Help wiring 5 pin LED Button
Hi I need help wiring this 5 pin LED toggle button, I want the button to activate when I press it and the LED to turn on only when pressed. I have tried many wiring configurations like in the screenshot I attached but no matter what I do, either the LED is on and turns off when I
press the button or the led works as I want but the button doesn't activate.
btw I am using mobiflight to control the buttons as I am building a button box for msfs.
Many thanks
Hi @kaddom101 ,
usually the letters on the switch back indicate this:
  • C = Common
  • NC = Normally Connected
  • NO = Normally Open
C is connected to
  • NC when switched "off"
  • NO when switched "on"
The other two pins are used for GND and Vcc of the integrated Led.
I assume that the led has already an internal resistor to limit the current.
If you use the button with pinMode INPUT_PULLUP you will have to switch the GPIO to GND to detect LOW that signalizes the "on" state.
In this case you could wire as follows:
  • C to GND
  • NC - left open
  • NO to the gpio Pin and to Led GND (Led -)
  • Led (+) to Vcc
Check or make sure that the button has an integrated resistor to limit the current. Otherwise you should add one externally to avoid damage to the led, the Arduino or both ...
Good luck!
ec2021
If the button is switched on GND will be connected to the pin and Led (-)
Thank you so much ec2021, it works perfectly now, I really appreciate the help and quick response have a great day!
