Hello!
I’m starting to learn electronics, and I’m still super noob with coding in Arduino.
(I can copy/build simple projects from other people, but I’m far from understanding it enough to write my own code)
If anyone could help me with this little first project I would be super grateful. ![]()
What I want is to have 10 portable Neopixels with a little controller from which I can:
- choose between “solid color mode” or “rainbow cycle mode”
- on “solid mode” I’d like to choose the hue with a Pot
- on “rainbow mode” I’d like to choose the speed animation with that same Pot
(I could give up on this speed feature if it adds too much complexity, though) - a second pot to choose the overall brightness (for the solid or the rainbow, whichever is on)
I've built something like the attached image (with 10 leds instead - powered from external source).
The hardware part so far seems ok. My problem is the coding.
I searched a lot but couldn't find anything close enough to my project that I'm capable of tweaking myself, right now ![]()
The closest I found so far is the code below
(but this only let you choose from specific colors with the pushbutton and then change the brightness with a pot. I wish I could add the rainbow mode to the "menu" and be able to choose the hue through the pot, instead of the button)
#define BUTTONPIN_G 2
#define PIXEL_PIN 6 // Digital IO pin connected to the NeoPixels.
#define PIXEL_COUNT 10
int potentiometerG = A2;
int brightness;
Adafruit_NeoPixel strip = Adafruit_NeoPixel(PIXEL_COUNT, PIXEL_PIN, NEO_GRB + NEO_KHZ800);
bool oldState = HIGH;
int showType = 0;
pinMode(potentiometerG, INPUT);
pinMode(BUTTONPIN_G, INPUT_PULLUP);
strip.begin();
strip.show();
// Set the strip to shite on powerup
uint32_t startcolor = strip.Color(127 * brightness / 100, 127 * brightness / 100, 127 * brightness / 100);
Allcolor(startcolor);
strip.show(); //Show the start color
startShow(showType);
// Here we'll use the reading from the potentiometer to set the brightness
brightness = map(analogRead(potentiometerG), 0, 1023, 0, 100);
// Get current button state.
bool newState = digitalRead(BUTTONPIN_G);
// Check if state changed from high to low (button press).
if (newState == LOW && oldState == HIGH) {
// Short delay to debounce button.
delay(20);
// Check if button is still low after debounce.
if (newState == LOW) {
showType++;
if (showType > 9)
showType=0;
strip.show(); // Display the LEDs
// Set the last button state to the old state.
oldState = newState;
void startShow(int i) {
switch(i){
case 0: {
uint32_t white = strip.Color(127 * brightness / 100, 100 * brightness / 100, 10 * brightness / 100);
Allcolor(white);
case 1: {
uint32_t red = strip.Color(255 * brightness / 100, 0, 0);
Allcolor(red);
case 2: {
uint32_t orange = strip.Color(255 * brightness / 100, 40 * brightness / 100, 0);
Allcolor(orange);
case 3:{
uint32_t yellow = strip.Color(175 * brightness / 100, 100 * brightness / 100, 0);
Allcolor(yellow);
case 4: {
uint32_t green = strip.Color(0, 255 * brightness / 100, 0);
Allcolor(green);
case 5: {
uint32_t cyan = strip.Color(0, 175 * brightness / 100, 100 * brightness / 100);
Allcolor(cyan);
case 6:{
uint32_t blue = strip.Color(0, 0, 255 * brightness / 100);
Allcolor(blue);
case 7: {
uint32_t purple = strip.Color(80 * brightness / 100, 0, 100 * brightness / 100);
Allcolor(purple);
case 8: {
uint32_t violet = strip.Color(255 * brightness / 100, 0, 20 * brightness / 100);
Allcolor(pink);
case 9:{
uint32_t pink = strip.Color(255 * brightness / 100, 1 * brightness / 100, 10 * brightness / 100);
Allcolor(pink);
void Allcolor(uint32_t c) {
for(int i = 0; i < PIXEL_COUNT; i++ ) {
strip.setPixelColor(i, c);
strip.show();
Example of rainbow animation that I'd like to include:
#define PIN 6
#define NUM_LEDS 10
// Parameter 1 = number of pixels in strip
// Parameter 2 = pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
// NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
// NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
// NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
// NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, PIN, NEO_GRB + NEO_KHZ800);
strip.begin();
strip.show(); // Initialize all pixels to 'off'
// aqui
rainbowCycle(20);
void rainbowCycle(int SpeedDelay) {
byte *c;
uint16_t i, j;
for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
for(i=0; i< NUM_LEDS; i++) {
c=Wheel(((i * 256 / NUM_LEDS) + j) & 255);
setPixel(i, *c, *(c+1), *(c+2));
showStrip();
delay(SpeedDelay);
byte * Wheel(byte WheelPos) {
static byte c[3];
if(WheelPos < 85) {
c[0]=WheelPos * 3;
c[1]=255 - WheelPos * 3;
c[2]=0;
} else if(WheelPos < 170) {
WheelPos -= 85;
c[0]=255 - WheelPos * 3;
c[1]=0;
c[2]=WheelPos * 3;
WheelPos -= 170;
c[0]=0;
c[1]=WheelPos * 3;
c[2]=255 - WheelPos * 3;
return c;
// aqui
void showStrip() {
#ifdef ADAFRUIT_NEOPIXEL_H
// NeoPixel
strip.show();
#endif
#ifndef ADAFRUIT_NEOPIXEL_H
// FastLED
FastLED.show();
#endif
void setPixel(int Pixel, byte red, byte green, byte blue) {
// NeoPixel
strip.setPixelColor(Pixel, strip.Color(red, green, blue));
#endif
// FastLED
leds[Pixel].r = red;
leds[Pixel].g = green;
leds[Pixel].b = blue;
#endif
void setAll(byte red, byte green, byte blue) {
for(int i = 0; i < NUM_LEDS; i++ ) {
setPixel(i, red, green, blue);
showStrip();
Huge thanks in advance to anyone that could help me with this! <3
