Help me understand this phonecal example code for Elegoo 2.8" TFT shield
Please help me understand this example code for the TFT screen I bought. The library and example code came from Elegoo but it is virtually the same as the Adafruit library and example code. It is the phonecal.ino example program that shows a fake phone screen with buttons that when pressed on the touch screen makes the characters appear at the top. The code works perfectly on my hardware but I want to understand how. The code comments are lacking clarity for me.
My hardware
Screen on shield: https://a.co/61gGexz
Uno R3: Amazon.com
// IMPORTANT: Elegoo_TFTLCD LIBRARY MUST BE SPECIFICALLY
// CONFIGURED FOR EITHER THE TFT SHIELD OR THE BREAKOUT BOARD.
// SEE RELEVANT COMMENTS IN Elegoo_TFTLCD.h FOR SETUP.
//Technical support:goodtft@163.com
#include <Elegoo_GFX.h>    // Core graphics library
#include <Elegoo_TFTLCD.h> // Hardware-specific library
#include <TouchScreen.h>
// The control pins for the LCD can be assigned to any digital or
// analog pins...but we'll use the analog pins as this allows us to
// double up the pins with the touch screen (see the TFT paint example).
#define LCD_CS A3 // Chip Select goes to Analog 3
#define LCD_CD A2 // Command/Data goes to Analog 2
#define LCD_WR A1 // LCD Write goes to Analog 1
#define LCD_RD A0 // LCD Read goes to Analog 0
#define LCD_RESET A4 // Can alternately just connect to Arduino's reset pin
// When using the BREAKOUT BOARD only, use these 8 data lines to the LCD:
// For the Arduino Uno, Duemilanove, Diecimila, etc.:
//   D0 connects to digital pin 8  (Notice these are
//   D1 connects to digital pin 9   NOT in order!)
//   D2 connects to digital pin 2
//   D3 connects to digital pin 3
//   D4 connects to digital pin 4
//   D5 connects to digital pin 5
//   D6 connects to digital pin 6
//   D7 connects to digital pin 7
// For the Arduino Mega, use digital pins 22 through 29
// (on the 2-row header at the end of the board).
// Assign human-readable names to some common 16-bit color values:
#define	BLACK   0x0000
#define	BLUE    0x001F
#define	RED     0xF800
#define	GREEN   0x07E0
#define CYAN    0x07FF
#define MAGENTA 0xF81F
#define YELLOW  0xFFE0
#define WHITE   0xFFFF
// Color definitions
#define ILI9341_BLACK       0x0000      /*   0,   0,   0 */
#define ILI9341_NAVY        0x000F      /*   0,   0, 128 */
#define ILI9341_DARKGREEN   0x03E0      /*   0, 128,   0 */
#define ILI9341_DARKCYAN    0x03EF      /*   0, 128, 128 */
#define ILI9341_MAROON      0x7800      /* 128,   0,   0 */
#define ILI9341_PURPLE      0x780F      /* 128,   0, 128 */
#define ILI9341_OLIVE       0x7BE0      /* 128, 128,   0 */
#define ILI9341_LIGHTGREY   0xC618      /* 192, 192, 192 */
#define ILI9341_DARKGREY    0x7BEF      /* 128, 128, 128 */
#define ILI9341_BLUE        0x001F      /*   0,   0, 255 */
#define ILI9341_GREEN       0x07E0      /*   0, 255,   0 */
#define ILI9341_CYAN        0x07FF      /*   0, 255, 255 */
#define ILI9341_RED         0xF800      /* 255,   0,   0 */
#define ILI9341_MAGENTA     0xF81F      /* 255,   0, 255 */
#define ILI9341_YELLOW      0xFFE0      /* 255, 255,   0 */
#define ILI9341_WHITE       0xFFFF      /* 255, 255, 255 */
#define ILI9341_ORANGE      0xFD20      /* 255, 165,   0 */
#define ILI9341_GREENYELLOW 0xAFE5      /* 173, 255,  47 */
#define ILI9341_PINK        0xF81F
/******************* UI details */
#define BUTTON_X 40
#define BUTTON_Y 100
#define BUTTON_W 60
#define BUTTON_H 30
#define BUTTON_SPACING_X 20
#define BUTTON_SPACING_Y 20
#define BUTTON_TEXTSIZE 2
// text box where numbers go
#define TEXT_X 10
#define TEXT_Y 10
#define TEXT_W 220
#define TEXT_H 50
#define TEXT_TSIZE 3
#define TEXT_TCOLOR ILI9341_MAGENTA
// the data (phone #) we store in the textfield
#define TEXT_LEN 12
char textfield[TEXT_LEN+1] = "";
uint8_t textfield_i=0;
#define YP A3  // must be an analog pin, use "An" notation!
#define XM A2  // must be an analog pin, use "An" notation!
