Help doing math with strings
I'm confused...
People use the C standard libraries all the time. String functions, math functions, I/O functions, etc.
@dylan_k
I like this little gem from Nick Gammon's serial page, to parse bigger than one digit num's
if (isdigit (c))
    currentValue *= 10;
    currentValue += c - '0';
  }  // end of digit
Alright, the code seems to be working! Thanks to everybody for their input!
FYI. isdigit (c) is part of the C standard libraries. This is an example of commonly used C library functions.
just look at this part of the code
const int MaxOp = 10;
char       op [MaxOp];
int        opIdx;
const int MaxVal = 10;
int       val [MaxVal];
int       valIdx = 0;
void
calc (
    char c )
    int val1;
    int val2;
    printf ("calc: c %c\n", c);
    switch (c) {
    case '0'...'9':
        val [valIdx] = 10*val [valIdx] + c - '0';
    case '+':
    case '-':
    case '*':
    case '/':
        if (MaxVal <= ++valIdx)  {
            printf ("Error: MaxVal exceeded\n");
            exit (1);
        op [opIdx++] = c;
    case '=':
        if (1 > valIdx)  {
            printf ("Error: too few vals - valIdx %d\n", valIdx);
            exit (1);
        val1 = val [--valIdx];
        val2 = val [--valIdx];
        switch (op [--opIdx])  {
        case '+':
            val [valIdx++] = val1 += val2;
        case '-':
            val [valIdx++] = val1 -= val2;
        printf (" %6d\n", val1);
they are actually header files.
Arduino.h is included by default in every .ino file. you're using many libraries
  Arduino.h - Main include file for the Arduino SDK
  Copyright (c) 2005-2013 Arduino Team.  All right reserved.
  This library is free software; you can redistribute it and/or
  modify it under the terms of the GNU Lesser General Public
  License as published by the Free Software Foundation; either
  version 2.1 of the License, or (at your option) any later version.
  This library is distributed in the hope that it will be useful,
  but WITHOUT ANY WARRANTY; without even the implied warranty of
  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
  Lesser General Public License for more details.
  You should have received a copy of the GNU Lesser General Public
  License along with this library; if not, write to the Free Software
  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
#ifndef Arduino_h
#define Arduino_h
#include <stdlib.h>
#include <stdbool.h>
#include <string.h>
#include <math.h>
#include <avr/pgmspace.h>
#include <avr/io.h>
#include <avr/interrupt.h>
#include "binary.h"
#ifdef __cplusplus
extern "C"{
#endif
void yield(void);
#define HIGH 0x1
#define LOW  0x0
#define INPUT 0x0
#define OUTPUT 0x1
#define INPUT_PULLUP 0x2
#define PI 3.1415926535897932384626433832795
#define HALF_PI 1.5707963267948966192313216916398
#define TWO_PI 6.283185307179586476925286766559
#define DEG_TO_RAD 0.017453292519943295769236907684886
#define RAD_TO_DEG 57.295779513082320876798154814105
#define EULER 2.718281828459045235360287471352
#define SERIAL  0x0
#define DISPLAY 0x1
#define LSBFIRST 0
#define MSBFIRST 1
#define CHANGE 1
#define FALLING 2
#define RISING 3
#if defined(__AVR_ATtiny24__) || defined(__AVR_ATtiny44__) || defined(__AVR_ATtiny84__)
