I’ve recently started using Arduino and I get the basics. One of my projects is to make a Simon Says game using the Ultrasonic Sensor, so far I’ve written down the code. The led light works and the ultrasonic sensor tracks my hand movement perfectly. The thing I left out of the code is the part I’m having a hard time figuring out, that’s the sequence of random patterns you press (in this case your hand movements) to move forward to a different random pattern.
Here’s the Code:
#define trigPin 7
#define echoPin 6
#define led 13
#define led2 12
#define led3 11
#define led4 10
#define led5 9
#define led6 8
#define led7 6
#define led8 5
#define buzzer 3
int sound = 250;
Serial.begin (9600);
randomSeed(analogRead(0));
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(led, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
pinMode(led4, OUTPUT);
pinMode(led5, OUTPUT);
pinMode(led6, OUTPUT);
pinMode(led7, OUTPUT);
pinMode(led8, OUTPUT);
pinMode(buzzer, OUTPUT);
const unsigned long measure_distance() {
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(5);
pinMode(trigPin, INPUT);
return pulseIn(trigPin, HIGH);
unsigned long duration, distance;
delayMicroseconds(10);
duration = measure_distance();
distance = (duration/2) / 29.1;
Serial.println("Distance: " + distance);
if (distance <= 40) {
digitalWrite(led, HIGH);
sound = 261;
else {
digitalWrite(led,LOW);
if (distance < 35) {
digitalWrite(led2, HIGH);
sound = 294;
else {
digitalWrite(led2, LOW);
if (distance < 30) {
digitalWrite(led3, HIGH);
sound = 329;
else {
digitalWrite(led3, LOW);
if (distance < 25) {
digitalWrite(led4, HIGH);
sound = 349;
else {
digitalWrite(led4,LOW);
if (distance < 20) {
digitalWrite(led5, HIGH);
sound = 392;
else {
digitalWrite(led5,LOW);
if (distance < 15) {
digitalWrite(led6, HIGH);
sound = 440;
else {
digitalWrite(led6,LOW);
if (distance < 10) {
digitalWrite(led7, HIGH);
sound = 493;
else {
digitalWrite(led7,LOW);
if (distance < 5) {
digitalWrite(led8, HIGH);
sound = 523;
else {
digitalWrite(led8,LOW);
if (distance > 40 || distance <= 0){
Serial.println("Out of range");
noTone(buzzer);
else {
Serial.print(distance);
Serial.println(" cm");
tone(buzzer, sound);
delay(300);