#define YM 9   // can be a digital pin
#define XP 8   // can be a digital pin
//Touch For New ILI9341 TP
#define TS_MINX 120
#define TS_MAXX 900
#define TS_MINY 70
#define TS_MAXY 920
// We have a status line for like, is FONA working
#define STATUS_X 10
#define STATUS_Y 65
Elegoo_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
// If using the shield, all control and data lines are fixed, and
// a simpler declaration can optionally be used:
// Elegoo_TFTLCD tft;
Elegoo_GFX_Button buttons[15];
/* create 15 buttons, in classic candybar phone style */
char buttonlabels[15][5] = {"Send", "Clr", "End", "1", "2", "3", "4", "5", "6", "7", "8", "9", "*", "0", "#" };
uint16_t buttoncolors[15] = {ILI9341_DARKGREEN, ILI9341_DARKGREY, ILI9341_RED,
                             ILI9341_BLUE, ILI9341_BLUE, ILI9341_BLUE,
                             ILI9341_ORANGE, ILI9341_BLUE, ILI9341_ORANGE};
void setup(void) {
  Serial.println(F("TFT LCD test"));
#ifdef USE_Elegoo_SHIELD_PINOUT
  Serial.println(F("Using Elegoo 2.8\" TFT Arduino Shield Pinout"));
#else
  Serial.println(F("Using Elegoo 2.8\" TFT Breakout Board Pinout"));
#endif
  Serial.print("TFT size is "); Serial.print(tft.width()); Serial.print("x"); Serial.println(tft.height());
  tft.reset();
  uint16_t identifier = tft.readID();
  if(identifier == 0x9325) {
    Serial.println(F("Found ILI9325 LCD driver"));
  } else if(identifier == 0x9328) {
    Serial.println(F("Found ILI9328 LCD driver"));
  } else if(identifier == 0x4535) {
    Serial.println(F("Found LGDP4535 LCD driver"));
  }else if(identifier == 0x7575) {
    Serial.println(F("Found HX8347G LCD driver"));
  } else if(identifier == 0x9341) {
    Serial.println(F("Found ILI9341 LCD driver"));
  } else if(identifier == 0x8357) {
    Serial.println(F("Found HX8357D LCD driver"));
  } else if(identifier==0x0101)
      identifier=0x9341;
       Serial.println(F("Found 0x9341 LCD driver"));
  }else {
    Serial.print(F("Unknown LCD driver chip: "));
    Serial.println(identifier, HEX);
    Serial.println(F("If using the Elegoo 2.8\" TFT Arduino shield, the line:"));
    Serial.println(F("  #define USE_Elegoo_SHIELD_PINOUT"));
    Serial.println(F("should appear in the library header (Elegoo_TFT.h)."));
    Serial.println(F("If using the breakout board, it should NOT be #defined!"));
    Serial.println(F("Also if using the breakout, double-check that all wiring"));
    Serial.println(F("matches the tutorial."));
    identifier=0x9341;
  tft.begin(identifier);
  tft.setRotation(2);
  tft.fillScreen(BLACK);
  // create buttons
  for (uint8_t row=0; row<5; row++) {
    for (uint8_t col=0; col<3; col++) {
      buttons[col + row*3].initButton(&tft, BUTTON_X+col*(BUTTON_W+BUTTON_SPACING_X),
                 BUTTON_Y+row*(BUTTON_H+BUTTON_SPACING_Y),    // x, y, w, h, outline, fill, text
                  BUTTON_W, BUTTON_H, ILI9341_WHITE, buttoncolors[col+row*3], ILI9341_WHITE,
                  buttonlabels[col + row*3], BUTTON_TEXTSIZE);
      buttons[col + row*3].drawButton();
  // create 'text field'
  tft.drawRect(TEXT_X, TEXT_Y, TEXT_W, TEXT_H, ILI9341_WHITE);
// Print something in the mini status bar with either flashstring
void status(const __FlashStringHelper *msg) {
  tft.fillRect(STATUS_X, STATUS_Y, 240, 8, ILI9341_BLACK);
  tft.setCursor(STATUS_X, STATUS_Y);
  tft.setTextColor(ILI9341_WHITE);
  tft.setTextSize(1);
  tft.print(msg);
// or charstring
void status(char *msg) {
  tft.setTextSize(1);
  tft.print(msg);
#define MINPRESSURE 10
#define MAXPRESSURE 1000
void loop(void) {
  /*TSPoint p;
  p = ts.getPoint();
  digitalWrite(13, HIGH);
  TSPoint p = ts.getPoint();
  digitalWrite(13, LOW);
  // if sharing pins, you'll need to fix the directions of the touchscreen pins
  //pinMode(XP, OUTPUT);
  pinMode(XM, OUTPUT);
  pinMode(YP, OUTPUT);
  //pinMode(YM, OUTPUT);
  // we have some minimum pressure we consider 'valid'
  // pressure of 0 means no pressing!
