Help! Decoding TPMS ID
Hello,
I'm new to the Arduino world. I was hoping someone can help with this project. Can someone help advise which Arduino Hardware would work best for capturing or decoding TPMS ID number. this is for an Industrial application.
The Idea is to Have Our TPMS receivers in different location of an underground mine where tires are stored. they just needs to know at what location the tires are being stored based on the TPMS ID. the data will then make it to surface VIA Fiber optics. that way they don't need to visit multiple locations to find the proper tires.
By using the RTL-SDR.com/ Radio hack tool, we where able to show all data in binary and found the TPMS identification number.
The next attempt was to have the Arduino RFM GPIO module decode the RF data, but doesn't seem to work?
Do need a different module? possibly for raw data?
Can someone help point me in the right direction?
will the programming be difficult?
Thanks
Richard
Hello,
Thanks
Richard
Cross post of Help! Decoding TPMS ID - #2 by richleva - Programming Questions - Arduino Forum
Glossary of Terms
TPMS: Tire Pressure Monitoring System
RTL-SDR: Software Defined Radio
Arduino RFM GPIO: ?
Cross Post: Duplicating a post in different parts of the forum
What did your experience with the software defined radio tell you about the transmission frequency, signal encoding etc. ?
TPMS overview
TPMS decoding software
A quick google search gives several projects
Threads merged.
@richleva, do not cross-post.
Hola lo que he visto hay dos tipos de sensor tpms
Uno usa 433.92 mhz esos los puedes analizar con las herramientas de sdr
Otros usan bluetooth BLE a 2.4Ghz para analizar estos usa un modulo bluetooth hm10 (actualizado a la versión 609) y el comando at+disa? Te da información del sensor
