I am trying to code a TFT LCD and I've created a UI, but the code for the UI isn't working. The UI is meant to work so that it checks if the first button is pressed before checking if the next set of buttons can be pressed, but it is checking for the second set of buttons even the the first hasn't been pressed
// create numbers for the vari
#include <Adafruit_GFX.h>
#include <Adafruit_TFTLCD.h>
#include <TouchScreen.h>
#define LCD_CS A3
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
#define LCD_RESET A4
// these pins define the pins being used by the Arduino^^
#define TS_MINX 118
#define TS_MINY 106
#define TS_MAXX 950
#define TS_MAXY 933
#define YP A3
#define XM A2
#define YM 9
#define XP 8
// this code calibrates the screen
Adafruit_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
// these define the pins used to activate the screen
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xf81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
int currentscreen;
bool Camera = false;
bool tracker = false;
bool Homevar = false;
bool backbutton = true;
void Home() {
tft.fillScreen(RED);
tft.setCursor(60, 100);
tft.setTextSize(2);
tft.print("CHOOSE APPLICATION");
tft.fillRect(10, 10, 75, 75, BLUE);
tft.fillRect(125, 10, 75, 75, BLUE);
tft.fillRect(240, 10, 75, 75, BLUE);
// creating buttons for applications, first test out using LED's
void Welcome() {
tft.fillScreen(WHITE); //WHat to fill the screen colour with- colours stated above
tft.drawRect(0, 0, 319, 240, WHITE); //the rectangularshape that the screen fills
tft.setCursor(5, 5); //set cursor is where text will begin on the screen, top right corner of the text
tft.setTextColor(BLACK);
tft.setTextSize(2);
tft.print("WELCOME LKAT");
//add parameters
tft.fillRect(50, 180, 210, 40, BLACK);
tft.drawRect(50, 180, 210, 40, GREEN);
tft.setCursor(60, 190);
tft.setTextColor(WHITE);
tft.setTextSize(2);
void LED() {
tft.fillScreen(BLUE);
tft.print("HELLO");
tft.reset();
uint16_t identifier = tft.readID();
tft.begin(identifier);
tft.setRotation(1); //changing this value between 1 and 0 will change the layout of the text on screen. landscape portarait
currentscreen = 0;
Welcome();
Serial.println(currentscreen);
Serial.println(Homevar);
TSPoint p = ts.getPoint();
if (p.z > ts.pressureThreshhold) {
p.x = map(p.x, TS_MAXX, TS_MINX, 0, 320);
p.y = map(p.y, TS_MAXY, TS_MINY, 0, 480);
pinMode(XM, OUTPUT);
pinMode(YP, OUTPUT);
//set screen resolution
// tft.fillRect(p.y, p.x, 5, 5, BLACK);
if (currentscreen == 0) {
if ((p.x >= 50 && p.x <= 260) && (p.y >= 180 && p.y <= 250)) {
tft.print("hi ");
currentscreen = 1;
Homevar = !Homevar;
Home();
// // else {
// // tft.print();
if (currentscreen == 1 && Homevar == true){){
if( p.x >10 && p.x < 85 && p.y > 10 && p.y < 85 && Homevar == true){
LED();
