help with OLED SH1106 SPi
how can i send the readings from my sensor (heartbeat sensor) to my SH1106 1.3 128x64 7 pin spi oled display ?
i don´t have a good knowledge on C so don´t expect to much from me :slight_smile:
please if you are going to write something on those lines of "you need do learn the basics" don´t even bother to answer this topic :wink:
#define USE_ARDUINO_INTERRUPTS true
#include <PulseSensorPlayground.h>
const int PulseWire = 0;
const int LED13 = 13;
int Threshold = 530;
PulseSensorPlayground pulseSensor;
pulseSensor.analogInput(PulseWire);
pulseSensor.blinkOnPulse(LED13);
pulseSensor.setThreshold(Threshold);
if (pulseSensor.begin()) {
Serial.println(" pulseSensor activated ");
int myBPM = pulseSensor.getBeatsPerMinute(); BPM as an "int".
if (pulseSensor.sawStartOfBeat()) {
Serial.println(" Heartbeat detected ");
Serial.print("BPM: ");
Serial.println(myBPM);
delay(20);
Having some knowledge in C is more then some questioners have.
If You use code tags, the leftmost symbol looking like </>, and copy Your code into it it is much more easy to read Your code for people not having a large Pc monitor to look at.
What is Your issue, what is Your actual question? Nobody posts a tested and ready sketch. You do the coding out of help with obstacles appearing.
my question is how i can show the serial monitor info in a external display like the one i listed up there
This compiles for a Nano but I have no clue if it's even close to working.
Note that you need to install the U8glib (Tools >Manage Libraries and search for U8glib.)
Hope it helps.
#include <U8glib.h>
const int PulseWire = A0;
const int Threshold = 530;
//update with whatever pins you're using
const int pinSCK = 4;
const int pinMOSI = 5;
const int pinCS = 6;
const int pinDC = 7;
int bpm = 0;
U8GLIB_SH1106_128X64 SH1106_Display( pinSCK, pinMOSI, pinCS, pinDC );
void DrawHeartBeat( int pulseBPM )
    char
        szBpm[10];
    sprintf( szBpm, "%d", pulseBPM );
    SH1106_Display.drawStr( 0, 0, szBpm );
}//DrawHeartBeat
void setup(void)
    SH1106_Display.setFont(u8g_font_gdr25r);
}//setup
void loop(void)
    UpdateBPM();
    UpdateDisplay();
}//loop
void UpdateBPM( void )
    static unsigned long
        timeUpdate = 0;
    unsigned long
        timeNow;
    timeNow = millis();
    //update heart rate and LED at 50mS intervals
    if( (timeNow - timeUpdate) < 50 )
        return;
    timeUpdate = timeNow;
    bpm = UpdateHeartRate();
    if( bpm >= Threshold )
        digitalWrite( LED13, HIGH );
        digitalWrite( LED13, LOW );
}//UpdateLED
void UpdateDisplay( void )
        timeUpdate = 0;
    unsigned long
        timeNow;
    timeNow = millis();
    //update heart rate at 250mS intervals
    if( (timeNow - timeUpdate) < 250 )
        return;
    SH1106_Display.firstPage();
    do
        DrawHeartBeat( bpm );
        Serial.println( bpm );
    } while( SH1106_Display.nextPage() );
}//UpdateDisplay
int UpdateHeartRate( void )
    return( pulseSensor.getBeatsPerMinute() );
}//UpdateHeartRate
First thanks for the help, the only problem i found is that the oled is showing this random dot
You might try changing the line:
to
SH1106_Display.drawStr( 15, 30, szBpm );
and see if anything changes.
thank you it worked :slight_smile:
nanoR4K:
The fact is though, you do need to.
It's unusual to be spoon-fed working code in most fora, and if you don't learn, you'll just be back again and again asking for more code to do , and until even Blackfin who seems to be one of the few members churning out turnkey code at the drop of a hat, may get pi$$ed off.
