Help for universal tester
Hello everyone,
I’m working on a universal cable tester project using an ESP32 DevKit V1, a MCP23017 (I2C) expander, a ST7735 TFT display (128×160), and a rotary encoder.
My goal is to detect cable connections (40 Pins tester) by scanning continuity between the pins (GPA ↔ GPB). I start with 8 pin so with only one MCP for test
Here is my current wiring setup on the breadboard:
  • ESP32 to TFT ST7735:
    • CS → GPIO27
    • DC → GPIO26
    • RST → GPIO25
    • MOSI → GPIO13
    • SCLK → GPIO14
    • VCC → 3.3V
    • GND → common ground
  • ESP32 to MCP23017 (I2C):
    • VDD → 3.3V
    • VSS → GND
    • SDA → GPIO21
    • SCL → GPIO22
    • A0, A1, A2 → GND (→ I2C address = 0x20)
    • RESET → 3.3V through 10 kΩ resistor
    • 0.1 µF capacitor between VDD and GND (close to the chip)
    • GPB0–GPB7 connected to GPA0–GPA7 (simulating cable links)
    • 10 kΩ pull-ups from each GPB pin to 3.3V
  • Rotary encoder:
    • A → GPIO4
    • B → GPIO2
    • SW → GPIO15
    • C → GND
    • The last Pin → GND
All components are powered from the ESP32’s 3.3 V rail.
The wiring has been double-checked and there are no shorts.
I tried several sketches, including the following I2C + MCP23017 diagnostic code (see below).
It initializes I2C on GPIO 21/22, scans the bus, and attempts a raw I2C read from address 0x20 before running Adafruit’s MCP23017 library.
However, the scan always returns:
*** NO DEVICES FOUND! ***
Check: Pull-ups, address pins, RESET, power, etc.
I2C errors such as
I2C hardware NACK detected
also appear repeatedly in the serial monitor.
I’ve verified wiring, used external 4.7 kΩ pull-ups on SDA/SCL, and tried 100 kHz I2C clock speed. Still nothing is detected.
Here’s the sketch I used:
#include <Arduino.h>
#include <Wire.h>
#include <Adafruit_MCP23X17.h>
Adafruit_MCP23X17 mcp;
const uint8_t MCP_ADDR = 0x20; // A0=A1=A2=GND
  Serial.println("\n\n========== I2C DIAGNOSTIC START ==========");
  Wire.begin(21, 22);
  Wire.setClock(100000);
  delay(100);
  int found_count = 0;
  for (uint8_t addr = 1; addr < 127; addr++) {
    Wire.beginTransmission(addr);
    byte error = Wire.endTransmission();
    if (error == 0) {
      found_count++;
      Serial.printf("Found device at 0x%02X\n", addr);
  if (found_count == 0) {
    Serial.println("*** NO DEVICES FOUND! ***");
    while (1) delay(1000);
  if (!mcp.begin_I2C(MCP_ADDR)) {
    Serial.println("*** LIBRARY INIT FAILED @0x20 ***");
  Serial.println("MCP23017 OK!");
void loop() {}
Does anyone have an idea why the MCP23017 isn’t detected at all on the I2C bus?
The next step, once it's working, is to multiply the MCP23017 to create sides A and B with 40 pins on each, and to be able to make a universal tester in which we will create adapters by making breakboards
Thank you! :folded_hands:
Using words to describe a circuit is not the best idea. Simply draw by hand where each wire goes, the boards etc then take a photo of it.
The choice of microcircuit for the device is unclear. The PCF8575 will give you 16 lines, but there can be 8 of these microcircuits on one bus.
Why isn't it being detected? Is the address incorrect or is it malfunctioning? Check with a scanner, does it find your device?
if I run the code of post 1 on a ESP32 with a MCP23017 using ESP32 core 3.3.2 I get
Found device at 0x20
MCP23017 OK!
could you have a power supply problem?
EDIT: running I2Cdetect
#include <Wire.h>
#include <i2cdetect.h>
#define I2C_SDA 21
#define I2C_SCL 22
  Wire.begin(I2C_SDA, I2C_SCL);
   Wire.setTimeout(0);//3000);// /* us /, true / reset_on_timeout */); //
   Wire.setClock ( 400000L ) ;
  //Wire.begin();
  Serial.println("i2cdetect example\n");
  Serial.print("Scanning address range 0x03-0x77\n\n");
  i2cdetect();
  delay(2000);
I get
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: 20 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
Could it be an MCP23S17 ? as that is a SPI device. (note the S instead of 0)
I'd like to know your verification method. Short wires carefully soldered or chained jumper wires running here and there with breadboard in the middle?
Quick update on my progress! > Thanks to the previous advice (especially regarding the battery charging), I have now finalized the schematics for my ESP32 cable tester.
To make the mechanical assembly easier, I decided to split the design into two separate PCBs connected by a 2x10 IDC ribbon cable:
1. Main Board (Controller & Power):
  • ESP32, 3.5" TFT Screen (SPI) and ADS1115.
  • Proper Load Sharing / Power Path circuit (DMP1045U p-mosfet + SB220 diode) combined with the TP4056 and MT3608 boost converter.
  • A constant current source using an MCP6002 Op-Amp for precise measurements.
2. Multiplexer Board (The Array):
  • 6x MCP23017 (I2C) driving 6x CD74HC4067 analog multiplexers. (Note: I used the BOB-09056 breakout module footprint for the multiplexers due to stock shortages of the DIP packages).
Since this is the final step before I generate the Gerbers for JLCPCB, I would highly appreciate a quick sanity check from the community. Does everything look correct, particularly the power path and the I2C/SPI routing?
Main Board:
carte2.pdf (366,8 Ko)
( its say that its the card 2 but its 1, I inverse ... )
Multiplexer Board:
carte1.pdf (949,9 Ko)
Thanks again for the help!
Don't know if this will affect your project but it's :
not advised to use A7, B7 as inputs
I haven't encountered any problems with those pins, maybe I was just lucky...
