Help with my project and i don't know how to use ardunio uno i have to connect the DiY metal detector and The MQ 3 model together
It is my first time using arduino uno and i have to make a detector that has both the DIY metal detector and MQ 3 module i don't know how to code this and how to connect the circuits so that it connects with the Ardunio and give a singe signal can someone help me
Datasheets of the devices that you want to connect are very useful. Or links to the devices that you are using.
Looking at the MQ3 (I assume)
You can connect Vcc and GND to the Vcc and GND of the Uno.
A0 will go to one of the analogue inputs of the Arduino (A0..A5).
D0 is optional but you can connect it to a digital pin if you have the need.
A quick search on the web reveals e.g. MQ3 Sensor & Arduino: Building An Alcohol Detector.
I can't help with the DIY metal detector. You will need to provide schematics and or datasheets. I did try but there are too many links on the web for it for me to check; diy metal detector at DuckDuckGo
Are these two separate projects?
Metal detection and alcohol detection combined seems an odd arrangement.
What are you trying to do?
The idea was to make a bomb detector as i don't know how to do that so i asked my seniors and they said that.. You can use metal detector and MQ 3 that can detect both alchohal and smoke to make it
Perhaps get a copy of the Arduino Cookbook and start there.
Ok i will try that
Hmm. A cardboard box filled with black power makes a perfect bomb and no metal needed.
