Help LED plus DC Motor control
Hi, I would need help with a project.
I am new, I ordered the arduino set for about 1 week, I specify that I do not know C ++, I made a little pascal in high school, but very little.
I have a potentiometer mount that controls a DC motor, I would like that when the potentiometer is set to zero, an RGB led will be off and when the potentiometer has any other value the RGB led will run a FADE program.
This is the main program:
int pwmPin = 12; // assigns pin 12 to variable pwm
int pot = A0; // assigns analog input A0 to variable pot
int c1 = 0; // declares variable c1
int c2 = 0; // declares variable c2
void setup() // setup loop
pinMode(pwmPin, OUTPUT);
pinMode(pot, INPUT);
c2= analogRead(pot);
c1= 1024-c2; // subtracts c2 from 1000 ans saves the result in c1
digitalWrite(pwmPin, HIGH);
delayMicroseconds(c1);
digitalWrite(pwmPin, LOW);
delayMicroseconds(c2);
And this is the LED program
#define BLUE 3
#define GREEN 5
#define RED 6
pinMode(RED, OUTPUT);
pinMode(GREEN, OUTPUT);
pinMode(BLUE, OUTPUT);
digitalWrite(RED, HIGH);
digitalWrite(GREEN, LOW);
digitalWrite(BLUE, LOW);
// define variables
int redValue;
int greenValue;
int blueValue;
// main loop
#define delayTime 10 // fading time between colors
redValue = 255; // choose a value between 1 and 255 to change the color.
greenValue = 0;
blueValue = 0;
// this is unnecessary as we've either turned on RED in SETUP
// or in the previous loop ... regardless, this turns RED off
// analogWrite(RED, 0);
// delay(1000);
for(int i = 0; i < 255; i += 1) // fades out red bring green full when i=255
redValue -= 1;
greenValue += 1;
// The following was reversed, counting in the wrong directions
// analogWrite(RED, 255 - redValue);
// analogWrite(GREEN, 255 - greenValue);
analogWrite(RED, redValue);
analogWrite(GREEN, greenValue);
delay(delayTime);
redValue = 0;
greenValue = 255;
blueValue = 0;
for(int i = 0; i < 255; i += 1) // fades out green bring blue full when i=255
greenValue -= 1;
blueValue += 1;
// analogWrite(BLUE, 255 - blueValue);
analogWrite(BLUE, blueValue);
delay(delayTime);
redValue = 0;
greenValue = 0;
blueValue = 255;
for(int i = 0; i < 255; i += 1) // fades out blue bring red full when i=255
// The following code has been rearranged to match the other two similar sections
blueValue -= 1;
redValue += 1;
delay(delayTime);
The for loop and delay() function need to be eliminated from the program. While it executes nothing else will happen.
Take a look at Using millis() for timing. A beginners guide, Several things at the same time and the BlinkWithoutDelay example in the IDE
Two or more programs is not going to be helpful. You get to load ONE and only ONE program at a time. Of course, you are going to be able to load more than one program, but loading a program wipes out the previously loaded program.
