GB250:
With the above reed switch do I have pull up the pin that it is attached to? or have an external pull down resistor.
For the Nano, I had my reed switch connected to the D2 pin and the ground, is this correct?
The reed switch has only two contacts, so you must either:
connect the switch between D2 and ground and use an external pull-up resistor,
connect the switch between D2 and 5V and use an external pull-down resistor,
connect the switch between D2 and ground use the Arduino's internal pull-up resistor with "pinMode(2, INPUT_PULLUP);"
Without one of the above, the Arduino pin will "float" and will not reliably read the switch.
However, option 2 is not recommended because of the risk of a short-circuit if the wire between the Arduino and the switch were to become disconnected or damaged. The bare 5V wire could touch the frame of the motorcycle, and because there would be no resistor to limit the current, the Arduino's 5V regulator could be damaged.
GB250:
Would that work with this line alone: attachInterrupt(0, speedCalc, RISING);
Using interrupts for this project is not necessary and not recommended for beginners. Use "digitalRead(2);". When the result changes from LOW to HIGH or HIGH to LOW, add one to a counter.
