Sketch generated by the Arduino IoT Cloud Thing "Hay Tracker"
https://create.arduino.cc/cloud/things/bcff5801-10f1-454e-b9e5-50de650b40f6
Arduino IoT Cloud Variables description
The following variables are automatically generated and updated when changes are made to the Thing
int HayVal;
bool status;
Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
which are called when their values are changed from the Dashboard.
These functions are generated with the Thing and added at the end of this sketch.
___________________________________________________________________________________________
Hay Tracker V 1.0 (STABLE)
#include "thingProperties.h"
const int toptrig = 13;
const int topecho = 12;
const int medtrig = 11;
const int medecho = 10;
const int bottrig = 9;
const int botecho = 8;
long topduration;
long botduration;
long medduration;
int top;
int med;
int bot;
// Initialize serial and wait for port to open:
// This delay gives the chance to wait for a Serial Monitor without blocking if none is found
delay(1500);
// Defined in thingProperties.h
initProperties();
// Connect to Arduino IoT Cloud
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
The following function allows you to obtain more information
related to the state of network and IoT Cloud connection and errors
the higher number the more granular information you’ll get.
The default is 0 (only errors).
Maximum is 4
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
pinMode(toptrig, OUTPUT);
pinMode(medtrig, OUTPUT);
pinMode(bottrig, OUTPUT);
pinMode(topecho, INPUT);
pinMode(medecho, INPUT);
pinMode(botecho, INPUT);
Serial.println("Hay Tracker V 1.0 (STABLE)");
ArduinoCloud.update();
// Your code here
digitalWrite(toptrig, LOW);
digitalWrite(medtrig, LOW);
digitalWrite(bottrig, LOW);
delayMicroseconds(2);
// Sets the trigPin on HIGH state for 10 micro seconds
digitalWrite(toptrig, HIGH);
digitalWrite(medtrig, HIGH);
digitalWrite(bottrig, HIGH);
delayMicroseconds(10);
// Reads the echoPin, returns the sound wave travel time in microseconds
topduration = pulseIn(topecho, HIGH);
medduration = pulseIn(medecho, HIGH);
botduration = pulseIn(botecho, HIGH);
// Calculating the distance
top = topduration * 0.034 / 2;
med = medduration * 0.034 / 2;
bot = botduration * 0.034 / 2;
// Prints the distance on the Serial Monitor
Serial.print("Top: ");
Serial.println(top);
Serial.print("Med: ");
Serial.println(med);
Serial.print("bot: ");
Serial.println(bot);
if(HayVal <= 1) {
status = false;
else {
status = true;
//__________________________________________
if(bot > 30 && med > 30 && top > 30){
HayVal = 0;
if(bot <= 30 && med > 30 && top > 30){
HayVal = 1;
//____________________________________________
if(bot <= 30 && med <= 30 && top > 30){
HayVal = 2;
//________________________________________________
if(bot <= 30 && med <= 30 && top <= 30){
HayVal = 3;
Serial.print("HayVal: ");
Serial.println(HayVal);
Since Status is READ_WRITE variable, onStatusChange() is
executed every time a new value is received from IoT Cloud.
void onStatusChange() {
// Add your code here to act upon Status change
Since Alerts is READ_WRITE variable, onAlertsChange() is
void onAlertsChange() {
// Add your code here to act upon Alerts change
Why am I getting straight 0s on "med" and "bot" but not on the top? I know the sensor is not defective because it works on the top. Could it possibly be because my Arduino Nano 33 Pins are defective, even though pins 13, 12 work? Or is it an error in my code?
[quote="loben, post:1, topic:1154778"]
you corrupt timing for each sensor. do each sensor readings one after one
The obvious reason is you are NOT allowing enough time between sensor pulsing for the sound and echo from the first sensor to die out. You cannot expect a sound sensor to work properly when you operate them THAT fast. Try allowing 1/2 second between sensor pulses.
