Help me on project MPU9250 using Kalman Filter
hi, sorry my english is not good. I want to make a project MPU9250 using Kalman filter. I am using arduino nano for the microcontroller. I used the code from Kristian Lauszus, TKJ Electronics for MPU6050 KalmanFilter/MPU6050.ino at master · TKJElectronics/KalmanFilter · GitHub then I changed it for MPU9250. I want to ask about a lot of errors that I found in my code using the Arduino IDE when I tried to convert it for the MPU9250.
I am a beginner in coding like this. This is the code I made with the reference above.
#include <Kalman.h>
#include <MPU9250.h>
#define RESTRICT_PITCH
float kalmanX; // Create the Kalman instances
float kalmanY;
float kalmanZ;
/* IMU Data */
double accX, accY, accZ;
double gyroX, gyroY, gyroZ;
double magX, magY, magZ;
int16_t tempRaw;
double gyroXangle, gyroYangle, gyroZangle; // Angle calculate using the gyro only
double kalAngleX, kalAngleY, kalAngleZ; // Calculated angle using a Kalman filter
double roll;
double pitch;
double yaw;
double i2cData;
double i2cRead;
double setAngle;
double getAngle;
uint32_t timer;
uint8_t i2cData[14]; // Buffer for I2C data
// TODO: Make calibration routine
MPU9250 mpu;
  Wire.begin();
  TWBR = ((F_CPU / 400000L) - 16) / 2; // Set I2C frequency to 400kHz
  i2cData[0] = 7; // Set the sample rate to 1000Hz - 8kHz/(7+1) = 1000Hz
  i2cData[1] = 0x00; // Disable FSYNC and set 260 Hz Acc filtering, 256 Hz Gyro filtering, 8 KHz sampling
  i2cData[2] = 0x00; // Set Gyro Full Scale Range to ±250deg/s
  i2cData[3] = 0x00; // Set Accelerometer Full Scale Range to ±2g
  while (i2cData(0x19, i2cData, 4, false)); // Write to all four registers at once
  while (i2cData(0x6B, 0x01, true)); // PLL with X axis gyroscope reference and disable sleep mode
  while (i2cRead(0x75, i2cData, 1));
  if (i2cData[0] != 0x68) { // Read "WHO_AM_I" register
    Serial.print(F("Error reading sensor"));
    while (1);
  delay(100); // Wait for sensor to stabilize
  /* Set kalman and gyro starting angle */
  while (i2cRead(0x3B, i2cData, 6));
  accX = (i2cData[0] << 8);
  accY = (i2cData[2] << 8);
  accZ = (i2cData[4] << 8);
  // Source: http://www.freescale.com/files/sensors/doc/app_note/AN3461.pdf eq. 25 and eq. 26
  // atan2 outputs the value of -π to π (radians) - see http://en.wikipedia.org/wiki/Atan2
  // It is then converted from radians to degrees
  double roll  = atan2(accY, accZ);
  double pitch = atan2((accX),((accY*sin(roll)) + accZ*cos(roll)));
  double yaw = atan2( (magZ*sin(roll)-magY*cos(roll)) , ((magX*cos(pitch))+(magY*sin(pitch)*sin(roll))+magZ*sin(pitch)*cos(roll)) );
  kalmanX.setAngle(roll); // Set starting angle
  kalmanY.setAngle(pitch);
  kalmanZ.setAngle(yaw);
  gyroXangle = roll;
  gyroYangle = pitch;
  gyroZangle = yaw;
  compAngleX = roll;
  compAngleY = pitch;
  compAngleZ = yaw;
  timer = micros();
  while (i2cRead(0x3B, i2cData, 14));
  accX = ((i2cData[0] << 8) | i2cData[1]);
  accY = ((i2cData[2] << 8) | i2cData[3]);
  accZ = ((i2cData[4] << 8) | i2cData[5]);
  tempRaw = (i2cData[6] << 8) | i2cData[7];
  gyroX = (i2cData[8] << 8) | i2cData[9];
  gyroY = (i2cData[10] << 8) | i2cData[11];
  gyroZ = (i2cData[12] << 8) | i2cData[13];
  tempRaw = (i2cData[14] << 8) | i2cData[15];
  magX = (i2cData[16] << 8) | i2cData[17];
  magY = (i2cData[18] << 8) | i2cData[19];
  magZ = (i2cData[20] << 8) | i2cData[21];
  double dt = (double)(micros() - timer) / 1000000; // Calculate delta time
  timer = micros();
  double gyroXrate = gyroX / 131.0; // Convert to deg/s
  double gyroYrate = gyroY / 131.0; // Convert to deg/s
  double gyroZrate = gyroZ / 131.0; // Convert to deg/s
#ifdef RESTRICT_PITCH
  // This fixes the transition problem when the accelerometer angle jumps between -180 and 180 degrees
  if ((roll < -90 && kalAngleX > 90) || (roll > 90 && kalAngleX < -90)) {
    kalAngleX = roll;
    gyroXangle = roll;
  } else
    kalAngleX = kalmanX.getAngle(roll, gyroXrate, dt); // Calculate the angle using a Kalman filter
  if (abs(kalAngleX) > 90)
    gyroYrate = -gyroYrate; // Invert rate, so it fits the restriced accelerometer reading
  kalAngleY = kalmanY.getAngle(pitch, gyroYrate, dt);
  if ((pitch < -90 && kalAngleY > 90) || (pitch > 90 && kalAngleY < -90)) {
    kalAngleY = pitch;
    gyroYangle = pitch;
  } else
    kalAngleY = kalmanY.getAngle(pitch, gyroYrate, dt); // Calculate the angle using a Kalman filter
  if (abs(kalAngleY) > 90)
    gyroXrate = -gyroXrate; // Invert rate, so it fits the restriced accelerometer reading
    kalAngleZ  = yaw;
    gyroZangle = yaw;
  } else
    kalAngleZ = kalmanZ.getAngle(yaw, gyroZrate, dt); // Calculate the angle using a Kalman filter
  if (abs(kalAngleZ) > 90)
    gyroZrate = -gyroZrate; // Invert rate, so it fits the restriced accelerometer reading
  kalAngleZ = kalmanZ.getAngle(roll, gyroZrate, dt); // Calculate the angle using a Kalman filter
#endif
  gyroXangle += gyroXrate * dt; // Calculate gyro angle without any filter
  gyroYangle += gyroYrate * dt;
  gyroZangle += gyroZrate * dt;
  //gyroXangle += kalmanX.getRate() * dt; // Calculate gyro angle using the unbiased rate
  //gyroYangle += kalmanY.getRate() * dt;
  //gyroZangle += kalmanZ.getRate() * dt;
  compAngleX = 0.93 * (compAngleX + gyroXrate * dt) + 0.07 * roll; // Calculate the angle using a Complimentary filter
  compAngleY = 0.93 * (compAngleY + gyroYrate * dt) + 0.07 * pitch;
  compAngleZ = 0.93 * (compAngleZ + gyroZrate * dt) + 0.07 * yaw;
  // Reset the gyro angle when it has drifted too much
  if (gyroXangle < -180 || gyroXangle > 180)
    gyroXangle = kalAngleX;
  if (gyroYangle < -180 || gyroYangle > 180)
    gyroYangle = kalAngleY;
  if (gyroZangle < -180 || gyroZangle > 180)
    gyroZangle = kalAngleZ;
  /* Print Data */
#if 0 // Set to 1 to activate
  Serial.print(accX); Serial.print("\t");
  Serial.print(accY); Serial.print("\t");
  Serial.print(accZ); Serial.print("\t");
  Serial.print(gyroX); Serial.print("\t");
  Serial.print(gyroY); Serial.print("\t");
  Serial.print(gyroZ); Serial.print("\t");
  Serial.print(magX); Serial.print("\t");
  Serial.print(magY); Serial.print("\t");
  Serial.print(magZ); Serial.print("\t");
  Serial.print("\t");
#endif
  Serial.print(roll); Serial.print("\t");
  Serial.print(gyroXangle); Serial.print("\t");
  Serial.print(kalAngleX); Serial.print("\t");
  Serial.print("\t");
  Serial.print(pitch); Serial.print("\t");
  Serial.print(gyroYangle); Serial.print("\t");
  Serial.print(kalAngleY); Serial.print("\t");
  Serial.print("\t");
  Serial.print(yaw); Serial.print("\t");
  Serial.print(gyroZangle); Serial.print("\t");
  Serial.print(kalAngleZ); Serial.print("\t");
#if 0 // Set to 1 to print the temperature
  Serial.print("\t");
  double temperature = (double)tempRaw / 340.0 + 36.53;
  Serial.print(temperature); Serial.print("\t");
#endif
  Serial.print("\r\n");
  delay(2);
many thanks guys :slightly_smiling_face:
Images of error messages suck.
