Help regarding Two Arduino Rx Tx Serial communication!
Need help regarding Tx Arduino with integer "25" and "32" to Rx Arduino.
/* Tx Arduino sending integer "25", "32" to Rx Arduino
Sketch modified from YouTube
https://www.youtube.com/watch?v=sSJ_GcaNrVU&t=4s
#include <SoftwareSerial.h>
SoftwareSerial softSerial(10,11);
int data1, data2, data3, data4;
  Serial.println("Tx Arduino");
  softSerial.begin(9600); // enable Tx
    data1 = 25;
    data2 = 32;
 softSerial.print(data1);      softSerial.print("A");
 softSerial.print(data2);      softSerial.print("B");
 softSerial.println("\n");
    Serial.print("    ");
  	softSerial.write("\n");
    softSerial.write(data1);
	delay (1500);
// Rx Arduino receiving integer "25", "32" from Tx Arduino
SoftwareSerial softSerial(2,3);
char c;
String dataIn;
int8_t indexOfA, indexOfB, indexOfC, indexOfD;
String data1, data2, data3, data4;
void setup(){
  Serial.println("Rx Arduino");
void loop(){
  while(softSerial.available()>0)   {
    c = softSerial.read();
      if(c=='\n') {break;}
      else        {dataIn+=c;}
  if(c=='\n')    {
      Serial.println("Serial Available");
      Parse_the_Data();
      Serial.println("Data1 = " + data1);
      Serial.println("Data2 = " + data2);
      Serial.println("===============================================");
    // Reset Values
      c=0;
      dataIn="";
void Parse_the_Data()	{
  indexOfA = dataIn.indexOf("A");
  indexOfB = dataIn.indexOf("B");
  data1  = dataIn.substring(0, indexOfA);
  data2  = dataIn.substring(indexOfA+1, indexOfB);
// Using Tinkercad for doing so.
  • Please expand on your situation.
  • Always show us a good schematic of your proposed circuit.
    Show us good images of your ‘actual’ wiring.
  • In the Arduino IDE, use Ctrl T or CMD T to format your code then copy the complete sketch.
    Use the < CODE / > icon from the ‘posting menu’ to attach the copied sketch.
Example 5 seems to be what you're after
https://forum.arduino.cc/t/serial-input-basics-updated/382007/3
That's the wiring.
Hi. Thanx for responding.
I edited the OP to depict the Sketch.
BTW
  • An integer is two bytes.
  • Where did you find this syntax ?
    Okay, you are using String
  • Pin 2 and 3 are already the hardware serial pins
Yes. As per the YouTube video of having numbers from Tx Arduino to Rx Arduino.
I am duplicating the YouTube with just 4 of 12 data input.
The Serial Monitor is not matching the YouTube, sadly!
I think you should write this to YouTube comment section. Am I wrong?
Keeping the same set, I went for a string "Hello World"
NOT the Sketch modified from YouTube
    data1 = 25;
    data2 = 32;
// Instead of sending "25" and "32" instead sending string
// softSerial.print(data1);      softSerial.print("A");
// softSerial.print(data2);      softSerial.print("B");
// softSerial.println("\n");
softSerial.println("Hello from Tx Arduino!");
    Serial.print("    ");
	delay (5000);
/* Rx Arduino receiving string from Tx Arduino
Project sketch based upon
https://www.makeuseof.com/arduino-mastering-serial-communication/
void setup(){
  if (softSerial.available() > 0) {
    String incomingData = softSerial.readString();
    Serial.println(incomingData);
    Serial.println("------------------");
  delay(5000);
The outcome
Tx Arduino
25
25
25 ... (etc)
Rx Arduino
Hello ærom ª¼
ɑե¹½…
¤²‹ë2ÉýÕAª¡º°º´··†…
Hållo fr·[¢áÁrduino!
So is that sketch all right or Tinkercad is not doing it right?
It can be connection issue. Try changing the cables. Also check this out:
