I have recently started working on Arduino for a project & its performance is awesome .
Need your expertise to check the feasibility to find a tree diameter using arduino & IR or Ultrasonic sensors with the combination for servos or any other .
Usually a tree diameter is calculation above 4:50 feet . so we may need gyro as well .
They are probably currently trying to measure the diameter and circumference of tress at varying heights.
usually involves someone ascending...usually not dangerous (although as a climber of ~20 years...I have seen varying levels of retardery when it comes to safe climbing) it can be expensive and slow going.
They want a device that will scale a tree and measure the circumference and diameter at varying heights.
The OP should explain how the measuring is done at the moment.
Trees tend to have branches which could make automated measurement very complex. But it is easy for a human brain to find a suitable work-around.
On a side note, this sounds like an attempt to replace a human with a machine. I think it is time we stopped doing that. It has been going on since the industrial revolution and, while it has made a few people very rich, it has not made humanity any happier.
you go into a forest and want to cut only trees that are 1 meter or larger in diameter.
you take your harvester to a tree,
from 4.12 meters away, sensed by your range finder
and at 4.5 feet from the ground
the visual angle of the tree is 2.31 degrees.
now you have all you need to calculate the unknown side. the diameter of the tree.
it it is larger than spec, it becomes Mrs Finnegans new chest of drawers and lumber for the new house.
by feeding the vision input into your R-Pi, you can do the math
#2
you approach a tree, slip your verniers over the tree and by holding them 4.5 feet above the ground as sensed by your range finder, you move them till they touch the tree on both sides. then measure the distance on your verniers based on movement of the verniers.
#3
you have your two lasers, each mounted parallel to each other,
on a rail that allows you to separate them.
you move to your tree, then slide them so that each one touches the side of the tree.
your ir sensor is to 'see' that it touches the tree and reflects or not...
measure the distance of your lasers, that equal the tree diameter
dave-in-nj:
. . . #3
I was beginning to think that a ladder and a tape measure would be the only practical solution, but this idea makes sense. If the lasers point upwards at 45 degrees from the ground, then the laser measuring device has to me mounted 4.5 meters ( minus half the base diameter) from the tree. This ensures that the measurement is made at the required height of 4.5 meters.
Robin2:
...R
Really OT, but do you have to work 12 hours a day 6/7 days a week?
Robin2:
Would you actually be less happy than you are now if you did have to (and did not know anything different)?
You probably would not have been kept awake at night worrying how you were going to meet next month's repayment on the new car.
...R
I for one am happy that Eli Whittney invented the cotton gin.
and that someone invented the saw mill.
I would not want to have to go out and cut my own trees to make my house
then grow my own crops for food.
it sounds romantic, but if your whole life is spent in the pursuit of living for the food and shelter for that day, there is little meaning in one's life.
besides, most people cannot even define happiness.
Sometimes, it's just nicer to climb the dang tree and measure it yourself. I've got the gear in a box in my shed and have done some climbing in my day. It would take me twice as long these days to get up there. But it's a whole lot better than sitting in traffic. Or moving in traffic for that matter.
Thanks all for anticipation and suggestions , this product is needed for a forest department in India to calculate the Diameter dividing the Eucalyptus Plants into sectors , living , dead with GPS marking on google maps with the details like diameter ... a big project and this part is very crucial .
