I have an incompatibility problem with the interrupts and the ppm reader library. Link below.
github.com/Nikkilae/PPM-reader
In my project I need to read a ppm signal and another sensor that uses an interrupt. I made a simplify version of my code which keeps the error. If anyone has a solution I will be very grateful.
arduino code below
#include <PPMReader.h>
#define interruptPin_TEST 3 //interrupt pin for a test sensor
int interruptPin_PPM = 2; //interrupt pin for the ppm library
int channelAmount = 6; //declaration of the 6 channels
PPMReader ppm(interruptPin_PPM, channelAmount); //declaration of reading of a PPM signal
void testvoid(){
Serial.print("void test use");
Serial.begin(19200);
pinMode(interruptPin_TEST, INPUT);
attachInterrupt(digitalPinToInterrupt(interruptPin_TEST), testvoid, RISING); //declaration of an interrupt for a test sensor
unsigned long channel_1 = ppm.latestValidChannelValue(1, 0); //read channel 1 of the PPM signal
Serial.print(String(channel_1) + " ");
error in the console during compilation below
WInterrupts.c.o (symbol from plugin): In function `attachInterrupt':
(.text+0x0): multiple definition of `__vector_1'
C:\Users\FREDPO~1\AppData\Local\Temp\arduino_build_699786\libraries\InterruptHandler\WInterrupts.cpp.o (symbol from plugin):(.text+0x0): first defined here
(.text+0x0): multiple definition of `__vector_2'
collect2.exe: error: ld returned 1 exit status
hoping to have news, thank you in advance
