Help with simple program: 1 GPIO open or close -> action?
Hi, new user & complete NOOB with this.
I have bought a SIM module to be able to get a SMS when dumb smoke detectors go off.
After some searching, I have found a sketch from which I have taken the loop and modified it to this:
  if (analogRead(BUTTON_PIN) == 0) {
    Serial.println("Contact Closed!");
    res = modem.sendSMS(SMS_TARGET, String("Test: GPIO closed -> Fire or Smoke!"));
    DBG("SMS:", res ? "OK" : "fail");
  else {
    Serial.println("Contact Open!");
    res = modem.sendSMS(SMS_TARGET, String("Test: GPIO Open -> No Fire or Smoke now!"));
delay(10000);
That sketch already had this constant checking of the GPIO, no matter what the previous state was.
I have no experience in programming and am looking for a way to only have an action when the state changes.
Any help is highly appreciated!
Not tested, but should work. I'm very suspicious of that analogRead(). It can be a sign of someone who had no clue what they were doing.
  static bool lastState = digitalRead(BUTTON_PIN);
  // No idea why previous version is using analogRead <<< code smelly
  bool buttonState = digitalRead(BUTTON_PIN);
  if (buttonState != lastState)
      // Trigger on state change to LOW
      if (buttonState == LOW)
  lastState = buttonState;
  delay(10000);
Hi, thanks a lot for your help!
RE 'analogRead': that someone is me! :blush:
The original sketch was using digitalRead but that didn't seem to work and ?somewhere? I found some code with analogRead.
Unlike what the code says, I'm not using a button but just testing by shorting a GPIO but I have no idea if that makes any difference.
I'm just discovering this world of ESP's
I will test your solution tomorrow and share my findings.
Well, it might still not work properly. We're only seeing a snippet of the code.
Me too, it only takes a dirty switch contact, or some noise pick up on the push button wiring and the analogRead() will always be non-zero.
I think that you can now remove that delay(10000), or at least reduce it to a few tens of milliseconds for switch debouncing.
With it present, you could have to wait with your 'finger on the button' for up to 10s before it is registered.
The techniques that cedarlakeinstruments has used are demonstrated in the Arduino IDE Example "StateChangeDetection".
All a switch does is provide continuity when closed and not when open.
Aside from the possibility of accidents, there is no difference. The jumper might be quite a bit noisier than a real switch depending on your technique. All that would mean in practice is that such a "switch" might bounce (return changing values when digitally read) longer and therefore require a longer debounce constant or whatever the algorirhm uses to decide a switch has stabilized or should be ignored.
a7
Thanks guys for helping!
I prefer learning something then just getting the working code, so any pointers/tips/advice/links/... are welcome.
I'm also posting the code below that I started out with and I wonder if those modem tests/settings really have to be in the loop.
@Delta_G: would you mind explaining the reason analogRead is wrong?
As you can see from my fipo, these are dumb devices that are in place so the easiest and cheapest option to get notified is something like this.
Before asking help here, I found this sketch from randomnerdtutorials.com:
LILYGO T-SIM7000G ESP32: Connect to the Internet, Send SMS, and Get GPS Data
  Rui Santos
  Complete project details at https://RandomNerdTutorials.com/lilygo-t-sim7000g-esp32-lte-gprs-gps/
  Permission is hereby granted, free of charge, to any person obtaining a copy
  of this software and associated documentation files.
  The above copyright notice and this permission notice shall be included in all
  copies or substantial portions of the Software.
