Help with proximity sensors + analog output
Hi I need a bit of help with my code for a project. I originally had it working with 2 sensors and an analog output (pwm):
I am having a few problems which include:
Refresh rate isn't what I am specifying.
Is not outputting 0-5v (pwm 0-255) values specified
I am using the Parallax Ping ultrasonic sensors.
int PINOUT = 3; //pwm pin 3. (output)
unsigned long timeOn = 5; // Change the number to set seconds to hold relays
unsigned long timeDeactivate = 10;
unsigned long timeOfDeactivation = 0;
unsigned long timeOfRelay1 = 0;
const double sensor1min = 100.00;
const double sensor1max = 10.00;
const double sensor2min = 75.00;
const double sensor2max = 5.00;
const double sensor3min = 120.00;
const double sensor3max = 10;
const int S1PIN = 7;
const int S2PIN = 8;
const int S3PIN = 9;
  // initialize serial communication:
  pinMode(PINOUT, OUTPUT);
  if ( 0 && 0 ) { //Deactivate
    timeOfDeactivation = millis();
    Serial.println("==AUTOMATIC IS OFF==");
  } else if (timeOfDeactivation != 0) {
  } else if ((((timeDeactivate * 1000) + timeOfDeactivation) < millis()) || timeOfDeactivation == 0){
  long s1cm, s2cm, s3cm;
  int s1pro, s2pro, s3pro, proout;
  s1cm = getdistance(S1PIN);
  if (s1cm < sensor1max) {
    s1pro = 255;
  } else if (s1cm > sensor1min) {
    s1pro = 0;
    s1pro = ((sensor1min - s1cm)/(sensor1min - sensor1max))*255;
  analogWrite(PINOUT,proout);
  s2cm = getdistance(S2PIN);
  if (s2cm < sensor2max) {
    s2pro = 255;
  } else if (s2cm > sensor2min) {
    s2pro = 0;
    s2pro = ((sensor2min - s2cm)/(sensor2min - sensor2max))*255;
  if (proout < s2pro) proout = s2pro;
  s3cm = getdistance(S3PIN);
  if (s3cm < sensor3max) {
    s3pro = 255;
  } else if (s3cm > sensor3min) {
    s3pro = 0;
    s3pro = ((sensor3min - s3cm)/(sensor3min - sensor3max))*255;
  if (proout < s3pro) proout = s3pro;
  Serial.print("Sensor 1: ");
  Serial.print(s1cm);
  Serial.print("  Sensor 2: ");
  Serial.print(s2cm);
  Serial.print("  Proportional Out (0-255): ");
  Serial.print(s1pro);
  Serial.print(" ;  ");
  Serial.print(s2pro);
  //Serial.print(((sensor2min - s2cm)/(sensor2min - sensor2max))*255);
  Serial.print(proout);
  delay(10);
long getdistance(int pin) {
  long duration;
  pinMode(pin, OUTPUT);
  digitalWrite(pin, LOW);
  delayMicroseconds(2);
  digitalWrite(pin, HIGH);
  delayMicroseconds(5);
  pinMode(pin, INPUT);
  duration = pulseIn(pin, HIGH);
  return duration / 29 / 2;
The PWM pin is not capable of outputting any other values. So, anything you measure on that pin will have to be in this range.
Please explain what you mean by this statement.
You are calculating and writing two different outputs for the PWM pin, and only printing data for one set of outputs. Why?
The refresh rate for what?
