2nd topic. Following on from the very helpful assistance from @xfpd and @time_document_3108 to get my Elecrow Automatic Smart Plant Watering project working, I am now seeking help in adding some code to improve the system. The project is based around an Arduino Leonardo (UNO also mentioned in manual) 'Crowtail Smart Pump Shield'. Details on this wiki: Elecrow wiki
At present the system works by sensing moisture levels and triggering the pump on <30% and off >55%. This is fine if the water is pumped directly onto or very close to the sensor. If however the water is pumped away from the sensor it takes time for the water to migrate through the soil to the sensor. Thus the pump will be running continuously for this time and the plant will be massively over-watered.
What I would like to do is introduce a pump duration and delay element into the code. When triggered by the moisture sensor the pump should run for a specified time and then wait for a specified time before reading the sensor again. This loop would then cater for all placements of the sensor. In my case, I'm looking at installing this system in a greenhouse to water an irrigation tray. Water should be added remotely from the sensor to allow the capillary matting to absorb water uniformly.
I'm aware that delay code stops the entire program, so need a different way of timing the pump rest period as the system needs to loop round the 4 independent sensor/pump combos. I've read up on the 'blink without delay' workaround, but will need help implementing something like this.
There appears to be redundant code in the project at present, with references to days of the week and RTC timing, but with no way of controlling these that I have discovered. There is also redundant code from when the developers used resistive sensors rather than capacitive.
Any help writing this code or pointing me towards useful help would be much appreciated. I did offer feedback and request assistance from Elecrow customer services and, while they were very grateful for my ideas (don't zip inside zip inside zip...!), they were unable to offer assistance with development of the code. It should be clear from what I've written that I don't really know what I'm talking about! I'm brand new to Arduino and code, though understand MS Excel programming. Please be gentle and give simple instructions! Thank you!
As we discovered in my earlier topic, the code is well hidden inside multiple zip files, so here is the fully unpacked and working code, once Arduino library versions of U8glib and RTC are installed:
#include <U8glib.h>
U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_NONE); // I2C
#include "RTClib.h"
RTC_DS1307 RTC;
// set all moisture sensors PIN ID
int moisture1 = A0;
int moisture2 = A1;
int moisture3 = A2;
int moisture4 = A3;
// declare moisture values
int moisture1_value = 0 ;
int moisture2_value = 0;
int moisture3_value = 0;
int moisture4_value = 0;