// Based on the following example: https://github.com/Xinyuan-LilyGO/LilyGO-T-SIM7000G/blob/master/examples/Arduino_TinyGSM/AllFunctions/AllFunctions.ino
#define TINY_GSM_MODEM_SIM7000
#define TINY_GSM_RX_BUFFER 1024 // Set RX buffer to 1Kb
#define SerialAT Serial1
// See all AT commands, if wanted
#define DUMP_AT_COMMANDS
// set GSM PIN, if any
#define GSM_PIN ""
// Your GPRS credentials, if any
const char apn[]  = "";     //SET TO YOUR APN
const char gprsUser[] = "";
const char gprsPass[] = "";
// Set phone number, if you want to test SMS
// Set a recipient phone number to test sending SMS (it must be in international format including the "+" sign)
#define SMS_TARGET  ""
#include <TinyGsmClient.h>
#include <SPI.h>
#include <SD.h>
#include <Ticker.h>
#ifdef DUMP_AT_COMMANDS  // if enabled it requires the streamDebugger lib
  #include <StreamDebugger.h>
  StreamDebugger debugger(SerialAT, Serial);
  TinyGsm modem(debugger);
#else
  TinyGsm modem(SerialAT);
#endif
#define uS_TO_S_FACTOR 1000000ULL  // Conversion factor for micro seconds to seconds
#define TIME_TO_SLEEP  60          // Time ESP32 will go to sleep (in seconds)
#define UART_BAUD   115200
#define PIN_DTR     25
#define PIN_TX      27
#define PIN_RX      26
#define PWR_PIN     4
#define SD_MISO     2
#define SD_MOSI     15
#define SD_SCLK     14
#define SD_CS       13
#define LED_PIN     12
int counter, lastIndex, numberOfPieces = 24;
String pieces[24], input;
void setup(){
  // Set console baud rate
  delay(10);
  // Set LED OFF
  pinMode(LED_PIN, OUTPUT);
  digitalWrite(LED_PIN, HIGH);
  pinMode(PWR_PIN, OUTPUT);
  digitalWrite(PWR_PIN, HIGH);
  delay(300);
  digitalWrite(PWR_PIN, LOW);
  SPI.begin(SD_SCLK, SD_MISO, SD_MOSI, SD_CS);
  if (!SD.begin(SD_CS)) {
    Serial.println("SDCard MOUNT FAIL");
    uint32_t cardSize = SD.cardSize() / (1024 * 1024);
    String str = "SDCard Size: " + String(cardSize) + "MB";
    Serial.println(str);
  Serial.println("\nWait...");
  SerialAT.begin(UART_BAUD, SERIAL_8N1, PIN_RX, PIN_TX);
  // Restart takes quite some time
  // To skip it, call init() instead of restart()
  Serial.println("Initializing modem...");
  if (!modem.restart()) {
    Serial.println("Failed to restart modem, attempting to continue without restarting");
void loop(){
  if (!modem.init()) {
  String name = modem.getModemName();
  Serial.println("Modem Name: " + name);
  String modemInfo = modem.getModemInfo();
  Serial.println("Modem Info: " + modemInfo);
  // Unlock your SIM card with a PIN if needed
  if ( GSM_PIN && modem.getSimStatus() != 3 ) {
      modem.simUnlock(GSM_PIN);
  modem.sendAT("+CFUN=0 ");
  if (modem.waitResponse(10000L) != 1) {
    DBG(" +CFUN=0  false ");
  delay(200);
    2 Automatic
    13 GSM only
    38 LTE only
    51 GSM and LTE only
  String res;
  // CHANGE NETWORK MODE, IF NEEDED
  res = modem.setNetworkMode(2);
  if (res != "1") {
    DBG("setNetworkMode  false ");
    return ;
  delay(200);
    1 CAT-M
    2 NB-Iot
    3 CAT-M and NB-IoT
  // CHANGE PREFERRED MODE, IF NEEDED
  res = modem.setPreferredMode(1);
  if (res != "1") {
    DBG("setPreferredMode  false ");
    return ;
  delay(200);
  /*AT+CBANDCFG=<mode>,<band>[,<band>…]
   * <mode> "CAT-M"   "NB-IOT"
   * <band>  The value of <band> must is in the band list of getting from  AT+CBANDCFG=?
   * For example, my SIM card carrier "NB-iot" supports B8.  I will configure +CBANDCFG= "Nb-iot ",8
  /* modem.sendAT("+CBANDCFG=\"NB-IOT\",8 ");*/
  /* if (modem.waitResponse(10000L) != 1) {
       DBG(" +CBANDCFG=\"NB-IOT\" ");
   delay(200);
  modem.sendAT("+CFUN=1 ");
    DBG(" +CFUN=1  false ");
  delay(200);
  SerialAT.println("AT+CGDCONT?");
  if (SerialAT.available()) {
    input = SerialAT.readString();
    for (int i = 0; i < input.length(); i++) {
      if (input.substring(i, i + 1) == "\n") {
        pieces[counter] = input.substring(lastIndex, i);
        lastIndex = i + 1;
        counter++;
        if (i == input.length() - 1) {
      // Reset for reuse
      input = "";
      counter = 0;
      lastIndex = 0;
      for ( int y = 0; y < numberOfPieces; y++) {
        for ( int x = 0; x < pieces[y].length(); x++) {
          char c = pieces[y][x];  //gets one byte from buffer
          if (c == ',') {
            if (input.indexOf(": ") >= 0) {
              String data = input.substring((input.indexOf(": ") + 1));
              if ( data.toInt() > 0 && data.toInt() < 25) {
