Hi, I have a problem with the arduino edge control board, I already tried to connect it but I don't see it turning on an indicator LED or something, the Arduino Ide if it detects the board, and you can load codes but I don't see any indicator LED. 2 MKR WAN 1310 boards were also connected directly to the edge control board since it has two connectors but it does not power them, they do not turn on. The model of the plate is control is AKX00034. I'd appreciate your help
The cables are connected to a 12v source, which are connected to the power of the 12v battery, and from there it is connected to the computer to charge codes etc.
