int RecievedData = 0; //recieved data
pinMode(LED_BUILTIN, OUTPUT);
if (Serial.available() > 0) { //only send data if data is recieved
RecievedData = Serial.read(); //read the recieved data
Serial.println(RecievedData); //print data
String inputString = ""; // a string to hold incoming data
volatile boolean stringComplete = false; // whether the string is complete
volatile uint32_t value;
Serial.begin(250000);
Serial.println(" Enter morse code ");
// reserve 4 bytes for the inputString:
inputString.reserve(4);
// print the string when a newline arrives:
if (stringComplete) {
value = inputString.toInt(); // convert to integer
a();
Serial.println(value);
// clear the string:
inputString = "";
void serialEvent() {
while (Serial.available()) {
// get the new byte:
char inChar = (char)Serial.read();
// add it to the inputString:
inputString += inChar;
// if the incoming character is a newline, set a flag
// so the main loop can do something about it:
if (inChar == '\n') {
stringComplete = true;
void DOT()
digitalWrite(LED_BUILTIN, HIGH);
digitalWrite(LED_BUILTIN, LOW);
void DASH()
Serial.println("coucou");
delay(3000);
void a() {
switch (value) {
case 97 :
DOT();
DASH();
case 98:
DASH();
DOT();
DOT();
DOT();
case 99:
DASH();
DOT();
DASH();
DOT();
case 100:
DASH();
DOT();
DOT();
case 32:
delay(200);
Please read the first post in any forum entitled how to use this forum. http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Also state what your program should do and what it is doing?
void a();
Regardless of what you receive from the serial port, you do nothing. That is not even a call to a(). That is a function prototype for a function that takes no arguments and returns nothing. It is not even a good name for a function.
