Help with controlling Nema23 stepper motor
Hello, this is my first time building anything electrical. I've made a build attached to a hand sanitizer stand so it can stand vertically. Attached are the wiring diagram, build, and code. When I upload the code and press the tactile button to close the circuit to pin 11, nothing happens. I already checked to see if the motor is wired correctly. The colors match the documentation and when plugged in it cannot be manually turned and emits a constant low buzzing noise. I can't figure out what's wrong. Also, whenever I press the tactile button, pin 13's LED lights up for some reason...
// Define stepper motor connections:
#define dirPin 2
#define stepPin 3
  // Declare pins as output:
  pinMode(stepPin, OUTPUT);
  pinMode(dirPin, OUTPUT);
  pinMode(11, INPUT);
  while (digitalRead(11)== HIGH)
{ digitalWrite(dirPin, HIGH);
digitalWrite(stepPin, HIGH);
delayMicroseconds(500);
digitalWrite(stepPin, LOW);
delayMicroseconds(500); }
The wiring diagram was drawn incorrectly. This is the updated one that matches the physical build:
the dark blue wire was supposed to be on ground
EN+ & EN- to GND?
pull out, they no needed for testing, EN is activated by default
const byte stepPin = 3;
How is the stepper powered?
24V power supply. I followed the wiring colors for the stepper motor as shown in the third picture. Additionally, the top right LED of the DM542T stepper motor driver is lit up, so I don't think that is a problem.
Jumping from 0 to 1000 steps per second won't work, the motor cannot accelerate that fast, it will just sit and buzz.
Try:
  delayMicroseconds(8000);
What does that indicate? Did you set the DM542T's current limiter to match the motor's current rating? What is that current rating?
I thought I was responding to jremington's response. That was meant to be a reply.
Turns out, I did not switch the DM542T from 20V to 5V using the little switch on the top. A very beginner mistake and I am quite embarrassed. The code and wiring work correctly now.
Now, you mentioned 200 steps per second is too much, what do you mean by that? I have the DM542T set to 200 pulses/rev, coded the same way I had it, and the rate of rotation actually seemed quite slow. I decreased the delay to 300 to speed it up and it still worked fine.
