hello all
I do a program using lcd menu display
and i dont know which library can use for this.
can you explain something about lcd menu
thanks. ![]()
I do a program
. . . which you didn't post.
Show us your code. Try to explain more about your problem, what lcd model, which arduino board, and so on.
Have you tried to Google:
Arduino LCD menu
#include <MenuBackend.h>
#include <LiquidCrystal.h>
const int buttonPinLeft = 8;
const int buttonPinRight = 9;
const int buttonPinEsc = 10;
const int buttonPinEnter = 11;
int lastButtonPushed = 0;
int lastButtonEnterState = LOW;
int lastButtonEscState = LOW;
int lastButtonLeftState = LOW;
int lastButtonRightState = LOW;
long lastEnterDebounceTime = 0; // the last time the output pin was toggled
long lastEscDebounceTime = 0;
long lastLeftDebounceTime = 0;
long lastRightDebounceTime = 0;
long debounceDelay = 100; // the debounce time
LiquidCrystal lcd(52, 53, 51, 50, 49, 48);
//Menu variables
MenuBackend menu = MenuBackend(menuUsed,menuChanged);
//initialize menuitems
MenuItem menu1Item1 = MenuItem("Item1");
MenuItem menuItem1SubItem1 = MenuItem("Item1SubItem1");
MenuItem menuItem1SubItem2 = MenuItem("Item1SubItem2");
MenuItem menu1Item2 = MenuItem("Item2");
MenuItem menuItem2SubItem1 = MenuItem("Item2SubItem1");
MenuItem menuItem2SubItem2 = MenuItem("Item2SubItem2");
MenuItem menuItem3SubItem3 = MenuItem("Item2SubItem3");
MenuItem menu1Item3 = MenuItem("Item3");
pinMode(buttonPinLeft, INPUT);
pinMode(buttonPinRight, INPUT);
pinMode(buttonPinEnter, INPUT);
pinMode(buttonPinEsc, INPUT);
lcd.begin(16, 2);
//configure menu
menu.getRoot().add(menu1Item1);
menu1Item1.addRight(menu1Item2).addRight(menu1Item3);
menu1Item1.add(menuItem1SubItem1).addRight(menuItem1SubItem2);
menu1Item2.add(menuItem2SubItem1).addRight(menuItem2SubItem2).addRight(menuItem3SubItem3);
menu.getRoot();
lcd.setCursor(0,0);
lcd.print("menu test");
readButtons();
navigateMenus();
} //loop()...
void menuChanged(MenuChangeEvent changed){
MenuItem newMenuItem=changed.to;
lcd.setCursor(0,1);
if(newMenuItem.getName()==menu.getRoot()){
lcd.print("Main Menu ");
}else if(newMenuItem.getName()=="Item1"){
lcd.print("Item1 ");
}else if(newMenuItem.getName()=="Item1SubItem1"){
lcd.print("Item1SubItem1");
}else if(newMenuItem.getName()=="Item1SubItem2"){
lcd.print("Item1SubItem2 ");
}else if(newMenuItem.getName()=="Item2"){
lcd.print("Item2 ");
}else if(newMenuItem.getName()=="Item2SubItem1"){
lcd.print("Item2SubItem1 ");
}else if(newMenuItem.getName()=="Item2SubItem2"){
lcd.print("Item2SubItem2 ");
}else if(newMenuItem.getName()=="Item2SubItem3"){
lcd.print("Item2SubItem3 ");
}else if(newMenuItem.getName()=="Item3"){
lcd.print("Item3 ");
void menuUsed(MenuUseEvent used){
lcd.setCursor(0,0);
lcd.print("You used ");
lcd.setCursor(0,1);
lcd.print(used.item.getName());
delay(3000); /
lcd.setCursor(0,0);
menu.getRoot(); //back to Main
void readButtons(){ //read buttons status
int reading;
int buttonEnterState=LOW;
int buttonEscState=LOW;
int buttonLeftState=LOW;
int buttonRightState=LOW;
//Enter button
reading = digitalRead(buttonPinEnter);
if (reading != lastButtonEnterState) {
// reset the debouncing timer
lastEnterDebounceTime = millis();
if ((millis() - lastEnterDebounceTime) > debounceDelay) {
buttonEnterState=reading;
lastEnterDebounceTime=millis();
// save the reading. Next time through the loop,
// it'll be the lastButtonState:
lastButtonEnterState = reading;
//Esc button
// read the state of the switch into a local variable:
reading = digitalRead(buttonPinEsc);
if (reading != lastButtonEscState) {
lastEscDebounceTime = millis();
if ((millis() - lastEscDebounceTime) > debounceDelay) {
// whatever the reading is at, it's been there for longer
// than the debounce delay, so take it as the actual current state:
buttonEscState = reading;
lastEscDebounceTime=millis();
lastButtonEscState = reading;
//Down button
reading = digitalRead(buttonPinRight);
// check to see if you just pressed the Down button
// (i.e. the input went from LOW to HIGH), and you've waited
// long enough since the last press to ignore any noise:
// If the switch changed, due to noise or pressing:
if (reading != lastButtonRightState) {
