Help fixing my project, hopefully me misunderstanding the math library
//yup, those sure are libraries
#include <math.h>
#include <Servo.h>
//yup, those sure are servos
Servo Shoulder;
Servo Elbow;
int x = 30;                //x position desired(input)
int y = 30;                //y position desired(input)
int shoulderAngle = 0;     //self-explanitory
int elbowAngle = 0;        //self-explanitory
int bicep_Length = 60;     //arm attached to first servo
int foremarm_Length = 70;  //arm attached to second servo
float P = 0;               //angle between the ground and the line from the endpoint to the base
float B = 0;               //angle between the endpoint and the base
int shoulderPin = (3);     //self-explanitory
int elbowPin = (5);        //self-explanitory
  pinMode(2, INPUT);
  pinMode(4, INPUT);
  Shoulder.attach(shoulderPin);
  Elbow.attach(elbowPin);
  //im using a pretty simple PWM pre-built controller because i couldnt be arsed to design and build one myself
  unsigned long moveRLButton = (pulseIn(7, HIGH));
  unsigned long moveFBButton = (pulseIn(8, HIGH));
  if (1300 <= moveFBButton <= 1500) {
    x = x;
  if (1300 >= moveFBButton) {
    x = x - 1;
  if (1500 <= moveFBButton) {
    x = x + 1;
  if (1300 <= moveRLButton <= 1500) {
    y = y;
  if (moveRLButton < 1200) {
    y = y + 1;
  if (moveRLButton > 1500) {
    y = y - 1;
  //these just stop the arm from attempting to move out of bounds
  if (x >= 60) {
    x = 60;
  if (x <= 10) {
    x = 10;
  if (y >= 60) {
    y = 60;
  if (y <= 10) {
    y = 10;
  //(allegedly) super simple inverse kinematics for 2dof
  int C2 = (x ^ 2 + y ^ 2);
  float C = sqrt(C2);
  float P = atan(y / x);
  float B = acos((foremarm_Length ^ 2 - bicep_Length ^ 2 - C2) / -2 * bicep_Length * C);
  elbowAngle = acos((C2 - bicep_Length ^ 2 - foremarm_Length ^ 2) / -2 * bicep_Length * foremarm_Length);
  shoulderAngle = (B + P);
  //writes the desired angle to the servos
  Shoulder.write(shoulderAngle);
  Elbow.write(elbowAngle);
  //tells me what to cry about(only here so i can see if im getting the right #'s)
  Serial.println(shoulderAngle);
  Serial.println(elbowAngle);
  Serial.println(C);
  Serial.println(C2);
  Serial.println(P);
  Serial.println(B);
  delay(400000);
i think i might be using a wrong variable type or have an operation in some way formatted incorrectly(ie i see ((x^2) + (y^2)) but code sees ((x) ^ (2+y) ^ (2)) (<--tried this, did not fix the issue) but for the life of me i cant figure out what is the issue, though B almost always outputs not a number which is what id like help with to start off with; im so sorry if tis cripplingly obvious im very new to this
Use x * x
Your problems are not with the math library.
Your problems are with not understanding basic C programming concepts.
Things like what the ^ operator does, and how to properly test multiple conditions.
I would suggest setting your compile warning level to ALL, and then doing some basic reading on C.
If you are following some guide or other resource, it is best to include a link to it so it becomes clearer what you are trying to achieve.
As others have said, "^" doesn't do what you think it does in C language. It is a numeric operator, so you won't get an error message, but it has a completely different purpose to some other languages. Look it up.
The C language doesn't allowed multiple conditions this way, use two separate condition and logic operators:
if ((1300 <= moveFBButton ) && (moveFBButton <= 1500))
