Why do you want that LED in the sensor? That will prevent you from attaching it to an arduino.
There are many IR LEDs and photo transistors you can use, look at your local supplier.
Once you know the parts you are using you can work out the values.
Grumpy_Mike:
Hello, Thanks for your reply...
Yesterday I went to see my local supplier but the only sell electronic parts and they don't help me to realise this schema. So they sold me an IR led and a photo transistor but I don't know the références and I test them but it don't works...
It's for this reason I need your help...to buy the correct parts to realise this.
I want use a led just to view if the result is correct. After I want to connect this to an arduino (in second time).
Ok get the ir emitter working first. Use the 5V from the arduino not 9V as this maks things easier. Wire up the IR emitter and look with a digital camera at the diode. You will see it light up white. If you don't then swap the two wires over.
Next wire up the transistor as you have it but to 5V maker the resistor 100K or something like that and do not put the led in. Put a wire from the transistor / resistor junction and run a simple button sketch.
Put the emitter and photo transistor facing each other with a very small gap. You should see the output from the button sketch change when you put a piece of card between the two.
Good luck.
Grumpy_Mike:
Good luck.
I've just connected the IR led directly on the +5v but I kill it...
I must buy an other one....
