Hi there, im having a bit of trouble with a project, using a Arduino Uno and an adafruit motor shield and a stepper motor.
here is my sketch so far
#include <AFMotor.h>
// Connect a stepper motor with 72 steps per revolution (5 degree)
// to motor port #1 (M1 and M2)
AF_Stepper motor(72, 1);
const int PotPin = A0;         // Change this if pot is connected to another pin
const int goPin = 2;           //the pin that the go switch is connected to
                               // this is switching digital pin 2 from High to Low
const int redPin = A2;         // the pin for the RED LED
const int bluePin = A4;        // the pin for the BLUE LED
int direction = FORWARD;       // Where we are going
int speed = 0;                 // How fast
int potVal = 0;                // Current potvalue
int goState = 0;              //current state of the goPin
   pinMode (goPin, INPUT);
   pinMode (redPin, OUTPUT);
   pinMode (bluePin, OUTPUT);
   Serial.begin(9600);         // initialize serial communication at 9600 bits per second:
   while (!Serial) { ;         // wait for serial port to connect. Needed for Leonardo only
  potVal = analogRead(PotPin);   // read the input on the pot:
  goState = digitalRead (goPin);
  if (potVal < 510)
    direction = FORWARD;        // Smaller than 512 so we're going forward
    speed = map(potVal, 0, 511, 20, 1);  // Map value from pot-range to motorspeed-range
  else if (potVal > 513)
  {                             // Otherwise, we're going backward
    direction = BACKWARD;
    speed = map(potVal, 512, 1024, 1, 20);
                                // print out the variables:
  Serial.print("GoPin:  ");
  Serial.print(goState  );
  Serial.print(" POT Value: ");
  Serial.print(potVal);
  Serial.print(" direction: ");
 if (direction==FORWARD)
    Serial.print("Forward");
    Serial.print("Backward");
    Serial.print(" Speed: ");
    Serial.println(speed);   // End of line, so also make it go a line
  // make motor go a step
  motor.setSpeed(speed);      // Set speed of motor
  motor.step(1,direction,INTERLEAVE);
  // You can change SINGLE to SINGLE, DOUBLE, INTERLEAVE or MICROSTEP
  delay(1);        // delay in between reads for stability
the stepper runs perfectly
I want to add a "go Switch" which is a single throw switch - the center pin is connected to pin 2 and the outer pins are +5v and Ground respectively,
So I don't want my stepper to run untill pin 2 see's high voltage and then I want it to stop when pin 2 see's low voltage.
If someone could show me how to add this to my current sketch that would be super.
