Help With Arduino UNO R3
I am working in a mode 1
  • Mode 1: USB Serial connected to ATMega328 for both programming and serial communication
  • Mode 2: USB Serial connected to ESP8266 for programming
  • Mode 3: USB Serial connected to ESP8266 for serial communication
  • Mode 4: ATMega328 and ESP8266 serial connected together for serial communication
Now i want to send a data from uno r3 to my website is that possible if yes how can i do that i need help regarding this for my college project
Issue is how i can connect uno R3 with my home wifi
The UNO uses 5 volt level of signals. The ESP usuallly uses 3.3 volt. Don't send 5 volt signals to a 3.3 volt device without level shifting. Sending 3.3 volt signals to a 5 volt device is okey.
@Railroader
I think OP has one of those boards that have an ESP8266 integrated on an Uno board. So level conversions should be catered for.
Let's ask him/her
@webydev Please tell us exactly which Arduino board you have
OP is using ESP8266 whose IO pins are practically tolerant to 5V logic; hence, it can be directly connected with UNOR3 without level shifters.
So not completely tolerant to 5V then
We have to use level shifter! (But, I operate without level shifter.)
Warning from Google:
ESP8266 pins are generally not considered 5V tolerant; while some evidence suggests they might tolerate a slightly higher voltage than their 3.3V operating voltage, directly connecting them to a 5V source can potentially damage the chip, so it's best practice to use a voltage divider when interfacing with 5V circuits.
As far as I know it's a myth that was debunked by Espressif.
Post a picture of your board.
  • You need proper hardware to do this.
  • The least expensive (less than $10.00) and most efficient way is to use a ESP32 using a WIFI connection and hosting the WEB page.
This is the board i am using what i want to do is just send a data to a website from this board this is a custom board with atmega326 + esp8266
I followed this video
@GolamMostafa @UKHeliBob
Thanks for messaging...
Waiting for your reply
1. I assume that you have a Router in your home.
2. You have a semperature sensor (DS18B20) connected with UNOR3.
3. You want to transfer the temperaure data from UNOR3 to your ESP8266 using (say) UART Port.
4. Your ESP8266 as a Server will use its built-in WiFi to send the temperature data to your Mobile Phone via the Router.
5. Your Mobile Phone will monitor temperature as a Client.
Are you expecting to build a Project like above?
For clarification, your topic title refers to a Uno R3 but that is not the board that you have
It is a custom board with board ATMEGA and ESP8266
My Idea is to make a data sending from this board showing in the above images with my router to the website
So it is not the board that you posted pictures of
Please post a schematic of your actual board
@UKHeliBob Please check this image for the schematic
That is not an image of your custom board nor is it a schematic
@UKHeliBob Then i am really sorry i don't have apart from this
ATmega328p + ESP8266 i have both the chips in my board if you want i can provide you more clear images
You previously said
Who designed and built it and where did you get it from ?
@UKHeliBob
I am using this one