Include the entire error message. It is easy to do. There is a button (lower right of the IDE window) called "copy error message". Copy the error and paste into a post in code tags. Paraphrasing the error message leaves out important information.
Post a schematic.
Post an image of your project.
Which Micro Controller are you using?
Is this simulator code?
Please describe the problem better then you just did.
This is the error message from the Arduino IDE that I got:
Arduino: 1.8.19 (Windows 10), Board: "Arduino Nano, ATmega328P (Old Bootloader)"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\USER\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\USER\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\USER\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328old -vid-pid=0403_6001 -ide-version=10819 -build-path C:\Users\USER\AppData\Local\Temp\arduino_build_515392 -warnings=none -build-cache C:\Users\USER\AppData\Local\Temp\arduino_cache_343207 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\USER\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\USER\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avr-gcc.path=C:\Users\USER\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\USER\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=C:\Users\USER\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\USER\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -verbose D:\Kuliah\SIDANG TA TEPAT WAKTU YOK!\testing_MPU9250_KAALMAN\testing_MPU9250_KAALMAN.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\USER\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\USER\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\USER\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328old -vid-pid=0403_6001 -ide-version=10819 -build-path C:\Users\USER\AppData\Local\Temp\arduino_build_515392 -warnings=none -build-cache C:\Users\USER\AppData\Local\Temp\arduino_cache_343207 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\USER\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\USER\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avr-gcc.path=C:\Users\USER\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\USER\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=C:\Users\USER\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\USER\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -verbose D:\Kuliah\SIDANG TA TEPAT WAKTU YOK!\testing_MPU9250_KAALMAN\testing_MPU9250_KAALMAN.ino
Using board 'nano' from platform in folder: C:\Users\USER\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Using core 'arduino' from platform in folder: C:\Users\USER\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Detecting libraries used...
"C:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_515392\\sketch\\testing_MPU9250_KAALMAN.ino.cpp" -o nul
Alternatives for Kalman.h: [Kalman@1.1.0]
ResolveLibrary(Kalman.h)
  -> candidates: [Kalman@1.1.0]
"C:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-IC:\\Users\\USER\\Documents\\Arduino\\libraries\\Kalman" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_515392\\sketch\\testing_MPU9250_KAALMAN.ino.cpp" -o nul
Alternatives for BasicLinearAlgebra.h: [BasicLinearAlgebra@3.6]
ResolveLibrary(BasicLinearAlgebra.h)
  -> candidates: [BasicLinearAlgebra@3.6]
"C:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-IC:\\Users\\USER\\Documents\\Arduino\\libraries\\Kalman" "-IC:\\Users\\USER\\Documents\\Arduino\\libraries\\BasicLinearAlgebra" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_515392\\sketch\\testing_MPU9250_KAALMAN.ino.cpp" -o nul