// set water relays
int relay1 = 6;
int relay2 = 8;
int relay3 = 9;
int relay4 = 10;
// set water pump
int pump = 4;
// set button
int button = 12;
//pump state 1:open 0:close
int pump_state_flag = 0;
//relay1 state 1:open 0:close
int relay1_state_flag = 0;
//relay2 state 1:open 0:close
int relay2_state_flag = 0;
//relay3 state 1:open 0:close
int relay3_state_flag = 0;
//relay4 state 1:open 0:close
int relay4_state_flag = 0;
static unsigned long currentMillis_send = 0;
static unsigned long Lasttime_send = 0;
char daysOfTheWeek[7][12] = {"Sun", "Mon", "Tues", "Wed", "Thur", "Fri", "Sat",};
unsigned long nowtime;
unsigned long endtime;
unsigned long nowtimeNext;
unsigned long nowtime1;
unsigned long endtime1;
unsigned long nowtimeNext1;
unsigned long nowtime2;
unsigned long endtime2;
unsigned long nowtimeNext2;
unsigned long nowtime3;
unsigned long endtime3;
unsigned long nowtimeNext3;
// good flower
unsigned char bitmap_good[] U8G_PROGMEM = {
0x00, 0x42, 0x4C, 0x00, 0x00, 0xE6, 0x6E, 0x00, 0x00, 0xAE, 0x7B, 0x00, 0x00, 0x3A, 0x51, 0x00,
0x00, 0x12, 0x40, 0x00, 0x00, 0x02, 0x40, 0x00, 0x00, 0x06, 0x40, 0x00, 0x00, 0x06, 0x40, 0x00,
0x00, 0x04, 0x60, 0x00, 0x00, 0x0C, 0x20, 0x00, 0x00, 0x08, 0x30, 0x00, 0x00, 0x18, 0x18, 0x00,
0x00, 0xE0, 0x0F, 0x00, 0x00, 0x80, 0x01, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x01, 0x00,
0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x02, 0xC1, 0x00, 0x00, 0x0E, 0x61, 0x00,
0x00, 0x1C, 0x79, 0x00, 0x00, 0x34, 0x29, 0x00, 0x00, 0x28, 0x35, 0x00, 0x00, 0x48, 0x17, 0x00,
0x00, 0xD8, 0x1B, 0x00, 0x00, 0x90, 0x1B, 0x00, 0x00, 0xB0, 0x09, 0x00, 0x00, 0xA0, 0x05, 0x00,
0x00, 0xE0, 0x07, 0x00, 0x00, 0xC0, 0x03, 0x00
// bad flower
unsigned char bitmap_bad[] U8G_PROGMEM = {
0x00, 0x80, 0x00, 0x00, 0x00, 0xC0, 0x00, 0x00, 0x00, 0xE0, 0x0D, 0x00, 0x00, 0xA0, 0x0F, 0x00,
0x00, 0x20, 0x69, 0x00, 0x00, 0x10, 0x78, 0x02, 0x00, 0x10, 0xC0, 0x03, 0x00, 0x10, 0xC0, 0x03,
0x00, 0x10, 0x00, 0x01, 0x00, 0x10, 0x80, 0x00, 0x00, 0x10, 0xC0, 0x00, 0x00, 0x30, 0x60, 0x00,
0x00, 0x60, 0x30, 0x00, 0x00, 0xC0, 0x1F, 0x00, 0x00, 0x60, 0x07, 0x00, 0x00, 0x60, 0x00, 0x00,
0x00, 0x60, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00,
0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0xC7, 0x1C, 0x00,
0x80, 0x68, 0x66, 0x00, 0xC0, 0x33, 0x7B, 0x00, 0x40, 0xB6, 0x4D, 0x00, 0x00, 0xE8, 0x06, 0x00,
0x00, 0xF0, 0x03, 0x00, 0x00, 0xE0, 0x00, 0x00
// Elecrow Logo
static unsigned char bitmap_logo[] U8G_PROGMEM ={
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0xE0,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x04,0xF8,0xFF,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x08,0xFE,0xFF,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x10,0x1F,0xE0,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0xB0,0x07,0x80,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0xE0,0x03,0x00,0x3F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0xC0,0x00,0x00,0x3E