Hi!
i am trying to make my servo movement smooth but it isn't quite working out, i watched this video: How To Make Robots Move Smoothly | Arduino Tutorial - YouTube start at 4:35 By James Bruton
and with his code:
#include <Servo.h>
int pot1;
int pot2;
int pot3;
int pot4;
int pot5;
int pot6;
float pot1Scaled;
float pot2Scaled;
float pot3Scaled;
float pot4Scaled;
float pot4aScaled;
float pot5Scaled;
float pot6Scaled;
float pot1Smoothed;
float pot2Smoothed;
float pot3Smoothed;
float pot4Smoothed;
float pot4aSmoothed;
float pot5Smoothed;
float pot6Smoothed;
float pot1SmoothedPrev;
float pot2SmoothedPrev;
float pot3SmoothedPrev;
float pot4SmoothedPrev;
float pot4aSmoothedPrev;
float pot5SmoothedPrev;
float pot6SmoothedPrev;
Servo servo1;
Servo servo2;
Servo servo3;
Servo servo4;
Servo servo5;
Servo servo6;
Servo servo7;
pinMode(A0, INPUT);
pinMode(A1, INPUT);
pinMode(A2, INPUT);
pinMode(A3, INPUT);
pinMode(A4, INPUT);
pinMode(A5, INPUT);
servo1.attach(4);
servo2.attach(5);
servo3.attach(6);
servo4.attach(7);
servo5.attach(8);
servo6.attach(9);
servo7.attach(10);
servo1.writeMicroseconds(1200);
servo2.writeMicroseconds(1650);
servo3.writeMicroseconds(1650);
servo4.writeMicroseconds(1500);
servo5.writeMicroseconds(1550);
servo6.writeMicroseconds(1500);
servo7.writeMicroseconds(1450);
pot1 = analogRead(A0);
pot2 = analogRead(A1);
pot3 = analogRead(A2);
pot4 = analogRead(A3);
pot5 = analogRead(A4);
pot6 = analogRead(A5);
// scale all pots for the servo microseconds range
pot1Scaled = ((pot1 - 512) * -1.6) + 1200;
pot2Scaled = (pot2 - 512) + 1500;
pot3Scaled = (pot3 - 512) + 1500;
pot4Scaled = ((pot4 - 512) * 1.2) + 1500;
pot4aScaled = ((pot4 - 512) * -1.2) + 1500;
pot5Scaled = (pot5 - 512) * 1.5;
pot6Scaled = (pot6 - 512) + 1650;
pot4Scaled = constrain(pot4Scaled,900,1500);
pot4aScaled = constrain(pot4aScaled,1500,2100);
// smooth pots
pot1Smoothed = (pot1Scaled * 0.02) + (pot1SmoothedPrev * 0.98);
pot2Smoothed = (pot2Scaled * 0.02) + (pot2SmoothedPrev * 0.98);
pot3Smoothed = (pot3Scaled * 0.02) + (pot3SmoothedPrev * 0.98);
pot4Smoothed = (pot4Scaled * 0.05) + (pot4SmoothedPrev * 0.95);
pot4aSmoothed = (pot4aScaled * 0.05) + (pot4aSmoothedPrev * 0.95);
pot5Smoothed = (pot5Scaled * 0.02) + (pot5SmoothedPrev * 0.98);
pot6Smoothed = (pot6Scaled * 0.02) + (pot6SmoothedPrev * 0.98);
// bookmark previous values
pot1SmoothedPrev = pot1Smoothed;
pot2SmoothedPrev = pot2Smoothed;
pot3SmoothedPrev = pot3Smoothed;
pot4SmoothedPrev = pot4Smoothed;
pot4aSmoothedPrev = pot4aSmoothed;
pot5SmoothedPrev = pot5Smoothed;
pot6SmoothedPrev = pot6Smoothed;
Serial.print(pot1Smoothed);
Serial.print(" , ");
Serial.print(pot2Smoothed);
Serial.print(pot3Smoothed);
Serial.print(pot4Smoothed);
Serial.print(pot5Smoothed);
Serial.println(pot6Smoothed);
// write servos
servo1.writeMicroseconds(pot1Smoothed);
servo2.writeMicroseconds(pot6Smoothed - pot5Smoothed);
servo3.writeMicroseconds(pot6Smoothed + pot5Smoothed);
servo5.writeMicroseconds(pot2Smoothed);
