Help with Adafruit SH1106 Library and OLED screen
Hello I have this library working GitHub - wonho-maker/Adafruit_SH1106: Adafruit graphic library for SH1106 dirver lcds. but it uses up quite a bit of memory. Is there any way I can trim down the code to remove anything thats not required.
I only need this library to write text, nothing fancy.
Sketch uses 20,922 bytes (64%) of program storage space. Maximum is 32,256 bytes.
Global variables use 1,585 bytes (77%) of dynamic memory, leaving 463 bytes for local variables. Maximum is 2,048 bytes.
Low memory available, stability problems may occur.
Thanks
It is said that the IDE (or compiler) only compiles or links what is needed. A simple test seems to prove that but I'm not 100% sure if I did it correctly. I don't have the GFX library installed so can't test your scenario.
I created a sketch and added two files (simulating a library); this 'library' contained two functions and in the sketch I only used one of them. Removing the non-used function from the 'library' did not make a difference in the memory (flash and ram) usage.
You can easily try it yourself by removing a function (that you don't need) from the library's cpp file and check the result.
The library needs a buffer to hold one bit per pixel. If you have a 128 x 64 pixel display, it needs 1024 bytes of memory to hold that data. There is NO way that you can reduce that.
Thanks for the tips, I've managed to trim it down enough to use it in my project.
Cheers