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x80,0x01,0x00,0x7E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x60,0x23,0x00,0x7C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x70,0xC7,0x00,0x7E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x70,0x9E,0x0F,0x7F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x70,0x3C,0xFE,0x7F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x70,0x78,0xF8,0x7F,0xF0,0x9F,0x07,0xFE,0x83,0x0F,0xFF,0x00,0x77,0x3C,0x18,0x1C,
0x70,0xF0,0xE1,0x3F,0xF1,0x9F,0x07,0xFE,0xE1,0x1F,0xFF,0xC3,0xF7,0x3C,0x38,0x0C,
0x70,0xE0,0x87,0x8F,0xF1,0xC0,0x07,0x1E,0x70,0x3C,0xCF,0xE3,0xE1,0x7D,0x3C,0x0E,
0x70,0xD0,0x1F,0xC0,0xF1,0xC0,0x03,0x1F,0x78,0x3C,0xCF,0xE3,0xE1,0x7D,0x3C,0x06,
0xF0,0xB0,0xFF,0xF1,0xF0,0xC0,0x03,0x0F,0x78,0x3C,0xCF,0xF3,0xE0,0x7B,0x3E,0x06,
0xF0,0x60,0xFF,0xFF,0xF0,0xC6,0x03,0xEF,0x3C,0x80,0xEF,0xF1,0xE0,0x7B,0x3E,0x03,
0xF0,0xE1,0xFC,0xFF,0xF8,0xCF,0x03,0xFF,0x3C,0x80,0xFF,0xF0,0xE0,0x7B,0x7B,0x01,
0xE0,0xC3,0xF9,0x7F,0x78,0xC0,0x03,0x0F,0x3C,0x80,0xF7,0xF1,0xE0,0xF9,0xF9,0x01,
0xE0,0x83,0xE3,0x7F,0x78,0xE0,0x03,0x0F,0x3C,0xBC,0xE7,0xF1,0xE0,0xF9,0xF9,0x00,
0xC0,0x0F,0x8F,0x3F,0x78,0xE0,0x81,0x0F,0x3C,0x9E,0xE7,0xF1,0xE0,0xF1,0xF8,0x00,
0x80,0x3F,0x1E,0x00,0x78,0xE0,0x81,0x07,0x38,0x9E,0xE7,0xF1,0xF0,0xF0,0x78,0x00,
0x80,0xFF,0xFF,0x00,0xF8,0xEF,0xBF,0xFF,0xF8,0xCF,0xE7,0xE1,0x7F,0x70,0x70,0x00,
0x00,0xFF,0xFF,0x0F,0xF8,0xEF,0xBF,0xFF,0xE0,0xC3,0xE3,0x81,0x1F,0x70,0x30,0x00,
0x00,0xFC,0xFF,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0xF8,0xFF,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0xE0,0x7F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
static unsigned char bitmap_T[] U8G_PROGMEM = {
0xF7, 0x01, 0x1D, 0x03, 0x0B, 0x02, 0x0C, 0x02, 0x0C, 0x00, 0x0C, 0x00, 0x0C, 0x00, 0x08, 0x02,
0x18, 0x03, 0xF0, 0x01
static unsigned char bitmap_H[] U8G_PROGMEM = {
0x00, 0x00, 0x80, 0x01, 0xC0, 0x03, 0xE0, 0x07, 0xF0, 0x0F, 0xF8, 0x1F, 0xF8, 0x1F, 0xFC, 0x3F,
0xFC, 0x3F, 0xFE, 0x7F, 0xEE, 0x7F, 0xB3, 0xF7, 0xBB, 0xFB, 0xBB, 0xFD, 0xBB, 0xFD, 0xC7, 0xFE,
0x7F, 0xC3, 0x3F, 0xDD, 0xBF, 0xFD, 0xDF, 0xDD, 0xEE, 0x5B, 0xFE, 0x7F, 0xFC, 0x3F, 0xF8, 0x1F,
0xE0, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
draw_elecrow();
delay(2000);
Wire.begin();
RTC.begin();
// declare relay as output
pinMode(relay1, OUTPUT);
pinMode(relay2, OUTPUT);
pinMode(relay3, OUTPUT);
pinMode(relay4, OUTPUT);
// declare pump as output
pinMode(pump, OUTPUT);
// declare switch as input
pinMode(button, INPUT);
//pinMode(ROTARY_ANGLE_SENSOR, INPUT);
// water_flower();
// read the value from the moisture sensors:
read_value();
water_flower();
int button_state = digitalRead(button);
if (button_state == 1)
read_value();
u8g.firstPage();
do
drawTH();
drawflower();
} while ( u8g.nextPage() );
u8g.firstPage();
do
drawtime();
u8g.drawStr(8, 55 , "www.elecrow.com");
} while (u8g.nextPage());
//Set moisture value
void read_value()
/**************These is for resistor moisture sensor***********