servo7.writeMicroseconds(pot2Smoothed);
servo4.writeMicroseconds(pot4Smoothed);
servo6.writeMicroseconds(pot4aSmoothed);
delay(5); // run loop 200 times/second
link for the code:
i managed to make this:
receiver code
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#include <Servo.h>
#define CE_PIN 49
#define CSN_PIN 48
RF24 radio(CE_PIN, CSN_PIN);
const byte pipe[] = "00001";
const byte servoPins[] = {2, 5, 4, 3}; //s1 =(2) s2 =(5) s3 =(4) s4 =(3)
const byte servosCount = sizeof servoPins / sizeof * servoPins;
const int initialPositions[servosCount] = {90, 90, 90, 84};
const int mappedRanges[servosCount][2] = {{80, 100}, {65, 115}, {65, 115}, {80, 88}};
Servo servos[servosCount];
struct __attribute__ ((packed)) t_message {
int16_t rawValues[servosCount];
} payload;
uint8_t messageBuffer[sizeof(t_message)];
pinMode(10, OUTPUT);
for (byte i = 0; i < servosCount; i++) {
servos[i].write(initialPositions[i]); //set starting positions
servos[i].attach(servoPins[i]);
// Serial
//radio
radio.begin();
radio.openReadingPipe(0, pipe);
radio.setPALevel(RF24_PA_MIN);
radio.startListening();
if (radio.available()) {
radio.read(messageBuffer, sizeof messageBuffer);
memcpy(&payload, messageBuffer, sizeof payload);
Serial.print(F("New positions: "));
float angle = map(payload.rawValues[i], 0, 1023, mappedRanges[i][0], mappedRanges[i][1]);
angle = angle * 100;
float smoothAngle = (angle * 0.05) + (angle * 0.95);
float finalAngle = smoothAngle;
Serial.print(angle); Serial.write('\t');
servos[i].write(finalAngle);
delay(30);
previous receiver code:
#include <SPI.h>
#include <RF24.h>
#include <Servo.h>
#define CE_PIN 49
#define CSN_PIN 48
} payload;
// Serial
//radio
radio.begin();
int angle = map(payload.rawValues[i], 0, 1023, mappedRanges[i][0], mappedRanges[i][1]);
servos[i].write(angle);
delay(30);
transmitter code:
#include <SPI.h>
#include <RF24.h>
#define CE_PIN 7
#define CSN_PIN 6
const byte joystickPins[] = {A7, A2, A3, A5};
const byte joysticksCount = sizeof joystickPins / sizeof * joystickPins;
int16_t rawValues[joysticksCount];
} payload, previousPayload;
radio.begin();
radio.openWritingPipe(pipe);
radio.stopListening();
// read the joysticks
for (byte i = 0; i < joysticksCount; i++) {
payload.rawValues[i] = analogRead(joystickPins[i]);
payload.rawValues[i] = analogRead(joystickPins[i]) & 0xFFFD; // two reads for stability, dropping the 2 LSb to filter out instability
// broadcast the data if it has changed
if (memcmp(&payload, &previousPayload, sizeof(t_message)) != 0) { // returns 0 when they match, https://cplusplus.com/reference/cstring/memcmp/
radio.write(&payload, sizeof(payload));
previousPayload = payload;
delay(30);
i only plugged my calbe in for 0.3s (that was a good idea) because the servo's instantly moves to their max. or min. mappedRanges. and that is not ok.
in his code he has 3 variables all with a funtion, but i only managed to get 2. so im missing one, but i don't know wich one and how to add it to the code.