                modem.sendAT("+CGDCONT=" + String(data.toInt()) + ",\"IP\",\"" + String(apn) + "\",\"0.0.0.0\",0,0,0,0");
              input = "";
          // Reset for reuse
          input = "";
          input += c;
    Serial.println("Failed to get PDP!");
  Serial.println("\n\n\nWaiting for network...");
  if (!modem.waitForNetwork()) {
    delay(10000);
    return;
  if (modem.isNetworkConnected()) {
    Serial.println("Network connected");
  // --------TESTING GPRS--------
  Serial.println("\n---Starting GPRS TEST---\n");
  Serial.println("Connecting to: " + String(apn));
  if (!modem.gprsConnect(apn, gprsUser, gprsPass)) {
    delay(10000);
    return;
  Serial.print("GPRS status: ");
  if (modem.isGprsConnected()) {
    Serial.println("connected");
    Serial.println("not connected");
  String ccid = modem.getSimCCID();
  Serial.println("CCID: " + ccid);
  String imei = modem.getIMEI();
  Serial.println("IMEI: " + imei);
  String cop = modem.getOperator();
  Serial.println("Operator: " + cop);
  IPAddress local = modem.localIP();
  Serial.println("Local IP: " + String(local));
  int csq = modem.getSignalQuality();
  Serial.println("Signal quality: " + String(csq));
  SerialAT.println("AT+CPSI?");     //Get connection type and band
    String r = SerialAT.readString();
    Serial.println(r);
  Serial.println("\n---End of GPRS TEST---\n");
  modem.gprsDisconnect();
  if (!modem.isGprsConnected()) {
    Serial.println("GPRS disconnected");
    Serial.println("GPRS disconnect: Failed.");
  // --------TESTING GPS--------
  Serial.println("\n---Starting GPS TEST---\n");
  // Set SIM7000G GPIO4 HIGH ,turn on GPS power
  // CMD:AT+SGPIO=0,4,1,1
  // Only in version 20200415 is there a function to control GPS power
  modem.sendAT("+SGPIO=0,4,1,1");
    DBG(" SGPIO=0,4,1,1 false ");
  modem.enableGPS();
  float lat,  lon;
  while (1) {
    if (modem.getGPS(&lat, &lon)) {
      Serial.printf("lat:%f lon:%f\n", lat, lon);
      Serial.print("getGPS ");
      Serial.println(millis());
    delay(2000);
  modem.disableGPS();
  // Set SIM7000G GPIO4 LOW ,turn off GPS power
  // CMD:AT+SGPIO=0,4,1,0
  modem.sendAT("+SGPIO=0,4,1,0");
    DBG(" SGPIO=0,4,1,0 false ");
  // --------TESTING SENDING SMS--------
  res = modem.sendSMS(SMS_TARGET, String("Hello from ") + imei);
  // --------TESTING POWER DONW--------
  // Try to power-off (modem may decide to restart automatically)
  // To turn off modem completely, please use Reset/Enable pins
  modem.sendAT("+CPOWD=1");
    DBG("+CPOWD=1");
  // The following command does the same as the previous lines
  modem.poweroff();
  Serial.println("Poweroff.");
  // GO TO SLEEP
  esp_sleep_enable_timer_wakeup(TIME_TO_SLEEP * uS_TO_S_FACTOR);
  delay(200);
  esp_deep_sleep_start();
  // Do nothing forevermore
  while (true) {
      modem.maintain();
and adapted it into this:
Working sketch
#define BUTTON_PIN 32
// GPRS credentials
const char apn[]  = "<apn>";     //SET TO YOUR APN
const char gprsUser[] = "<>";
const char gprsPass[] = "<>";
// Set phone number
#define SMS_TARGET  "+xxxxxxxxxxx"
#include <SPI.h>
#include <SD.h>
#include <Ticker.h>
#else
#endif
#define PIN_DTR     25
#define PIN_TX      27
#define PIN_RX      26
#define PWR_PIN     4
#define SD_MISO     2
#define SD_MOSI     15
#define SD_SCLK     14
#define SD_CS       13
#define LED_PIN     12
void setup(){
  delay(10);
  pinMode(BUTTON_PIN, INPUT); //configures pin as an input
  // Set LED OFF
  delay(300);
void loop(){
  // String name = modem.getModemName();
  // delay(500);
  // Serial.println("Modem Name: " + name);
  // String modemInfo = modem.getModemInfo();
  // delay(500);
  // Serial.println("Modem Info: " + modemInfo);
  delay(200);
  String res;
  if (res != "1") {
    return ;
  delay(200);
  if (res != "1") {
    return ;
  delay(200);
  delay(200);
        lastIndex = i + 1;
        counter++;
      // Reset for reuse
      input = "";
      counter = 0;
      lastIndex = 0;
          if (c == ',') {
              input = "";
          // Reset for reuse
          input = "";
          input += c;
    delay(10000);
    return;
  // if (modem.isNetworkConnected()) {
  //   Serial.println("Network connected");
    res = modem.sendSMS(SMS_TARGET, String("Test: Contact Closed -> Fire or smoke!"));
  else {
    res = modem.sendSMS(SMS_TARGET, String("Test: Contact Open -> No Fire or Smoke right now!"));
  delay(10000);
So with the help of @cedarlakeinstruments I made these changes but I did not get the open/close output in the serial monitor.