float value1 = analogRead(A0);
moisture1_value = (value1 * 120) / 1023; delay(20);
float value2 = analogRead(A1);
moisture2_value = (value2 * 120) / 1023; delay(20);
float value3 = analogRead(A2);
moisture3_value = (value3 * 120) / 1023; delay(20);
float value4 = analogRead(A3);
moisture4_value = (value4 * 120) / 1023; delay(20);
/************These is for capacity moisture sensor*********/
moisture1_value =map(value1,590,360,0,100); delay(20);
if(moisture1_value<0){
moisture1_value=0;
moisture2_value =map(value2,600,360,0,100); delay(20);
if(moisture2_value<0) {
moisture2_value=0;
moisture3_value =map(value3,600,360,0,100); delay(20);
if(moisture3_value<0){
moisture3_value=0;
moisture4_value =map(value4,600,360,0,100); delay(20);
if(moisture4_value<0) {
moisture4_value=0;
void water_flower()
if (moisture1_value < 30)
digitalWrite(relay1, HIGH);
relay1_state_flag = 1;
delay(50);
if (pump_state_flag == 0)
digitalWrite(pump, HIGH);
pump_state_flag = 1;
delay(50);
else if (moisture1_value > 55)
digitalWrite(relay1, LOW);
delay(50);
if ((relay1_state_flag == 0) && (relay2_state_flag == 0) && (relay3_state_flag == 0) && (relay4_state_flag == 0))
digitalWrite(pump, LOW);
delay(50);
if (moisture2_value < 30)
digitalWrite(relay2, HIGH);
relay2_state_flag = 1;
delay(50);
delay(50);
else if (moisture2_value > 55)
digitalWrite(relay2, LOW);
delay(50);
delay(50);
if (moisture3_value < 30)
digitalWrite(relay3, HIGH);
relay3_state_flag = 1;
delay(50);
delay(50);
else if (moisture3_value > 55)
digitalWrite(relay3, LOW);
delay(50);
delay(50);
if (moisture4_value < 30)
digitalWrite(relay4, HIGH);
relay4_state_flag = 1;
delay(50);
delay(50);
else if (moisture4_value > 55)
digitalWrite(relay4, LOW);
delay(50);
delay(50);
void draw_elecrow(void){
u8g.setFont(u8g_font_gdr9r);
u8g.drawStr(8,55 , "www.elecrow.com");
u8g.drawXBMP(0, 5,128,32, bitmap_logo);
void drawtime(void)
int x = 5;
float i = 25.00;
float j = 54;
DateTime now = RTC.now();
//Serial.print(now.year(), DEC);
if (! RTC.isrunning())
u8g.setFont(u8g_font_6x10);
u8g.setPrintPos(5, 20);
u8g.print("RTC is NOT running!");
RTC.adjust(DateTime(__DATE__, __TIME__));
u8g.setFont(u8g_font_7x13);
u8g.setPrintPos(x, 11);
u8g.print(now.year(), DEC);
u8g.setPrintPos(x + 80, 11);
u8g.print(daysOfTheWeek[now.dayOfTheWeek()]);
u8g.setPrintPos(x + 28, 11);
u8g.print("/");
u8g.setPrintPos(x + 33, 11);
u8g.print(now.month(), DEC);
if (now.month() < 10)
x -= 7;
u8g.setPrintPos(x + 47, 11);
u8g.print("/");
u8g.setPrintPos(x + 53, 11);
u8g.print(now.day(), DEC);
u8g.setFont(u8g_font_8x13);
int x = 35;
u8g.setPrintPos(x, 33);
u8g.print(now.hour(), DEC);
if (now.hour() < 10)
x -= 7;
u8g.setPrintPos(x + 15, 33);
u8g.print(":");
u8g.setPrintPos(x + 21, 33);
u8g.print(now.minute(), DEC);
if (now.minute() < 10)
x -= 7;
u8g.setPrintPos(x + 36, 33);
u8g.print(":");
u8g.setPrintPos(x + 42, 33);
u8g.print(now.second(), DEC);
void drawLogo(uint8_t d)
