Help Improving Control System of Servos [Object Tracking]
I am workign in a project, righ now I am here.
With the camera I work out the position of the object (15 times per second) and with that value I move the servo trying to get the center point of the camera. I am doing this with this code:
  if(camera.color_detection(RED))  // True if an object is found, then the position is update in camera.pos_x/y
    // Define the limits which we are going to consider as a valid centered positions "The frame is 160x120"
    int upLimit = 65;
    int downLimit = 55;
    int rightLimit = 85;
    int leftLimit = 75;
    // Real the position of the Servos (degrees)
    int lowerPos = camera.lowerServo.read();
    int upperPos = camera.upperServo.read();
    // If the position of the object is outside our limits we calculate our new position of the servos (Degrees)
    // Based on the distance from the object to the center
    if(camera.object.pos_x > rightLimit)
      lowerPos -= (camera.object.pos_x - rightLimit)/gear;
    else if(camera.object.pos_x < leftLimit)
      lowerPos += (leftLimit - camera.object.pos_x)/gear;
    // Same for upper servo
    if(camera.object.pos_y > upLimit)
      upperPos += (camera.object.pos_y - upLimit)/gear;
    else if(camera.object.pos_y < downLimit)
      upperPos -= (downLimit - camera.object.pos_y)/gear;
    // Update the position of the Servos
    camera.lowerServo.write(lowerPos);
    camera.upperServo.write(upperPos);
    // Serial prints for Debug
    Serial.print("Object position: ");
    Serial.print(camera.object.pos_x);
    Serial.print(", ");
    Serial.println(camera.object.pos_y);
    Serial.print("Distance: ");
    Serial.println(camera.object.distance);
    Serial.print("Movement: ");
    Serial.println(lowerPos);
the function camera.color_detection(RED) updates camera.object.pos_x/y with the position of the object.
The camera is working in QQVGA resolution (160,120) "Desired postition 80,60"
And gear is a constant I am using in order to change the speed of the response.
Now I would like to move to a PID controller or whatever what could improve the response. A have read several examples of PID but I don't know how to implement the code in my case. How to translate the diference from the desired point to degrees.
Thanks in advance.
Can you provide a description of what your code is trying to do. For example "camera.upperServo.read()" means nothing to me.
What should your code be doing and what is it actually doing?
...R
Robin2:
...R
Okey sorry, I'll explain everything better.
I am using thel ibrary servo to control the servo and the library "camera" which control the functionality of the camera. I have updated the post with more code explanation.
I like brevity. But perhaps you are overdoing it? I have NO idea what your system is trying to do or what it's actually doing so how can I help?
Also, it's generally confusing if you make major changes to an earlier post. Better just to show the updated version in a later post.
...R