Another attempt was with a basic sketch which leaves out the whole modem part, just to see if I could detect the state of GPIO 32 but that didn't work at all (?modem commands/settings needed?)
-> do you guys think/know if it's possible to skip the modem part and just use this board as a simple ESP device (as a test, for learning purposes)?
I also tried this minimalistic sketch (ofc with the right settings) and added the code for detecting the state of GPIO 32.
Network test
  Rui Santos
// Original code: https://github.com/Xinyuan-LilyGO/LilyGO-T-SIM7000G/blob/master/examples/Arduino_NetworkTest/Arduino_NetworkTest.ino
// Set serial for debug console (to the Serial Monitor, default speed 115200)
#define SerialMon Serial
// #define DUMP_AT_COMMANDS
#define GSM_PIN ""
#include <SPI.h>
#include <SD.h>
#include <Ticker.h>
  StreamDebugger debugger(SerialAT, SerialMon);
#else
#endif
// LilyGO T-SIM7000G Pinout
#define PIN_DTR             25
#define PIN_TX              27
#define PIN_RX              26
#define PWR_PIN             4
#define SD_MISO             2
#define SD_MOSI             15
#define SD_SCLK             14
#define SD_CS               13
#define LED_PIN             12
void modemPowerOn(){
void modemPowerOff(){
  delay(1500);
void modemRestart(){
  modemPowerOff();
  modemPowerOn();
void setup(){
  SerialMon.begin(115200);
  delay(10);
  // Set LED OFF
  modemPowerOn();
  Serial.println("========SDCard Detect.======");
  SPI.begin(SD_SCLK, SD_MISO, SD_MOSI);
  Serial.println("===========================");
  Serial.println("/**********************************************************/");
  Serial.println("To initialize the network test, please make sure your LTE ");
  Serial.println("antenna has been connected to the SIM interface on the board.");
  Serial.println("/**********************************************************/\n\n");
  delay(10000);
void loop(){
  String res;
  Serial.println("========INIT========");
    modemRestart();
    delay(2000);
    return;
  Serial.println("========SIMCOMATI======");
  modem.sendAT("+SIMCOMATI");
  modem.waitResponse(1000L, res);
  res.replace(GSM_NL "OK" GSM_NL, "");
  Serial.println(res);
  res = "";
  Serial.println("=======================");
  Serial.println("=====Preferred mode selection=====");
  modem.sendAT("+CNMP?");
  if (modem.waitResponse(1000L, res) == 1) {
  res = "";
  Serial.println("=====Preferred selection between CAT-M and NB-IoT=====");
  modem.sendAT("+CMNB?");
  res = "";
  for (int i = 0; i <= 4; i++) {
    uint8_t network[] = {
        2,  /*Automatic*/
        13, /*GSM only*/
        38, /*LTE only*/
        51  /*GSM and LTE only*/
    Serial.printf("Try %d method\n", network[i]);
    modem.setNetworkMode(network[i]);
    delay(3000);
    bool isConnected = false;
    int tryCount = 60;
    while (tryCount--) {
      int16_t signal =  modem.getSignalQuality();
      Serial.print("Signal: ");
      Serial.print(signal);
      Serial.print(" ");
      Serial.print("isNetworkConnected: ");
      isConnected = modem.isNetworkConnected();
      Serial.println( isConnected ? "CONNECT" : "NO CONNECT");
      if (isConnected) {
      digitalWrite(LED_PIN, !digitalRead(LED_PIN));
    if (isConnected) {
  Serial.println("Device is connected .");
  Serial.println("=====Inquiring UE system information=====");
  modem.sendAT("+CPSI?");
  Serial.println("After the network test is complete, please enter the  ");
  Serial.println("AT command in the serial terminal.");
  while (1) {
    while (SerialAT.available()) {
      SerialMon.write(SerialAT.read());
    while (SerialMon.available()) {
      SerialAT.write(SerialMon.read());
Hi guys, I did put this project on hold but now I'm picking it up.
So I got the analogRead vs digitalRead now! :wink:
Thanks for explaining
[quote="cedarlakeinstruments, post:2, topic:1260917"]
[/quote
Where does this go in the sketch:
  • in the first part, defining everything
  • or in the 'void setup()' section?
It seems that you just wasted this time since your last visit, since you still aren't even familiar with the arduino sketch structure...
or even in loop()...