u8g.setFont(u8g_font_gdr25r);
u8g.drawStr(8 + d, 30 + d, "E");
u8g.drawStr(30 + d, 30 + d, "l");
u8g.drawStr(40 + d, 30 + d, "e");
u8g.drawStr(55 + d, 30 + d, "c");
u8g.drawStr(70 + d, 30 + d, "r");
u8g.drawStr(85 + d, 30 + d, "o");
u8g.drawStr(100 + d, 30 + d, "w");
//Style the flowers bitmap_bad: bad flowers bitmap_good:good flowers
void drawflower(void)
u8g.drawXBMP(0, 0, 32, 30, bitmap_bad);
u8g.drawXBMP(0, 0, 32, 30, bitmap_good);
u8g.drawXBMP(32, 0, 32, 30, bitmap_bad);
u8g.drawXBMP(32, 0, 32, 30, bitmap_good);
u8g.drawXBMP(64, 0, 32, 30, bitmap_bad);
u8g.drawXBMP(64, 0, 32, 30, bitmap_good);
u8g.drawXBMP(96, 0, 32, 30, bitmap_bad);
u8g.drawXBMP(96, 0, 32, 30, bitmap_good);
void drawTH(void)
int A = 0;
int B = 0;
int C = 64;
int D = 96;
char moisture1_value_temp[5] = {0};
char moisture2_value_temp[5] = {0};
char moisture3_value_temp[5] = {0};
char moisture4_value_temp[5] = {0};
read_value();
itoa(moisture1_value, moisture1_value_temp, 10);
itoa(moisture2_value, moisture2_value_temp, 10);
itoa(moisture3_value, moisture3_value_temp, 10);
itoa(moisture4_value, moisture4_value_temp, 10);
u8g.setFont(u8g_font_7x14);
u8g.setPrintPos(9, 60);
u8g.print("A0");
if (moisture1_value < 10)
//u8g.setPrintPos(A + 14, 45 );
u8g.drawStr(A + 14, 45, moisture1_value_temp);
delay(20);
else if (moisture1_value < 100)
//u8g.setPrintPos(A + 7, 45);
u8g.drawStr(A + 7, 45, moisture1_value_temp);
delay(20);
//u8g.setPrintPos(A + 2, 45 );
moisture1_value = 100;
u8g.drawStr(A + 2, 45, moisture1_value_temp);
//u8g.print(moisture1_value);
u8g.setPrintPos(A + 23, 45 );
u8g.print("%");
u8g.setPrintPos(41, 60 );
u8g.print("A1");
if (moisture2_value < 10)
//u8g.setPrintPos(B + 46, 45 );
u8g.drawStr(B + 46, 45, moisture2_value_temp);
delay(20);
else if (moisture2_value < 100)
//u8g.setPrintPos(B + 39, 45);
u8g.drawStr(B + 39, 45, moisture2_value_temp);
delay(20);
//u8g.setPrintPos(B + 32, 45);
moisture2_value = 100;
u8g.drawStr(B + 32, 45, moisture2_value_temp);
// u8g.print(moisture2_value);
u8g.setPrintPos(B + 54, 45);
u8g.print("%");
u8g.setPrintPos(73, 60);
u8g.print("A2");
if (moisture3_value < 10)
//u8g.setPrintPos(C + 14, 45 );
u8g.drawStr(C + 14, 45, moisture3_value_temp);
delay(20);
else if (moisture3_value < 100)
// u8g.setPrintPos(C + 7, 45);
u8g.drawStr(C + 7, 45, moisture3_value_temp);
delay(20);
// u8g.setPrintPos(C + 2, 45);
moisture3_value = 100;
u8g.drawStr(C + 2, 45, moisture3_value_temp);
//u8g.print(moisture3_value);
u8g.setPrintPos(C + 23, 45);
u8g.print("%");
u8g.setPrintPos(105, 60);
u8g.print("A3");
if (moisture4_value < 10)
//u8g.setPrintPos(D + 14, 45 );
u8g.drawStr(D + 14, 45, moisture4_value_temp);
delay(20);
else if (moisture4_value < 100)
// u8g.setPrintPos(D + 7, 45);
u8g.drawStr(D + 7, 45, moisture4_value_temp);
delay(20);
//u8g.setPrintPos(D + 2, 45);
moisture4_value = 100;
u8g.drawStr(D + 2, 45, moisture4_value_temp);
//u8g.print(moisture4_value);
u8g.setPrintPos(D + 23, 45);
u8g.print("%");
