Help with queue
I'm attempting to use this Queue library:
So far I'm not having any luck. Here's my stripped down code, based on this example:
#include <cppQueue.h>
typedef struct strRec {
  char  url[300];
  char  misc1[255];
} Rec;
Rec tab[2] = {
  { "https://whatever1.com", "something1" },
  { "https://whatever2.com", "something2" }
cppQueue  queue1(sizeof(Rec), 10, LIFO, true);
    // iterate through the queue
    for (int i = 0 ; i < sizeof(tab)/sizeof(Rec) ; i++)
      Rec rec;
      queue1.pop(&rec);
      Serial.println("There's something in the queue!");
      Serial.print(rec.url);
      Serial.print(" ");
      Serial.print(rec.misc1);
      String url = rec.url;
      Serial.println("URL = " + url);
However this just prints gibberish to the console:
There's something in the queue! ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮xV⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮xV⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮xV⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮xV⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮ ,⸮ URL = ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮
Any ideas by chance?
Also, shouldn't calling pop() on the queue remove that item from the queue? Currently it isn't.
There is a separate example for working with strings. Perhaps that helps.
I saw that, and thank you, but I would like to use a struct (of strings).
Ah, I see you did not push() anything, so whatever you pop() is undefined.
You probably want to add something like this (taken from the example):
for (i = 0; i < sizeof(tab) / sizeof(Rec); i++) {
  Rec rec = tab[i];
  q.push(&rec);
Thank you! And oops.
My fixed code and simpler example of using the Queue library, on the off chance it's useful to someone:
  char  url[300];
  char  misc1[255];
} Rec;
  Rec test = {"http://google.com", "some stuff"};
  queue1.push(&test);
  while (!queue1.isEmpty())
    Rec rec;
    queue1.pop(&rec);
    Serial.print(" ");
This outputs:
On a sidenote that example that I used as a starting point strikes me as confusing. Why would anyone iterate the queue in that way instead of using "while (!queue1.isEmpty())"? And why does the struct "tab" exist at all?
