Help using melody..
Hi all,
Me and my friend are fiddling around with the melody example, but we cant get this tune to play properly... heres the code:
int speakerPin = 9;
int length = 80; // the number of notes
char notes[] = "GFEF GFEG DEa aEFGFCDEaG  GFEF aGFEE GE Fa EFGECDE aDEGFED abCGFEED "; // a space represents a rest
int beats[] = { 1, 1, 2, 1, 1, 1, 1, 2, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 3, 1, 1, 1, 1, 2, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 2, 1, };
//Above is the beats the note palys for
int tempo = 50;
void playTone(int tone, int duration) {
  for (long i = 0; i < duration * 1000L; i += tone * 2) {
    digitalWrite(speakerPin, HIGH);
    delayMicroseconds(tone);
    digitalWrite(speakerPin, LOW);
void playNote(char note, int duration) {
  char names[] = { 'c', 'd', 'e', 'f', 'g', 'a', 'b', 'C', 'D', 'E', 'F', 'G', 'A', 'B' };
  int tones[] = { 1915, 1700, 1519, 1432, 1275, 1136, 1014, 956, 587, 659, 698, 784, 880, 988 };
  // play the tone corresponding to the note name
  for (int i = 0; i < 8; i++) {
    if (names[i] == note) {
      playTone(tones[i], duration);
  pinMode(speakerPin, OUTPUT);
  for (int i = 0; i < length; i++) {
    if (notes[i] == ' ') {
      delay(beats[i] * tempo); // rest
      playNote(notes[i], beats[i] * tempo);
    // pause between notes
    delay(tempo / 2);
Any ideas?
Maybe this helps?
[UNTESTED CODE]
byte speakerPin = 9;
byte length = 80; // the number of notes
char notes[] = "GFEF GFEG DEa aEFGFCDEaG  GF EF aGFEE GE Fa EFGECDE aDEGFED abCGFEED      "; // a space represents a rest
byte beats[] = { 1, 1, 2, 1, 1, 1, 1, 2, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 3, 1, 1, 1, 1, 2, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 2, 1 }; //81*2 = 162 bytes with int 81 bytes with bytes
unsigned int tones[] = { 1915, 1700, 1519, 1432, 1275, 1136, 1014, 956, 587, 659, 698, 784, 880, 988 };
byte tempo = 50;
  for (int i = 0; i < 14; i++) {
    delay(tempo / 2);
Okay its a lot better but it still freezes at a point towards the end BTW this is the song im trying to do http://www.steamgames.com/v/img/whatsnew/StillAlive.pdf
and the code is:
char notes[] = "GFEEF   GFEEG DEa  aEFGFCDEaaaG   GFEEF  aGFEE GE Fa   EFGECDE aDEGFED  abCGFEED          "; // a space represents a rest
byte beats[] = { 1, 1, 2, 1, 1, 1, 1, 2, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 3, 1, 1, 1, 1, 2, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1 }; //81*2 = 162 bytes with int 81 bytes with bytes
//Above is the beats the note plays for
byte tempo = 900;
    delay(tempo / 2);
It works for me, although I did make the following change when I noticed the length was not being set to the actual number of notes
const byte length = sizeof(notes); // the number of notes
byte beats[length] = { 1, 1, 2, 1, 1, 1, 1, 2, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 3, 1, 1, 1, 1, 2, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1 };
Thank you very much works a lot better now, it doesnt get stuck on that note.. :slight_smile: :slight_smile:
