I am a total noob when it comes to using makefiles and dealing with source code with many components, .c and .h files. I am only use to working within the Arduino IDE environment working with .ino files and libraries. I also do not have Linux installed, nor do I have much experience with it.
I have spent weeks researching how to accomplish compiling using makefiles in windows with no luck. Some of the projects I am starting to work on now demand it. I've found that there are too many tools with no clear cut way on how to use makefiles to compile from source code and upload to the arduino. I understand the process somewhat, but it seems that a special cmd line tool is needed, and I've found several such as GNU Make. But I have no idea how to use these utilities.
My wish is that someone would provide a very clear solution for noobs like me (noob to the makefile process), especially when working with source code repositories that contain main.c files and the multitude of .h and .c support files, what tools are required, and how to compile and upload these programs.
In my last attempt, I started simple using the Blink example. I copied it and added the .cpp extension, created a makefile for it with the board parameters, paths, and function prototypes as instructed. When I tried 'make' in the windows cmd line windows obviously had no idea what to do.
Every tutorial and forum I have read provides examples and files/tools but nothing seems to be geared towards the windows users. Is there anyone out there who can explain how to do this clearly, and for those who have never worked with source files and the cmd line to compile?
Much thanks in advance...