  #define DEFAULT 0
  #define EXTERNAL 1
  #define INTERNAL1V1 2
  #define INTERNAL INTERNAL1V1
#elif defined(__AVR_ATtiny25__) || defined(__AVR_ATtiny45__) || defined(__AVR_ATtiny85__)
  #define DEFAULT 0
  #define EXTERNAL 4
  #define INTERNAL1V1 8
  #define INTERNAL2V56 9
  #define INTERNAL2V56_EXTCAP 13
#else
#if defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__) || defined(__AVR_ATmega1284__) || defined(__AVR_ATmega1284P__) || defined(__AVR_ATmega644__) || defined(__AVR_ATmega644A__) || defined(__AVR_ATmega644P__) || defined(__AVR_ATmega644PA__)
#define INTERNAL2V56 3
#else
#define INTERNAL 3
#endif
#define DEFAULT 1
#define EXTERNAL 0
#endif
// undefine stdlib's abs if encountered
#ifdef abs
#undef abs
#endif
#define min(a,b) ((a)<(b)?(a):(b))
#define max(a,b) ((a)>(b)?(a):(b))
#define abs(x) ((x)>0?(x):-(x))
#define constrain(amt,low,high) ((amt)<(low)?(low):((amt)>(high)?(high):(amt)))
#define round(x)     ((x)>=0?(long)((x)+0.5):(long)((x)-0.5))
#define radians(deg) ((deg)*DEG_TO_RAD)
#define degrees(rad) ((rad)*RAD_TO_DEG)
#define sq(x) ((x)*(x))
#define interrupts() sei()
#define noInterrupts() cli()
#define clockCyclesPerMicrosecond() ( F_CPU / 1000000L )
#define clockCyclesToMicroseconds(a) ( (a) / clockCyclesPerMicrosecond() )
#define microsecondsToClockCycles(a) ( (a) * clockCyclesPerMicrosecond() )
#define lowByte(w) ((uint8_t) ((w) & 0xff))
#define highByte(w) ((uint8_t) ((w) >> 8))
#define bitRead(value, bit) (((value) >> (bit)) & 0x01)
#define bitSet(value, bit) ((value) |= (1UL << (bit)))
#define bitClear(value, bit) ((value) &= ~(1UL << (bit)))
#define bitToggle(value, bit) ((value) ^= (1UL << (bit)))
#define bitWrite(value, bit, bitvalue) ((bitvalue) ? bitSet(value, bit) : bitClear(value, bit))
// avr-libc defines _NOP() since 1.6.2
#ifndef _NOP
#define _NOP() do { __asm__ volatile ("nop"); } while (0)
#endif
typedef unsigned int word;
#define bit(b) (1UL << (b))
typedef bool boolean;
typedef uint8_t byte;
void init(void);
void initVariant(void);
int atexit(void (*func)()) __attribute__((weak));
void pinMode(uint8_t pin, uint8_t mode);
void digitalWrite(uint8_t pin, uint8_t val);
int digitalRead(uint8_t pin);
int analogRead(uint8_t pin);
void analogReference(uint8_t mode);
void analogWrite(uint8_t pin, int val);
unsigned long millis(void);
unsigned long micros(void);
void delay(unsigned long ms);
void delayMicroseconds(unsigned int us);
unsigned long pulseIn(uint8_t pin, uint8_t state, unsigned long timeout);
unsigned long pulseInLong(uint8_t pin, uint8_t state, unsigned long timeout);
void shiftOut(uint8_t dataPin, uint8_t clockPin, uint8_t bitOrder, uint8_t val);
uint8_t shiftIn(uint8_t dataPin, uint8_t clockPin, uint8_t bitOrder);
void attachInterrupt(uint8_t interruptNum, void (*userFunc)(void), int mode);
void detachInterrupt(uint8_t interruptNum);
void setup(void);
void loop(void);
// Get the bit location within the hardware port of the given virtual pin.
// This comes from the pins_*.c file for the active board configuration.
#define analogInPinToBit(P) (P)
// On the ATmega1280, the addresses of some of the port registers are
// greater than 255, so we can't store them in uint8_t's.