lastRightDebounceTime = millis();
if ((millis() - lastRightDebounceTime) > debounceDelay) {
buttonRightState = reading;
lastRightDebounceTime =millis();
lastButtonRightState = reading;
//Up button
reading = digitalRead(buttonPinLeft);
if (reading != lastButtonLeftState) {
lastLeftDebounceTime = millis();
if ((millis() - lastLeftDebounceTime) > debounceDelay) {
buttonLeftState = reading;
lastLeftDebounceTime=millis();;
lastButtonLeftState = reading;
//records which button has been pressed
if (buttonEnterState==HIGH){
lastButtonPushed=buttonPinEnter;
}else if(buttonEscState==HIGH){
lastButtonPushed=buttonPinEsc;
}else if(buttonRightState==HIGH){
lastButtonPushed=buttonPinRight;
}else if(buttonLeftState==HIGH){
lastButtonPushed=buttonPinLeft;
}else{
lastButtonPushed=0;
void navigateMenus() {
MenuItem currentMenu=menu.getCurrent();
switch (lastButtonPushed){
case buttonPinEnter:
if(!(currentMenu.moveDown())){ //if the current menu has a child and has been pressed enter then menu navigate to item below
menu.use();
}else{ //otherwise, if menu has no child and has been pressed enter the current menu is used
menu.moveDown();
case buttonPinEsc:
menu.moveUp();
case buttonPinRight:
menu.moveRight();
case buttonPinLeft:
menu.moveLeft();
lastButtonPushed=0;
this is my code
this code show only the current menu on lcd
but i want that it show the previous menu too.
Where did you get that library? There should be documentation and examples for it.
/MenuBackend library - copyright by Alexander Brevig
and this is the library example
This is the structure of the modelled menu
Settings
Pin
Debug
Options
Delay (D)
100 ms
200 ms
300 ms
400 ms
//this controls the menu backend and the event generation
MenuBackend menu = MenuBackend(menuUseEvent,menuChangeEvent);
//beneath is list of menu items needed to build the menu
MenuItem settings = MenuItem("Settings");
MenuItem pin = MenuItem("Pin");
MenuItem debug = MenuItem("Debug");
MenuItem options = MenuItem("Options");
MenuItem setDelay = MenuItem("Delay",'D');
MenuItem d100 = MenuItem("100 ms");
MenuItem d200 = MenuItem("200 ms");
MenuItem d300 = MenuItem("300 ms");
MenuItem d400 = MenuItem("400 ms");
//this function builds the menu and connects the correct items together
void menuSetup()
Serial.println("Setting up menu...");
//add the file menu to the menu root
menu.getRoot().add(settings);
//setup the settings menu item
settings.addRight(pin);
//we want looping both up and down
pin.addBefore(debug);
pin.addAfter(debug);
debug.addAfter(pin);
//we want a left movement to pint to settings from anywhere
debug.addLeft(settings);
pin.addLeft(settings);
settings.addBefore(options);
settings.addAfter(options);
options.addRight(setDelay);
setDelay.addLeft(options);
setDelay.addRight(d100);
d100.addBefore(d100); //loop to d400
d100.addAfter(d200);
d200.addAfter(d300);
d300.addAfter(d400);
d400.addAfter(d100); //loop back to d100
//we want left to always be bak to delay
d100.addLeft(setDelay);
d200.addLeft(setDelay);
d300.addLeft(setDelay);
d400.addLeft(setDelay);
options.addAfter(options);
This is an important function
Here all use events are handled
This is where you define a behaviour for a menu item
void menuUseEvent(MenuUseEvent used)
Serial.print("Menu use ");
Serial.println(used.item.getName());
if (used.item == setDelay) //comparison agains a known item
Serial.println("menuUseEvent found Dealy (D)");
Here we get a notification whenever the user changes the menu
That is, when the menu is navigated
void menuChangeEvent(MenuChangeEvent changed)
Serial.print("Menu change ");
Serial.print(changed.from.getName());
Serial.print(" ");
Serial.println(changed.to.getName());
menuSetup();
Serial.println("Starting navigation:\r\nUp: w Down: s Left: a Right: d Use: e");
if (Serial.available()) {
byte read = Serial.read();
switch (read) {
case 'w': menu.moveUp(); break;
case 's': menu.moveDown(); break;
case 'd': menu.moveRight(); break;
case 'a': menu.moveLeft(); break;
case 'e': menu.use(); break;
Does the example work?
yes , it work
Then start by modifiying the example little by little, testing each modification until you finish the desired code.
Thanks for your response
do you know another menu library?
