Hello!
I'm trying to understand the MIDI keyboard code which I found one book. The code is below.
Please, could someone explain to me what does it mean when there is this line in the loop():
scanKeys(keyState[row + col + blk]);
I do understand that this a function called scanKeys, but I don't understand how it is used here.
And why there are always these keysState-statements in every case:
for example:
keyState[row + col + blk] = 1;
keyState[row + col + blk] = 0;
keyState[row + col + blk] = 2;
etc.
I'm wondering why these are used? What difference it makes if Arduino knows that the keyState is now keyState 1...or 2...or whatever...? I don't understand.
Thank you!
To read keys on a 25 note Fatar Keyboard using an 8x5=40 matrix, and
produce velocity sensitive MIDI Output
#include <math.h>
// define the pins we use
#define ROW0 14
#define ROW1 15
#define ROW2 16
#define ROW3 17
#define ROW4 18
#define ROW5 19
#define ROW6 20
#define ROW7 21
#define MK0 22
#define MK1 24
#define MK2 26
#define MK3 28
#define MK4 30
#define BR0 23
#define BR1 25
#define BR2 27
#define BR3 29
#define BR4 31
#define LedPin 13 // for midi out status
#define thresholdTime_max 2400
#define constrain_min 1
#define constrain_max 200
#define log_multiplier 25
int note;
byte noteOn = 0x90;
byte noteOff = 0x80;
byte firstNote = 36; // Note C2
byte channel = 0; // MIDI channel 1
byte velocityOn;
byte velocityOff;
int constrainTimeOn;
int constrainTimeOff;
double logTime1;
double logTime2;
int keyState[40];
int x, col, row, blk;
unsigned long startTime1[40];
unsigned long startTime2[40];
unsigned long startTimeOn;
unsigned long startTimeOff;
int MK[5] = { MK0, MK1, MK2, MK3, MK4};
int BR[5] = { BR0, BR1, BR2, BR3, BR4};
int ROW[8] = { ROW0, ROW1, ROW2, ROW3, ROW4, ROW5,
ROW6, ROW7};
for (x = 0; x < 8; x++) {
pinMode(ROW[x], INPUT_PULLUP);
for (x = 0; x < 5; x++) {
pinMode(MK[x], OUTPUT);
pinMode(BR[x], OUTPUT);
digitalWrite(MK[x], HIGH);
digitalWrite(BR[x], HIGH);
// initialize all to 0's
for (x = 0; x < 40; x++) {
startTime1[x] = 0;
startTime2[x] = 0;
keyState[x] = 0;
OnFlag[40] = 0;
pinMode(LedPin, OUTPUT);
Serial.begin(31250); // set serial baud rate
//----------------End of Setup-----------------
blk = 0;
for (col = 0; col < 5; col++) {
for (row = 0; row < 8; row++) {
blk = blk + 7;
//----------------End of main Loop-------------
//--------------Start of Functions-------------
void scanKeys(int var) {
switch (var) {
case 0:
digitalWrite(BR[col], LOW); // Switch BR ON
if (digitalRead(ROW[row]) == LOW) { // BR key is pressed
startTime1[row + col + blk] = millis();
digitalWrite(BR[col], HIGH); // Switch BR OFF
case 1:
if (digitalRead(ROW[row]) == HIGH) { //No key pressed
case 2:
digitalWrite(MK[col], LOW); // Switch MK ON
if (digitalRead(ROW[row]) == LOW) { // MK key is pressed
startTimeOn = millis() - startTime1[row + col + blk];
logTime1 = log_multiplier * log(startTimeOn);
if (startTimeOn > thresholdTime_max) {
digitalWrite(MK[col], HIGH); // Switch MK OFF
constrainTimeOn = constrain(logTime1, constrain_min,
constrain_max);
velocityOn = map(constrainTimeOn, constrain_min, constrain_max,
127, 1); // Linear Curve
note = row + col + blk;
midiSend(noteOn + channel , firstNote + note, velocityOn); // send
midi note on
keyState[row + col + blk] = 3;
case 3 :
if (digitalRead(ROW[row]) == HIGH) { // MK key is released
startTime2[row + col + blk] = millis();
keyState[row + col + blk] = 4;
case 4:
if (digitalRead(ROW[row]) == HIGH) { // BR key reached top
startTimeOff = millis() - startTime2[row + col + blk];
logTime2 = log_multiplier * log(startTimeOff);
constrainTimeOff = constrain(logTime2, constrain_min,
constrain_max);
velocityOff = map(constrainTimeOff, constrain_max,
constrain_min, 1, 127); // Linear Curve
midiSend(noteOff + channel, firstNote + note, velocityOff); // send
midi note off
default:
// Send a general MIDI message
void midiSend(byte cmd, byte data1, byte data2) {
digitalWrite(LedPin, HIGH); // indicate we're sending MIDI data
Serial.write(cmd);
Serial.write(data1);
Serial.write(data2);
digitalWrite(LedPin, LOW);