extern const uint16_t PROGMEM port_to_mode_PGM[];
extern const uint16_t PROGMEM port_to_input_PGM[];
extern const uint16_t PROGMEM port_to_output_PGM[];
extern const uint8_t PROGMEM digital_pin_to_port_PGM[];
// extern const uint8_t PROGMEM digital_pin_to_bit_PGM[];
extern const uint8_t PROGMEM digital_pin_to_bit_mask_PGM[];
extern const uint8_t PROGMEM digital_pin_to_timer_PGM[];
// These perform slightly better as macros compared to inline functions
#define digitalPinToPort(P) ( pgm_read_byte( digital_pin_to_port_PGM + (P) ) )
#define digitalPinToBitMask(P) ( pgm_read_byte( digital_pin_to_bit_mask_PGM + (P) ) )
#define digitalPinToTimer(P) ( pgm_read_byte( digital_pin_to_timer_PGM + (P) ) )
#define portOutputRegister(P) ( (volatile uint8_t *)( pgm_read_word( port_to_output_PGM + (P))) )
#define portInputRegister(P) ( (volatile uint8_t *)( pgm_read_word( port_to_input_PGM + (P))) )
#define portModeRegister(P) ( (volatile uint8_t *)( pgm_read_word( port_to_mode_PGM + (P))) )
#define NOT_A_PIN 0
#define NOT_A_PORT 0
#define NOT_AN_INTERRUPT -1
#ifdef ARDUINO_MAIN
#define PA 1
#define PB 2
#define PC 3
#define PD 4
#define PE 5
#define PF 6
#define PG 7
#define PH 8
#define PJ 10
#define PK 11
#define PL 12
#endif
#define NOT_ON_TIMER 0
#define TIMER0A 1
#define TIMER0B 2
#define TIMER1A 3
#define TIMER1B 4
#define TIMER1C 5
#define TIMER2  6
#define TIMER2A 7
#define TIMER2B 8
#define TIMER3A 9
#define TIMER3B 10
#define TIMER3C 11
#define TIMER4A 12
#define TIMER4B 13
#define TIMER4C 14
#define TIMER4D 15
#define TIMER5A 16
#define TIMER5B 17
#define TIMER5C 18
#ifdef __cplusplus
} // extern "C"
#endif
#ifdef __cplusplus
#include "WCharacter.h"
#include "WString.h"
#include "HardwareSerial.h"
#include "USBAPI.h"
#if defined(HAVE_HWSERIAL0) && defined(HAVE_CDCSERIAL)
#error "Targets with both UART0 and CDC serial not supported"
#endif
uint16_t makeWord(uint16_t w);
uint16_t makeWord(byte h, byte l);
#define word(...) makeWord(__VA_ARGS__)
unsigned long pulseIn(uint8_t pin, uint8_t state, unsigned long timeout = 1000000L);
unsigned long pulseInLong(uint8_t pin, uint8_t state, unsigned long timeout = 1000000L);
void tone(uint8_t _pin, unsigned int frequency, unsigned long duration = 0);
void noTone(uint8_t _pin);
// WMath prototypes
long random(long);
long random(long, long);
void randomSeed(unsigned long);
long map(long, long, long, long, long);
#endif
#include "pins_arduino.h"
#endif
To use this code, how do I input the equation?
pass it a string
    calc ("123+45=");
so
    char s = "123+45=";
    calc (s);
char s = "123+45=";
calc (s);
char       op [MaxOp];
int        opIdx;
int       val [MaxVal];
int       valIdx = 0;
void
calc (
    char c )
    int val1;
    int val2;
    switch (c) {
    case '0'...'9':
    case '+':
    case '-':
    case '*':
    case '/':
            exit (1);
        op [opIdx++] = c;
    case '=':
        if (1 > valIdx)  {
            exit (1);
        case '+':
        case '-':
Gave me the errors:
1:10: error: invalid conversion from 'const char*' to 'char' [-fpermissive]
2:6: error: expected constructor, destructor, or type conversion before '(' token
calc (s);
This code is outside of a function, hence the second error. Please post a complete sketch
You will likely need to use float variables for the calculation, such as the following equation, which will give a wrong answer with integer math:
( 2 / 4 ) * 6 * 8
That is the full code. It is the code that got posted and I wasn't able to copy the code from the linked article
It has no setup() or loop() function so how it the complete sketch ?
sorry, my mistake.
it needs to be passed one char at a time
but i've found some serious flaws in the code
No problem, I am currently working on some self made code, since that will be easier for me to understand (I had working code, but then I accidentally deleted it and didn't have a save).
i feel this code demonstrates the approach using separate stacks for values and operator, but is incomplete. while easy to add '*', perhaps not so easy for '/', not sure about '(', ')'.
