Help on how to use a LEONARDO as a "game pad"
I've checked a few of the suggestions offered when I typed in the subject, but none really helped.
I have been told that the Leonardo is the one I want as it works better as a HID (game pad - if you will) than the others.
I have also seen a hack to allow use of an analogue joystick using the Leonardo.
The scenario is that I have a game and the key map is confusing at best.
As I have other hardware plugged in, I can assign their buttons to control things by selecting what I want to do, then when prompted, press the desired button and it is assigned to control that thing.
It shows up as a game controller rather than key press, so that is even better.
But I'm new to this sort of thing and so have no idea what is involved.
I'm guessing I tell the Arduino it is a Game controller and assign pins as inputs.
I don't know if there is much to that or not, but for now let's say there isn't too much in making that part work.
Then I would plug it in, load the game and in the config section where I assign key inputs, I would then click on what I want to be controlled, get prompted to press the button and press one of the buttons connected to the Leonardo.
And that's that.
Or so I hope.
Would someone mind helping me understand what I need to do?
As I explained my understand is this:
I tell the Leonardo to be a game pad configure/program the GPIO pins as inputs (pull_up needed I'm guessing) and put a switch to pull the GPIO pins low.
Then when it is plugged in, the game will accept it's inputs to control things.
Thanks in advance.
