I have been using the library below for the TMP102 temperature sensor - recently I noticed that it doesn't handle negative temperatures correctly so instead of counting -1, -2, -3 etc it reports 254, 253, 252 etc..... can anyone provide some help on how to resolve this please? Thanks
#include "TMP102.h"
void TMP102::readTemperatureRegister(void)
 unsigned char MSB,LSB;
 Wire.beginTransmission(TMP102_ADDRESS); //TMP102 Device (I2C Slave) address
 Wire.send(0x00); //Temperature registers starts at address 0x00
 Wire.endTransmission();
 Wire.requestFrom(TMP102_ADDRESS, 2);Â
Â
 MSB = Wire.receive(); //Read MSB of Temperature Register
 LSB = Wire.receive(); //Read LSB of Temperature Register
 Temperature Register Format:
 MSB: T11 T10 T9 T8 T7 T6 T5 T4
 LSB: T3 T2 T1 T0 0 0 0 0
 temperature = (MSB << 8 ) | LSB;
 temperature >>= 4 ; // Value is left shifted in above table. Hence Right shift.
 temperature = temperature & 0xFFF; //temperature is integer. Remove extra bits.
 if(temperature & 0b100000000000) //T11 indicates sign (either +ve or -ve)
 //Negative temperature
 //Negative numbers are represented in binary two's complement format according to data sheet
  temperature = temperature - 1;
  temperature ^= 0xFFF;
  temperatureCelsius = temperature * 0.0625 * (-1); //Each bit is 0.0625 deg Celsius
 //Positive temperature
  temperatureCelsius = temperature * 0.0625;
//Return temperature (each bit indicates 0.0625 deg celsius)
int TMP102::getTemperature(void)
readTemperatureRegister();
return temperature;
//Return temperature in celsius
float TMP102::getTemperatureInCelsius(void)
return temperatureCelsius;
TMP102 Tmp102; //Create object
