Ajeb22
February 21, 2020, 11:42am
1
hello i want to ask about this program on arduino UNO
//Test DDRB
#define LEDMASK 0x01
unsigned char *portDDRB;
portDDRB = (unsigned char *)0x24;
*portDDRB |= LEDMASK;
unsigned char *portB;
portB = (unsigned char *)0x25;
*portB |= LEDMASK;
delay(2000);
*portB &= (~LEDMASK);
when i run this i though port 10 and 13 always on(from 0x25) and port 8 will be switch between on atau off, but i somehow it onlyworked on port 8. port 10 and 13 is always off with this code, what did i miss?
gcjr:
what is "DDRB"?
DDRB - Data Direction Register for Port-B of ATmega328P MCU. When we place HIGH at DDRB0-position, the corresponding port line (the PB0) of Port-B works as an output line. The Arduino code is: pinMode(8, OUTPUT);. The following diagram (shown for a bit-2 of Port-D) may help to understand the role of DDRX (X = B, C, D) Register.
If you used the predefined macros for the registers (PORTB, DDRB, PINB) etc, you'd get the correct volatile qualifications for free.
I don't think I'll ever understand this style of programming
Please post the actual code that you used to drive pin 10 or 13.
Ajeb22
February 21, 2020, 2:32pm
6
aarg:
that's all of the code
did you mean this? from what i understand from these line is it is used to set pin 10 and 13 as output then
set pin 10 and 13 as high
No,those lines are simply setting up the pointers to the registers.
Ajeb22:
Then you do not understand. Pin 10 and 13 would be set with:
#define LEDMASK 0x24
TheMemberFormerlyKnownAsAWOL:
Is there any register named portDDRB in the ATmega328P?
GolamMostafa:
No, but that's OK, because it is simply a variable the OP invented.
volatile unsigned char* portDDRB = (unsigned char*) 0x24;
volatile unsigned char* portB = (unsigned char*) 0x25;
const unsigned char LED_MASK = 0x20; // bit 5, pin 13
*portDDRB |= LED_MASK;
*portB |= LED_MASK;
delay (2000);
*portB &= ~LED_MASK;
delay (1000);
(compiled and tested on Duemilanove/168)
Or, alternatively
volatile unsigned char* portINB = (unsigned char*) 0x23;
*portINB = LED_MASK;
delay (500);
delay (500);
That two lines of codes do not set the direction of DPin-13 as output (verified in UNO).
GolamMostafa:
No-one (except perhaps the OP) ever said that they did.
See reply #6
The OP is setting up his own variables to point to the registers, instead of using the predefined DDRB and PORTB. LEDMASK is the variable that specifies which specific ports to set as output and turn on/off.
Ajeb22
February 21, 2020, 5:58pm
14
i think i get it now, thank you!
the truth is this is not my code, i just found and try to understand it cause i never try those kind of i/o