Alternatives for MPU9250.h: [MPU9250@0.4.8]
ResolveLibrary(MPU9250.h)
  -> candidates: [MPU9250@0.4.8]
"C:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-IC:\\Users\\USER\\Documents\\Arduino\\libraries\\Kalman" "-IC:\\Users\\USER\\Documents\\Arduino\\libraries\\BasicLinearAlgebra" "-IC:\\Users\\USER\\Documents\\Arduino\\libraries\\MPU9250" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_515392\\sketch\\testing_MPU9250_KAALMAN.ino.cpp" -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
  -> candidates: [Wire@1.0]
"C:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-IC:\\Users\\USER\\Documents\\Arduino\\libraries\\Kalman" "-IC:\\Users\\USER\\Documents\\Arduino\\libraries\\BasicLinearAlgebra" "-IC:\\Users\\USER\\Documents\\Arduino\\libraries\\MPU9250" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_515392\\sketch\\testing_MPU9250_KAALMAN.ino.cpp" -o nul
"C:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-IC:\\Users\\USER\\Documents\\Arduino\\libraries\\Kalman" "-IC:\\Users\\USER\\Documents\\Arduino\\libraries\\BasicLinearAlgebra" "-IC:\\Users\\USER\\Documents\\Arduino\\libraries\\MPU9250" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "C:\\Users\\USER\\Documents\\Arduino\\libraries\\Kalman\\Kalman.cpp" -o nul
"C:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-IC:\\Users\\USER\\Documents\\Arduino\\libraries\\Kalman" "-IC:\\Users\\USER\\Documents\\Arduino\\libraries\\BasicLinearAlgebra" "-IC:\\Users\\USER\\Documents\\Arduino\\libraries\\MPU9250" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src\\Wire.cpp" -o nul
"C:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-IC:\\Users\\USER\\Documents\\Arduino\\libraries\\Kalman" "-IC:\\Users\\USER\\Documents\\Arduino\\libraries\\BasicLinearAlgebra" "-IC:\\Users\\USER\\Documents\\Arduino\\libraries\\MPU9250" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src\\utility\\twi.c" -o nul
Generating function prototypes...
"C:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-IC:\\Users\\USER\\Documents\\Arduino\\libraries\\Kalman" "-IC:\\Users\\USER\\Documents\\Arduino\\libraries\\BasicLinearAlgebra" "-IC:\\Users\\USER\\Documents\\Arduino\\libraries\\MPU9250" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_515392\\sketch\\testing_MPU9250_KAALMAN.ino.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_515392\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_515392\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-IC:\\Users\\USER\\Documents\\Arduino\\libraries\\Kalman" "-IC:\\Users\\USER\\Documents\\Arduino\\libraries\\BasicLinearAlgebra" "-IC:\\Users\\USER\\Documents\\Arduino\\libraries\\MPU9250" "-IC:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_515392\\sketch\\testing_MPU9250_KAALMAN.ino.cpp" -o "C:\\Users\\USER\\AppData\\Local\\Temp\\arduino_build_515392\\sketch\\testing_MPU9250_KAALMAN.ino.cpp.o"
testing_MPU9250_KAALMAN:48:19: error: conflicting declaration 'uint8_t i2cData [14]'
D:\Kuliah\SIDANG TA TEPAT WAKTU YOK!\testing_MPU9250_KAALMAN\testing_MPU9250_KAALMAN.ino:42:8: note: previous declaration as 'double i2cData'
 double i2cData;
I2C:37:71: error: 'uint8_t i2cRead(uint8_t, uint8_t*, uint8_t)' redeclared as different kind of symbol
 uint8_t i2cRead(uint8_t registerAddress, uint8_t *data, uint8_t nbytes) {
D:\Kuliah\SIDANG TA TEPAT WAKTU YOK!\testing_MPU9250_KAALMAN\testing_MPU9250_KAALMAN.ino:43:8: note: previous declaration 'double i2cRead'
 double i2cRead;
D:\Kuliah\SIDANG TA TEPAT WAKTU YOK!\testing_MPU9250_KAALMAN\testing_MPU9250_KAALMAN.ino: In function 'void setup()':
