So I have the following code with which I am controlling a stepper (with a dvr8825 driver) and an led (with a pwm operated led driver):
const int M0 = 22;
const int M1 = 24;
const int M2 = 26;
const int stepPin = 28;
const int dirPin = 30;
int ledcontrol = 9;
#include <AccelStepper.h>
AccelStepper stepper(AccelStepper::DRIVER, stepPin, dirPin);
pinMode(M0,OUTPUT);
pinMode(M1,OUTPUT);
pinMode(M2,OUTPUT);
digitalWrite(M0,HIGH);
digitalWrite(M1,HIGH);
digitalWrite(M2,HIGH);
stepper.setMaxSpeed(10000);
stepper.setSpeed(100);
analogWrite(ledcontrol, 200);
stepper.runSpeed();
my idea is to have the stepper running at speed = 100 for 2000 miliseconds
then accelerate it to speed = 1000 for 2000 miliseconds
then deaccelerate it back to speed 100
how can I achieve that?
I have another example where I use acceleration, but I dont really know how to apply all of this to achieve my goal...
const int M10 = 22;
const int M11 = 24;
const int M12 = 26;
const int stepPin1 = 28;
const int dirPin1 = 30;
int velocidad = 20;
AccelStepper stepper1(AccelStepper::DRIVER, stepPin1, dirPin1);
pinMode(M10,OUTPUT);
pinMode(M11,OUTPUT);
pinMode(M12,OUTPUT);
digitalWrite(M10,LOW);
digitalWrite(M11,LOW);
digitalWrite(M12,LOW);
stepper1.setMaxSpeed(velocidad);
stepper1.setAcceleration(5);
stepper1.moveTo(__LONG_MAX__ / 2);
stepper1.run();
if ( millis() > change_speed )//time to change
if(speed == high )// switch to low speed
change_speed = millis() + 2000;//next change at ….
set and run at low speed;
speed =low;
else//switch from high to low
set and run at high speed;
speed =high;
} //end of changing
}// end of loop
The AccelStepper is not designed for using acceleration between one speed and another. To use the acceleration you need to specify a number of steps and it will move from standstill to standstill accelerating and decelerating smoothly.
It is not difficult to write you own code to do acceleration without using the library. Have a look at the code in this link
This illustrates a way to make a stepper change speed and acceleration without stopping using the AccelStepper library. I set the motor to run a (very) long distance. The motor will stop when it reaches the distance so adjust distance for the total duration you want. Then, periodically, change the speed and accel using arrarys to store the sequence. I made adjustments for my setup in the pin assignments. Fix as required.
// stepper sequencing example C Goulding
// turn on a stepper and let it run at while changing speed and accel at designated times.
const byte stepperEnablePin = 8; // required for my CNC shield
const byte unsigned long numBusySteps = 100000; // get the motor to run reduce for shoter run
// put the sequence of times, speeds ann accels here
const long times[] = {2000, 5000, 3000, 2000};
const long speeds[] = {0, 100, 1000, 2000};
const long accels[] = {50, 500, 500, 500};
unsigned int timesArraySize = 0; // this is taken care of later
AccelStepper stepper;
timesArraySize = sizeof(times) / sizeof(times[0]);
pinMode(stepperEnablePin, OUTPUT);
digitalWrite(stepperEnablePin, LOW);
stepper.setMaxSpeed(100);
stepper.setAcceleration(200);
static unsigned long changeTimer = 0;
static unsigned long changeInterval = 10;
static unsigned int moveIndex = 0;
stepper.moveTo(numBusySteps); // tell it to go a looong way.
if (millis() - changeTimer >= changeInterval)
changeTimer = millis();
changeInterval = times[moveIndex];
stepper.setMaxSpeed(speeds[moveIndex]);
stepper.setAcceleration(accels[moveIndex]);
moveIndex++;
if (moveIndex > timesArraySize)
moveIndex = 0;
stepper.run();
groundFungus:
Did you try the code? Is that action what you were after?
I have just tried it. em... not really. I identify 3 different movements; slow spinning, acceleration and something else. But at the moment of something else, I can only hear the stepper working but it doesnt spin. so no, definitely not what I am after.
As I said before also, this coding is much more than what I can handle. Which is also a very good thing to start improving my coding.
In the meantime, I got a nice code for this matter in the accelstepper google group. I think this is easier for me to understand and also manipulate...
const int M0 = 22;
const int M1 = 24;
const int M2 = 26;
int ledcontrol = 9;
enum state_t : uint8_t {
STATE_IDLE = 0,
STATE_CONST = 1,
STATE_ACCEL = 2,
STATE_DECEL = 3,
STATE_DONE = 4
uint32_t time_start = 0L;
uint32_t time_speed_last = 0L; //time of last speed update in accelerated movements
uint8_t state = STATE_IDLE;
pinMode(M0, OUTPUT);
pinMode(M1, OUTPUT);
pinMode(M2, OUTPUT);
digitalWrite(M0, HIGH);
digitalWrite(M1, HIGH);
digitalWrite(M2, HIGH);
stepper.setAcceleration(450.0f);
time_start = millis();
state = STATE_CONST;
//if 2000ms have passed since the stepper started its constant speed movement
if ((state == STATE_CONST) && (millis() - time_start > 5000))
//start accelerated movement
state = STATE_ACCEL;
time_speed_last = millis();
if (state == STATE_ACCEL)
//update stepper motor speed every 10 ms
if (millis() - time_speed_last >= 10)
stepper.setSpeed(stepper.speed() + 4.5f);
if (stepper.speed() >= 2000.0f)
state = STATE_DECEL;
if (state == STATE_DECEL)
stepper.setSpeed(stepper.speed() - 4.5f);
if (stepper.speed() <= 100.0f)
stepper.runSpeed();
