hi people, hope your all good,
so my next project that i would like to do is looking a bit tricky and was wondering if i could get some help.
so i am looking to create what is effectively a digital thermostat using relays to control AC on and off determined by a threshold with a tolerance of 1 maybe 2 degrees. for example if i set that i want it at 30 degrees if it reaches 1 or 2 degrees over then it will turn off and the same for under 30.
i would like to be able to change the desired temp up and down using buttons.
eventually i would like to be able to make it talk to an app on ios and andriod but thats not key yet.
the main issue i am having is the coding. was wondering if anyone could shed some light.
so to recap and put all the things i want to start with.
input temp sensor
16x2 or 20x4 lcd driven with i2c
output to relay to then turn on and off relay. depending on the temp.
where do i start lol
any help would be greatly appreciated.
Kind Regards
Marc
