // Close the file.
the error is
ibutton.ino: In function 'void read_file_contents(String)':
ibutton:468: error: cannot convert 'String' to 'int' in assignment
ibutton:474: error: 'address' was not declared in this scope
ibutton:475: error: 'aa' was not declared in this scope
ibutton:475: error: 'address' was not declared in this scope
ibutton:481: error: 'ssid' was not declared in this scope
ibutton:483: error: 'passphrase' was not declared in this scope
ibutton_v5.ino (11.3 KB)
NO! That is nonsense.
You have a collection of boxes. There are 10 rows and 8 columns. Why is it so difficult to understand that a letter read from the file goes in one of the boxes? Why is it so difficult to understand that you need to keep track of which row the letter will end up on? Why is it so difficult to understand that you need to keep track of which column the letter will end up in?
Keeping track of the row and column) is dirt simple.
You have a global variable called row, initialized to 0.
You have a global variable called col, initialized to 0.
Every time you read a character from the file, test it.
If it is a carriage return, increment row and set col to 0.
Otherwise, store the character in the row'th row, in the col'th column and increment col.
I could understand it easyly but not by code.
I'm tryng anymore but I can0t do that. Seems to easy but is not when you must code it