 // p = ts.getPoint();
  if (ts.bufferSize()) {
    // this is our way of tracking touch 'release'!
    p.x = p.y = p.z = -1;
  // Scale from ~0->4000 to tft.width using the calibration #'s
  if (p.z != -1) {
    p.x = map(p.x, TS_MINX, TS_MAXX, 0, tft.width());
    p.y = map(p.y, TS_MINY, TS_MAXY, 0, tft.height());
    Serial.print("("); Serial.print(p.x); Serial.print(", ");
    Serial.print(p.y); Serial.print(", ");
    Serial.print(p.z); Serial.println(") ");
   if (p.z > MINPRESSURE && p.z < MAXPRESSURE) {
    // scale from 0->1023 to tft.width
    p.x = map(p.x, TS_MINX, TS_MAXX, tft.width(), 0);
    p.y = (tft.height()-map(p.y, TS_MINY, TS_MAXY, tft.height(), 0));
  // go thru all the buttons, checking if they were pressed
  for (uint8_t b=0; b<15; b++) {
    if (buttons[b].contains(p.x, p.y)) {
      //Serial.print("Pressing: "); Serial.println(b);
      buttons[b].press(true);  // tell the button it is pressed
      buttons[b].press(false);  // tell the button it is NOT pressed
  // now we can ask the buttons if their state has changed
    if (buttons[b].justReleased()) {
      // Serial.print("Released: "); Serial.println(b);
      buttons[b].drawButton();  // draw normal
    if (buttons[b].justPressed()) {
        buttons[b].drawButton(true);  // draw invert!
        // if a numberpad button, append the relevant # to the textfield
        if (b >= 3) {
          if (textfield_i < TEXT_LEN) {
            textfield[textfield_i] = buttonlabels[b][0];
            textfield_i++;
	    textfield[textfield_i] = 0; // zero terminate
           // fona.playDTMF(buttonlabels[b][0]);
        // clr button! delete char
        if (b == 1) {
          if (textfield > 0) {
            textfield_i--;
            textfield[textfield_i] = ' ';
        // update the current text field
        Serial.println(textfield);
        tft.setCursor(TEXT_X + 2, TEXT_Y+10);
        tft.setTextColor(TEXT_TCOLOR, ILI9341_BLACK);
        tft.setTextSize(TEXT_TSIZE);
        tft.print(textfield);
        // its always OK to just hang up
        if (b == 2) {
          status(F("Hanging up"));
          //fona.hangUp();
        // we dont really check that the text field makes sense
        // just try to call
        if (b == 0) {
          status(F("Calling"));
          Serial.print("Calling "); Serial.print(textfield);
          //fona.callPhone(textfield);
      delay(100); // UI debouncing
At line 234 there is an if statement that checks if the pressure p.z meets the threshold to be a screen touch. If met, the coordinates of the touch are scaled to match the screen resolution. OK so far. What I don't understand is at line 241 there is a for loop that checks if buttons were pressed, but this is outside the if statement above. So what prevents unscaled touch x and y coordinates that don't meet the pressure threshold from causing the wrong buttons being assigned as pressed? The code works but I don't understand how. Lines 234-248 shown below:
I see what you mean. I suspect the reason it works is "luck". The unscaled coordinates are maybe up one corner of the display where there happens to be no button. Or maybe they are way off the screen somewhere, so, again, don't match a button. It's doesn't seem to be the best-written code.
Yeah you would think example code would be more exemplary. I modified this example code to make my program and when mine was having some problems with random buttons being pushed I looked at the code more carefully and found this.
I tried using UTFT libraries from Rinky Dink Electronics but their example code with libraries was too big for the Uno flash memory. Their libraries looks to be simpler to use. I am going to put addressable LED lights on my golf cart and I want to be able to control different patterns, brightness, and turn on and off. A touch screen seems like an fairly easy way to do all of this without a bunch of physical buttons but at this point wiring in buttons would have been quicker.
I was able to get my similar program working by scaling all of the touch sensor coordinates, then checking for pressure threshold within the for loop and if statement that checks if each button contains the current point.
This scaling is different than the example because my screen is in landscape mode. I didn't bother to fix the phonecal example program but hopefully this helps anyone else with the same question I had.
    // scale from 0->1023 to tft.dimensions. It gets a little funky here because in this orientation the x and y of the
    //display and touch sensor are swapped and reversed direction
    int mappedpx = map(p.y, TS_MINY, TS_MAXY,tft.width(),0);
    int mappedpy = map(p.x, TS_MINX, TS_MAXX,tft.height(),0);
    p.x=mappedpx;
    p.y=mappedpy;
  for (uint8_t b=0; b<14; b++) {
    if ((buttons[b].contains(p.x, p.y))&& (p.z > MINPRESSURE && p.z < MAXPRESSURE)){
      Serial.print(" Pressing: "); Serial.print(b);Serial.print(", x= "); Serial.print(p.x);Serial.print(", y= "); Serial.println(p.y);
      lastbuttonpressed=b;