testing_MPU9250_KAALMAN:60:12: error: invalid types 'double[int]' for array subscript
testing_MPU9250_KAALMAN:61:12: error: invalid types 'double[int]' for array subscript
testing_MPU9250_KAALMAN:62:12: error: invalid types 'double[int]' for array subscript
testing_MPU9250_KAALMAN:63:12: error: invalid types 'double[int]' for array subscript
testing_MPU9250_KAALMAN:64:41: error: 'i2cData' cannot be used as a function
testing_MPU9250_KAALMAN:65:34: error: 'i2cData' cannot be used as a function
testing_MPU9250_KAALMAN:68:34: error: 'i2cRead' cannot be used as a function
testing_MPU9250_KAALMAN:69:16: error: invalid types 'double[int]' for array subscript
testing_MPU9250_KAALMAN:77:34: error: 'i2cRead' cannot be used as a function
testing_MPU9250_KAALMAN:78:20: error: invalid types 'double[int]' for array subscript
testing_MPU9250_KAALMAN:79:20: error: invalid types 'double[int]' for array subscript
testing_MPU9250_KAALMAN:80:20: error: invalid types 'double[int]' for array subscript
testing_MPU9250_KAALMAN:91:11: error: request for member 'setAngle' in 'kalmanX', which is of non-class type 'float'
testing_MPU9250_KAALMAN:92:11: error: request for member 'setAngle' in 'kalmanY', which is of non-class type 'float'
testing_MPU9250_KAALMAN:93:11: error: request for member 'setAngle' in 'kalmanZ', which is of non-class type 'float'
testing_MPU9250_KAALMAN:97:3: error: 'compAngleX' was not declared in this scope
   compAngleX = roll;
D:\Kuliah\SIDANG TA TEPAT WAKTU YOK!\testing_MPU9250_KAALMAN\testing_MPU9250_KAALMAN.ino:97:3: note: suggested alternative: 'kalAngleX'
   compAngleX = roll;
   kalAngleX
testing_MPU9250_KAALMAN:98:3: error: 'compAngleY' was not declared in this scope
   compAngleY = pitch;
D:\Kuliah\SIDANG TA TEPAT WAKTU YOK!\testing_MPU9250_KAALMAN\testing_MPU9250_KAALMAN.ino:98:3: note: suggested alternative: 'kalAngleY'
   compAngleY = pitch;
   kalAngleY
testing_MPU9250_KAALMAN:99:3: error: 'compAngleZ' was not declared in this scope
   compAngleZ = yaw;
D:\Kuliah\SIDANG TA TEPAT WAKTU YOK!\testing_MPU9250_KAALMAN\testing_MPU9250_KAALMAN.ino:99:3: note: suggested alternative: 'kalAngleZ'
   compAngleZ = yaw;
   kalAngleZ
D:\Kuliah\SIDANG TA TEPAT WAKTU YOK!\testing_MPU9250_KAALMAN\testing_MPU9250_KAALMAN.ino: In function 'void loop()':
testing_MPU9250_KAALMAN:105:35: error: 'i2cRead' cannot be used as a function
testing_MPU9250_KAALMAN:106:21: error: invalid types 'double[int]' for array subscript
testing_MPU9250_KAALMAN:106:40: error: invalid types 'double[int]' for array subscript
testing_MPU9250_KAALMAN:107:21: error: invalid types 'double[int]' for array subscript
testing_MPU9250_KAALMAN:107:40: error: invalid types 'double[int]' for array subscript
testing_MPU9250_KAALMAN:108:21: error: invalid types 'double[int]' for array subscript
testing_MPU9250_KAALMAN:108:40: error: invalid types 'double[int]' for array subscript
testing_MPU9250_KAALMAN:109:23: error: invalid types 'double[int]' for array subscript
testing_MPU9250_KAALMAN:109:42: error: invalid types 'double[int]' for array subscript
testing_MPU9250_KAALMAN:110:21: error: invalid types 'double[int]' for array subscript
testing_MPU9250_KAALMAN:110:40: error: invalid types 'double[int]' for array subscript
testing_MPU9250_KAALMAN:111:22: error: invalid types 'double[int]' for array subscript
testing_MPU9250_KAALMAN:111:42: error: invalid types 'double[int]' for array subscript
testing_MPU9250_KAALMAN:112:22: error: invalid types 'double[int]' for array subscript
testing_MPU9250_KAALMAN:112:42: error: invalid types 'double[int]' for array subscript
