Help not should 18650 discharge tester
Hi all this is the first time on here and this is my first time using arduino I hace 3 of them,one I/O expansion broad, and a Smraza 2004 LCD Display Module that I would like to use for this..
I looking for help I'm working on a battery tester using Nano:::, Nano I/O Expansion Sensor Shield for Arduino UNO R1 Nano 3.0 Duemilanove 2009...amazon:::https://www.amazon.com/HiLetgo-Expansion-Sensor-Arduino-Duemilanove/dp/B00OLBDXC6/ref=sr_1_2?dchild=1&keywords=HiLetgo+Nano+I%2FO+Expansion+Sensor+Shield+for+Arduino+UNO+R1+Nano+3.0+Duemilanove+2009&qid=1599775674&sr=8-2
Smraza 2004 LCD Display Module (20 Characters x 4 Lines) Compatible with Arduino R3 MEGA2560 Nano
18650 Battery Case Holder, 4 Slots
Ok here what I'm trying to do make 1 using 8 cell not 16channel DIY Arduino 18650 Li-ion Battery Capacity tester using code is base off of this person
https://ev-north.co.uk/wp/2018/04/12/18650-discharge-tester/
but only for the 8 cell but he didn't give must information on the circuit drawing is no help there so I got the next 1 for some help
also 3x 18650 battery test at https://www.instructables.com/id/3-X-18650-Battery-Capacity-Tester/
the 1 for the base circuit drawing which will help now for the code I try this 1 here here which I try to mod to work but will not upload to the Nano
so can some out there help...
Dig up the codes and display here, using code tags. I don't spend time hunting and downloading them.
The circuit for testing is not 100% correct. Battory capacity is measured by pulling a defined current, capacity Ah/10, out of the battory. Then a 4R resistor will not give the same discharge current all the time.
If you post your code as described in
How to use this forum - please read,
more members will read it.
