hello i am trying to modify a code in arduino .... i want to be able read analog pins (that is ok) and to write on digital pin (this where i need help) ... everything has to run through max msp
if somebody is patient maybe he could describe a bit why it does not work
here is what i modified... (oh yeah ... i am new to all this)
- Arduino2Max
- Send pin values from Arduino to MAX/MSP
- Arduino2Max.pde
- This version: .4, October 2007
- Copyleft: use as you like
- by Daniel Jolliffe
- Based on a sketch and patch by Thomas Ouellet Fredericks tof.danslchamp.org
int x = 0; // a place to hold pin values
int ledpin = 13;
Serial.begin(115200); // 115200 is the default Arduino Bluetooth speed
digitalWrite(13,HIGH); ///startup blink
delay(600);
digitalWrite(13,LOW);
pinMode(13,INPUT);
if (Serial.available() > 0){ // Check serial buffer for characters
if (Serial.read() == 'r') { // If an 'r' is received then read the pins
if (Serial.write() == 'w') {
for (int pin= 0; pin<=5; pin++){ // Read and send analog pins 0-5
x = analogRead(pin);
sendValue (x);
for (int pin= 2; pin<=7; pin++){ // Read and send digital pins 2-7
x = digitalRead(pin);
sendValue (x);
for (int pin= 8; pin<=12; pin++){ // write and recieve digital pins 8-12
y = digitalwrite(pin);
receiveValue (y);
Serial.println(); // Send a carriage returnt to mark end of pin data.
delay (5); // add a delay to prevent crashing/overloading of the serial port
void sendValue (int x){ // function to send the pin value followed by a "space".
Serial.print(x);
Serial.print(32, BYTE);