testing_MPU9250_KAALMAN:113:24: error: invalid types 'double[int]' for array subscript
testing_MPU9250_KAALMAN:113:44: error: invalid types 'double[int]' for array subscript
testing_MPU9250_KAALMAN:114:21: error: invalid types 'double[int]' for array subscript
testing_MPU9250_KAALMAN:114:41: error: invalid types 'double[int]' for array subscript
testing_MPU9250_KAALMAN:115:21: error: invalid types 'double[int]' for array subscript
testing_MPU9250_KAALMAN:115:41: error: invalid types 'double[int]' for array subscript
testing_MPU9250_KAALMAN:116:21: error: invalid types 'double[int]' for array subscript
testing_MPU9250_KAALMAN:116:41: error: invalid types 'double[int]' for array subscript
testing_MPU9250_KAALMAN:137:13: error: request for member 'setAngle' in 'kalmanX', which is of non-class type 'float'
testing_MPU9250_KAALMAN:141:25: error: request for member 'getAngle' in 'kalmanX', which is of non-class type 'float'
testing_MPU9250_KAALMAN:145:23: error: request for member 'getAngle' in 'kalmanY', which is of non-class type 'float'
testing_MPU9250_KAALMAN:147:1: error: 'else' without a previous 'if'
testing_MPU9250_KAALMAN:150:13: error: request for member 'setAngle' in 'kalmanY', which is of non-class type 'float'
testing_MPU9250_KAALMAN:154:25: error: request for member 'getAngle' in 'kalmanY', which is of non-class type 'float'
testing_MPU9250_KAALMAN:158:23: error: request for member 'getAngle' in 'kalmanX', which is of non-class type 'float'
testing_MPU9250_KAALMAN:160:1: error: 'else' without a previous 'if'
testing_MPU9250_KAALMAN:163:13: error: request for member 'setAngle' in 'kalmanZ', which is of non-class type 'float'
testing_MPU9250_KAALMAN:167:25: error: request for member 'getAngle' in 'kalmanZ', which is of non-class type 'float'
testing_MPU9250_KAALMAN:171:23: error: request for member 'getAngle' in 'kalmanZ', which is of non-class type 'float'
testing_MPU9250_KAALMAN:182:3: error: 'compAngleX' was not declared in this scope
D:\Kuliah\SIDANG TA TEPAT WAKTU YOK!\testing_MPU9250_KAALMAN\testing_MPU9250_KAALMAN.ino:182:3: note: suggested alternative: 'kalAngleX'
   kalAngleX
testing_MPU9250_KAALMAN:183:3: error: 'compAngleY' was not declared in this scope
D:\Kuliah\SIDANG TA TEPAT WAKTU YOK!\testing_MPU9250_KAALMAN\testing_MPU9250_KAALMAN.ino:183:3: note: suggested alternative: 'kalAngleY'
   kalAngleY
testing_MPU9250_KAALMAN:184:3: error: 'compAngleZ' was not declared in this scope
D:\Kuliah\SIDANG TA TEPAT WAKTU YOK!\testing_MPU9250_KAALMAN\testing_MPU9250_KAALMAN.ino:184:3: note: suggested alternative: 'kalAngleZ'
   kalAngleZ
D:\Kuliah\SIDANG TA TEPAT WAKTU YOK!\testing_MPU9250_KAALMAN\I2C.ino: In function 'uint8_t i2cRead(uint8_t, uint8_t*, uint8_t)':
 double i2cRead;
Using library Kalman at version 1.1.0 in folder: C:\Users\USER\Documents\Arduino\libraries\Kalman
Using library BasicLinearAlgebra at version 3.6 in folder: C:\Users\USER\Documents\Arduino\libraries\BasicLinearAlgebra
Using library MPU9250 at version 0.4.8 in folder: C:\Users\USER\Documents\Arduino\libraries\MPU9250
Using library Wire at version 1.0 in folder: C:\Users\USER\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire
exit status 1
Yes, this is simulator code. I'm using Arduino Nano ATMEGA328
The TKJ Electronics offering is not a Kalman filter, and doesn't work well, so don't bother with it.
Adafruit has a genuine Kalman filter for a different IMU, and that should not be too difficult to adapt to the obsolete, discontinued MPU-9250, if there is any point in doing so.