output for "120+45-60+1
calc: c 1
calc: c 2
calc: c 0
calc: c +
                            <1>    <0>
                            120
calc: c 4
calc: c 5
calc: c -
                            <2>    <1>
                            120      +
                             45
    165  =    120 +     45  [1]    <0>
calc: c 6
calc: c 0
calc: c +
                            <2>    <1>
                            165      -
                             60
    105  =    165 -     60  [1]    <0>
calc: c 1
calc: c =
                            <2>    <1>
                            105      +
                              1
    106  =    105 +      1  [1]    <0>
char       op [MaxOp];
int        opIdx;
int       val [MaxVal];
int       valIdx = 0;
char s [90];
void
calc (
    char c )
    int  val1;
    int  val2;
    char oper;
    sprintf (s, "calc: c %c", c);
    Serial.println (s);
    switch (c) {
    case '0'...'9':
    case '-':
    case '+':
    case '*':
    case '/':
    case '=':
            exit (1);
        sprintf (s, "%24s    <%d>    <%d>", "", valIdx, opIdx);
        Serial.println (s);
        for (int n = 0; n < valIdx; n++)  {
            sprintf (s, "%24s %6d %6c", "", val [n], op [n]);
            Serial.println (s);
        if (1 < valIdx)  {
            val2 = val [--valIdx];   val [valIdx] = 0;
            val1 = val [--valIdx];   val [valIdx] = 0;
            oper = op  [--opIdx];    op  [opIdx]  = 0;
#if 0
            sprintf (s, "%27s [%d]    <%d>", "", valIdx, opIdx);
            Serial.println (s);
#endif
            switch (oper)  {
            case '+':
                val [valIdx++] = val1 + val2;
            case '-':
                val [valIdx++] = val1 - val2;
            sprintf (s, " %6d  = %6d %c %6d  [%d]    <%d>",
                    val [valIdx-1], val1, oper, val2, valIdx, opIdx);
            Serial.println (s);
        if ('=' != c)
            op [opIdx++] = c;
            valIdx = opIdx = val [0] = 0;
void loop ()
    while (Serial.available ())
        calc (Serial.read ());
void setup ()
    Serial.begin (9600);
I did not see a need for arrays. Converting ASCII characters to integer is this... subtract '0' from the ASCII character, change the char to a float (for division), shift the current total left, add the new float.
      pFloat = pChar - 48; // change char to float
      subtotal *= 10; // shift subtotal left...
      subtotal += pFloat; // ... add the new digit
Addition, subtraction, multiplication and division are all forms of addition. Addition is in the positive direction, subtraction is "addition in the negative direction," multiplication is recursive addition in the positive direction, and division is recursive addition in the negative direction. Exponents multiply multiplication (recursively add recursive addition in the positive direction) and routes divide division (recursively add in the negative direction , recursive addition in the negative direction).
The sketch only does addition and subtraction, and can be improved on the sign-checking and presentation.
// https://forum.arduino.cc/t/help-doing-math-with-strings/1373788/
  calculator - Keep It Simple So Alto Smiles Serenely
  - operates left to right only
  - add, sub, mul, div ALL USE ADDITION:
  -- add (positive direction)
  -- sub (negative direction)
  -- mul (recursive positive direction)
  -- div (recursive negative direction)
char array[] = "631 - 35 + 238 - 57 =";
int sizeofArray = sizeof(array) / sizeof(array[0]);
int pChar, pFloat, total, subtotal;
int signNew = 1, signOld = 1;
  for (int i = 0; i < sizeofArray; i++)
    parse(array[i]);
void loop() {}
void parse(char pChar) {
  switch (pChar) {
    case '+': // sign indicates new number. default sign is +
      signOld = signNew;
      signNew =  1; // add positive direction
      total = total + (subtotal * signOld); // store subtotal
      Serial.print(subtotal * signOld);
      Serial.print("+");
      subtotal = 0; // clear subtotal when symbol is read
    case '-':
      signOld = signNew;
      signNew = -1;
    case'=':
      signOld = signNew;
      total = total + subtotal * signOld;
      Serial.print("=");
      Serial.println(total);
      subtotal = 0;
    case ' ': break; // ignore space
    case '0'...'9':
    default: break;
Multiplication, division, exponents and routes to come.
This code seems really small for what it does, which is great! However, the calculator I am working on needs to know PEMDAS (and "+", "-", "*", "/", "(" and"')" ). I actually finished it earlier today, but I am adding some extra stuff like error messages for 0 divided by 0 and stuff like that :slight_smile:
Hope to see your result.
The showcase for this (my) code is the three lines used to convert ASCII characters to a number. Formatting and display was the bulk of the code.
