Help with string operations?
Can anyone help me with string operations?
I have a CSV string that I would like to assign string variables to different values within the string
such as:
string str1 = CSVstring[0];
string str2 = CSVstring[1];
I haven't played around with strings before and there must be some sort of string
operation commands available?
What is the best way to do this?
THANKS!
You may want to have a look at the text parser library.
Example:
#include <textparser.h>
TextParser parser(", ");  // Delimiter is a comma followed by a space.
If all fields are of the same type, we can use an array.
int a[5];
parser.parseLine("1, 2, 3, 4, 5", a);
// `a` now contains 1, 2, 3, 4 and 5.
If the fields have different types, we can use multiple variables.
char a[4];
int b;
double c;
parser.parseLine("one, 2, 3.4", a, b, c);
// `a` now contains "one", `b` contains 2 and `c` contains 3.4.
In your case, instead of providing a string constant, as is done in the examples above, you can provide CSVstring.c_str().
Do you mean "char *" when you say 'string' or do you mean "String" when you say 'string'? The coding is different for each.
consider
char s [80];
#define MaxTok  10
char *toks [MaxTok];
int   vals [MaxTok];
int
tokenize (
    char       *s,
    const char *sep )
    unsigned n = 0;
    toks [n] = strtok (s, sep);
    vals [n] = atoi (toks [n]);
    for (n = 1; (toks [n] = strtok (NULL, sep)); n++)
    return n;
void dispToks (
    char * toks [])
    char s [40];
    for (unsigned n = 0; toks [n]; n++)  {
        sprintf (s, " %6d  %s", vals [n], toks [n]);
        Serial.println (s);
void loop ()
    if (Serial.available ())  {
        int n = Serial. readBytesUntil ('\n', s, sizeof(s)-1);
        s [n] = 0;      // terminate string
        tokenize (s, ",");
        dispToks (toks);
void setup ()
    Serial.begin (9600);
